Old 01-14-2014, 09:07 PM   #155
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
Originally Posted by Glaedon View Post
Did this last night and it sounds SO much better. Thanks for the tip I can finally hear my Borla exhaust over 3500 rpm!
So where exactly is this hole? Drivers side pull back the Matt and it's near the gas pedal ? Or am I wrong
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-14-2014, 09:21 PM   #156
congee
congee's Avatar
Drives: SSM BRZ
Passenger side below the glove box. Pull the carpet down and you'll see a hole. You can't miss it.
I plugged the hole on my stock brz and wasn't too impressed tbh. Made the car sound quieter/slower than it already is loll I am one of the few that like the sound intake haha
I'll probably plug it again once I get a exhaust and intake.
congee is offline   Reply With Quote
Old 01-23-2014, 06:56 PM   #157
fubarian
Drives: 13 FR-S
Originally Posted by mezdup View Post
for anybody in the US interested in doing this. i just took a quick trip to lowe's and found what i think is the same exact plug that @Tech used. it was about $1.50 for 2 plugs. fit perfectly. i'll see if i notice any difference when i go out later.
Can this plug be installed permanently without water leaks?
fubarian is offline   Reply With Quote
Old 01-23-2014, 07:04 PM   #158
mezdup
#1362
mezdup's Avatar
Drives: 2014 Ice Silver WRX
Water leaks?
Sent from my ADR6425LVW using Tapatalk
mezdup is offline   Reply With Quote
Old 01-23-2014, 07:42 PM   #159
fubarian
Drives: 13 FR-S
Water leaks?
Yes, water leaks. Should have clarified that I want to delete the sound tube completely, so the side in the engine compartment will be open. Or is it better to seal it from the engine compartment side?
Old 01-24-2014, 02:33 PM   #160
xlid007
Drives: Scion FRS
I'm wondering the same thing as I'm getting my intake tomorrow and I'm going to delete the sound tube completely. The sound tube can be taken out by just pulling it out; I'm guessing through the engine side. Do I have to plug the engine side and cabin side or just one is good enough?
xlid007 is offline   Reply With Quote
Old 01-24-2014, 08:21 PM   #161
Tech
Tech's Avatar
Drives: White MT GT86 with TRD extras
If you are removing the sound tube then you only need to remove it down to the plastic elbow as shown in this picture. place a rubber cap over the exposed elbow and that is it. You don't need to plug the other end inside the cabin or even need to remove the tube beyond this point. If you do, then you will only have to start looking for an even larger plug to fill the hole in the firewall.
I have two of these cars. One has the tube still connected to the intake and just plugged in the cabin. The other car has the tube completely removed. I can assure you the complete removal of the sound tube is absolutely no quieter than a plugged tube! It does however make the engine bay a lot less cluttered.
Tech is offline   Reply With Quote
Old 01-25-2014, 02:06 PM   #162
fubarian
Drives: 13 FR-S
Do you have a source or part number for this cap?
Old 01-25-2014, 02:15 PM   #163
nzer
nzer's Avatar
Drives: 2012 Grey TRD GT86, 2015 VW Golf R
http://www.frsmod.com/products/scion...ube-delete-kit
There's cheaper DIY options but this one looks nice.
nzer is offline   Reply With Quote
Old 01-26-2014, 12:35 AM   #164
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
A foam earplug or a wad of bubble gum will do the same thing if your mod budget won't cover it 8)
Old 01-27-2014, 07:54 PM   #165
schmearcampain
Drives: 2014 Argento FRS 6MT
Wait a minute. This whole assembly coming off the left side of the air intake is just to provide a certain sound in the cabin?
what a waste of time and material.
schmearcampain is offline   Reply With Quote
Old 01-27-2014, 08:24 PM   #166
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Yup. And yup again.
Now, if only someone could give the dimensions of the cap for the intake hole I'd need, I'd go outside right now & delete the sound tube entirely.
^GT5 Replay Photo Mode^
Old 01-27-2014, 08:31 PM   #167
nzer
nzer's Avatar
Originally Posted by SirBrass View Post
Yup. And yup again.
Got a ruler?
Old 01-27-2014, 08:45 PM   #168
JS + BRZ
Drives: 2010 MS3
Thanks for this. Didn't know about this til now.
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 10:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
