Northern California NorCal
Old 01-24-2014, 01:28 AM   #631
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I am going to NCRC Laguna Seca on 7/28 and Thunderhill on 8/2-8/3. Excited! Well, a long way off.
Old 01-24-2014, 11:53 AM   #632
AyJay
AyJay's Avatar
Drives: 22 GR86, 13 FR-S, AP2 S2000
This vid is 86 related so I'll post. From 12/15 @ Thunderhill w/ CityTech's advanced group. I'm driving my S2000 and battling it out with an ol' school AE86 which I was told had an F20c swap (s2000 engine). This car was pretty fast! These aren't my fastest laps of the day since I was still trying to dial out some under steer which I got right by the end of the day.
[ame="https://www.youtube.com/watch?v=xbmcJnJx5Nc"]12/15/13 CityTech @ Thunderhill - S2000 and AE86 w/ f20c swap - YouTube[/ame]
Also, for experienced GoPro users, can you make some recommendations to shoot a better video? I have the GoPro mounted on a custom s2000 mount over my right shoulder but is there anyway to zoom in a bit? Additionally, I have the dark setting on that looks like a dot on the screen. It's said to improve day videos shot from inside dark cars... does anyone use this setting? It'd probably help if I paid attn to my GF putting down the sun visor. LoL
AyJay is offline   Reply With Quote
The Following 2 Users Say Thank You to AyJay For This Useful Post:
RC51ed (01-24-2014), WoOosOn (01-24-2014)
Old 01-24-2014, 12:09 PM   #633
RC51ed
RC51ed's Avatar
Drives: 2013 Scion FRS
Amazing how that ae86 took off in the straights with the s2000 motor. Great job on getting him and passing him at the end. Looks like he made you work for it a lot.
RC51ed is offline   Reply With Quote
The Following User Says Thank You to RC51ed For This Useful Post:
AyJay (01-24-2014)
Old 01-24-2014, 01:01 PM   #634
AyJay
AyJay's Avatar
Agreed. He definitely had the power/weight ratio advantage over my stock engine S2000. He definitely put some gap me on the straights.
It looks like I had a traction advantage where my car was carrying higher cornering speeds. While I was fighting understeer and having to back off my entry speed (especially evident in turn 2-3-4) he was fighting his rear end breaking loose. Ultimately, I was able to catch and pass once we got thru the other traffic.
BTW, check out my buddy Dan's rediculously fast modified M3 on slicks running sub 2:00 laps!
Old 01-24-2014, 03:14 PM   #635
PMok
Codename: Stitch
PMok's Avatar
Great video AyJay! Great driving, and yeah that AE86 had some tail wagging oversteer all over the place... Running at the ragged edge, haha.
It depends on what model of GoPro camera you have, but most of the newer ones have the ability to set the field of view between wide, medium, and narrow. If you record at the highest resolution, I don't think you can go narrow, but you can always edit and crop to a more zoomed in view using editing software like iMovie. Yes, the spot metering mode that you are using is the right mode to use when you're shooting inside the car with a wide enough angle to show both the interior and exterior. What it does is use the light metering based on the exact center of the image, so if you have it pointed to look out the window, it will expose for the outside view as opposed to the inside. If you use the normal mode in that situation, the camera tends to try to brighten exposure to reveal the details of your interior, which tends to be darker and therefore will overexpose the view outside the window.
Old 01-26-2014, 11:47 AM   #636
AyJay
AyJay's Avatar
Thanks for the tips PMok. I have the hero 3 black edition. Now that you mention it, I do remember the field of view settings you are referring to. I will take a look at those again to see if changing the setting makes it look like the camera is closer. Right now I think I have it set on wide. I'd like to be able to make a better video when I run the fr-s on 2/7.
Old 01-26-2014, 11:49 AM   #637
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
Awesome driving AyJay!! Love how u hug turn 2 and 3!!
Get one more GoPro mount on outside front windshield!!
Sent from my iPhone using TapatalkfQ
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following User Says Thank You to RehabJeff86 For This Useful Post:
AyJay (01-26-2014)
Old 01-26-2014, 01:16 PM   #638
MyRx
MyRx's Avatar
Great driving AyJay! Way to go sticking with him.
How did you resolve your understeer - tires, stiffened the rear?
The Following User Says Thank You to MyRx For This Useful Post:
AyJay (01-26-2014)
Old 01-26-2014, 02:15 PM   #639
PMok
Codename: Stitch
PMok's Avatar
ok, I have the same GoPro as you. The narrower FOV settings are only available at the 1080p and lower resolution settings I believe. And yeah they will have the effect of looking more zoomed in. If you are recording at 1440p or higher it won't let you choose them.
The Following User Says Thank You to PMok For This Useful Post:
AyJay (01-26-2014)
Old 01-26-2014, 03:13 PM   #640
AyJay
AyJay's Avatar
I was able to tame the oversteer by playing with my tire pressures. I recently added aero to my car which completely changed the driving dynamics of it. Pre-aero w/ 255 squared tires i would tame oversteer with an adjustable front sway bar and higher front PSI in the tires (PSI tricks I learned from my AutoX days). Since the addition of the aero parts I had so much rear downforce I had to put my oem front sway bar back on and I've been still dealing with high speed understeer. Once i realized thru trial and error that I would probably benefit from running higher PSI in the rear than the front (something I've never done) then the car really felt neutral again. I dropped my lap time 0.8 sec just by adding an add'l 2 PSI in the rear.
I probably will have to do some more tweaking next time out. The car is over at Driving Ambition in Cameron Park right now getting improved front aero similar to what the run on their SCCA race S2k. My adjustable wing is completely flat right now and with better front aero I expect to be able to increase the Angle of Attack and get even more balanced traction and a lower lap time.
The Following User Says Thank You to AyJay For This Useful Post:
MyRx (01-27-2014)
Old 01-29-2014, 03:01 AM   #641
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Double Post *sorry
leicaboss is offline   Reply With Quote
Old 01-29-2014, 03:24 AM   #642
leicaboss
Coffee Snob
leicaboss's Avatar
I think I'm going to register for NCRC's Thunderhill ASAP - anyone with a place to crash willing to let me throw a few bucks your way? I've got a sleeping bag and some mats I can sleep on, don't mind sleeping on the floor. Sigh.
Old 01-29-2014, 03:34 AM   #643
PMok
Codename: Stitch
PMok's Avatar
looks like the Feb. 7 NCRC day is pretty much full... so much for waiting till last minute to sign up. I might still come out just to spectate/bum rides though.
BRZkitty (01-29-2014)
Old 01-31-2014, 12:35 PM   #644
AyJay
AyJay's Avatar
1 week away! Got my NCRC packet in the mail yesterday.
BRZkitty (01-31-2014), EAGLE5 (01-31-2014)
HPDE - Sebring with PCA 2/23/13 - 2/24/13 Dave-ROR Southeast 2 01-03-2013 09:25 PM
How can you help somebody get into HPDE RedRocket Tracking / Autocross / HPDE / Drifting 4 10-02-2012 07:19 PM
HPDE with BMW CCA Texas BRZ Southwest 0 09-14-2012 11:46 AM
norcal hpde? slaxx Southern California 1 08-18-2012 02:13 AM
HPDE Day video Dragonitti Other Vehicles & General Automotive Discussions 34 06-12-2011 10:11 PM
