Old 01-21-2014, 05:20 PM   #239
Red FRS
Red FRS's Avatar
Drives: 2014 Subaru BRZ
Originally Posted by Luckrider View Post
No problem. I have 3 tanks through 1.42b and 1/2 tank through 1.52b with no issues on my 100% stock car. I know other are in the same boat. You may have cold start issues (below 50 degrees) if you have high ethanol content in your area.
Edit: If you do have cold start issues, I have a copy of Malt's Table changes for IPW, and even an edited A001 tune to match his adjustments if you need.
Ok that's awesome. Yeah I shouldn't have an issue really with cold starts. I'm in south florida. Thanks for that though, really appreciate it. I just filled up my first E85 tank, seems to be driving fine. I'm on the 1.42
Molded rb v1 BRZ on WCI LP1
instagram.com/seantejani
Red FRS is offline   Reply With Quote
Old 01-21-2014, 05:23 PM   #240
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
I don't know how cold it gets for you, but e90 has been troublesome for people with just 50°.
Luckrider is offline   Reply With Quote
The Following User Says Thank You to Luckrider For This Useful Post:
Red FRS (01-21-2014)
Old 01-21-2014, 05:25 PM   #241
Red FRS
Red FRS's Avatar
I almost never gets below 50 other than at night. Sunny south florida! Lol
Old 01-21-2014, 06:15 PM   #242
Cross
It's the Mad Cow
Cross's Avatar
Its in the 70's here or more but at night its in the 40's. Without any changes made the car takes 2-3 tries to start in the morning.
Old 01-21-2014, 07:36 PM   #243
1086
1086's Avatar
Drives: UM86 - 6MT
I have not had any cold start issues w/ E85 for the past 4 days I have been running it, I wonder why....
1086 is offline   Reply With Quote
Old 01-22-2014, 03:57 AM   #244
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
I played with the cranking tables and upped the fuel at 20c and below by quite a bit. This did not lead to smooth starting. I then raised the idle target when cranking to 2krpm. This helped a lot. 2nd crank every time instead of usually third. Also, this evening in ~50 degree weather, it started on the first try. I was amazed. We'll see how it is tomorrow morning. I will keep playing with the tables and see how it goes. At the least, I suggest you raise your target idle on the tables to 2krpm when at low temps.
I am running e85 propel, which seems to be, at least so far, much richer on the ethanol than the gas.
Old 01-23-2014, 11:32 AM   #245
EAGLE5
Dismember
EAGLE5's Avatar
By doubling, yes doubling, the stock fuel table, I have a rough but successful start on a first turn of the key on a 50F morning if I push the accelerator down. This is as opposed to no fuel. I also raised the idle target to 2k rpm. Still need to tweak.
Old 01-23-2014, 11:48 AM   #246
Td-d
Garden variety obsessive
Drives: 2009 Sti Hatch; 2015 Audi RSQ3
The fact that you're getting a better response when you are pressing the accelerator down means that you are overfueling on cranking now. There is a table that will progressively cut cranking pulse width the further the accelerator is pressed down.
Td-d is offline   Reply With Quote
Old 01-23-2014, 12:07 PM   #247
Cross
It's the Mad Cow
Cross's Avatar
Didn't a member post his table up which have resolved almost everyone's cold start issues? Why wouldn't you try those instead?
My car starts on the first pull every time now, I have just been tweaking it trying to get the cold start idle under 1300rpm but its taking a little more work. Its close though.
Old 01-23-2014, 12:17 PM   #248
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
I'll be going back to running e85 on our test car night. Could you point me to these settings? I'll give them a try and update the OTS maps according
Cheers
shiv
Shiv@Openflash is offline   Reply With Quote
Old 01-23-2014, 12:25 PM   #249
Cross
It's the Mad Cow
Cross's Avatar
Cheers
shiv
Sure umm crap I have the pictures on my laptop this is my work desktop just a second let me look for the thread. Ok Found it. @mad_sb was the one I started with but others on Page 2 also posted what they were using. Its down towards the bottom.
http://www.ft86club.com/forums/showt...t=53537&page=7
Last edited by Cross; 01-23-2014 at 12:43 PM. Reason: Corrected Mad's name for proper credit.
The Following User Says Thank You to Cross For This Useful Post:
Shiv@Openflash (01-23-2014)
Old 01-23-2014, 12:37 PM   #250
Shiv@Openflash
Drives: 2013 FRS
Sure umm crap I have the pictures on my laptop this is my work desktop just a second let me look for the thread. Ok Found it. @mad_sd was the one I started with but others on Page 2 also posted what they were using. Its down towards the bottom.
Thank you for that. Anyone else want to post up cold start cranking settings that are working from them when the OTS settings were giving them hard starts in the morning. I'll test the settings in our CA not-so-cold morning here before implementing them in the new revision of OTS maps.
Old 01-23-2014, 01:07 PM   #251
Indestruct
Drives: 2013 SWP Limited BRZ, MT
Thanks SHIV for addressing this, maybe you can run a tank of Propel Fuel too, seems to be what everyone is having problems with. Also hopefully these updates will be available for the older Roms... mine is 700C...
Indestruct is offline   Reply With Quote
Old 01-23-2014, 02:09 PM   #252
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Running E85 and getting starts 100% in about 22degF weather, BUT I am getting about 30s of minor stumbling and a noise that sounds a little bit like a short grind.
Anyone have any ideas?
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
OpenFlash Tablet Rombinhood@OpenFlash Software Tuning 1838 07-29-2023 06:35 PM
Openflash Tablet v1.31 beta maps (including Stage 2!) now available for download Shiv@Openflash Software Tuning 354 02-08-2015 05:23 PM
Is Openflash tablet detectable? Boofneenee Software Tuning 25 05-02-2014 10:03 PM
OpenFlash Tablet Stage 1 v1.2 maps available for download Shiv@Openflash Software Tuning 31 10-31-2013 08:45 PM
WTB Openflash Tablet Vlady Want-To-Buy Requests 0 10-25-2013 12:10 AM
