| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: WRB JR BRZED
RS05RR Setup
Was going to run some 17x8 Wheels but I like the RS05RR.
Thinking about RS05RR 18X8.5 +42 square with 245/35 michelin pss. The car will be running around 250ish whp. Any cons/concerns with that setup? |
#2 |
I like to eat!
You may need spacers to get flush. ~+38/35 may be better offset.
#3 |
Drives: fr-s
15-20 offset. I run a =10 in my 17x8.25 xxr's
| The Following User Says Thank You to executivekoala For This Useful Post: | charged86 (01-23-2014) |
#4 |
Drives: frs
Setup should fit fine. No rubbing or hitting another. Depending on camber settings and such you can go with a lower offset as someone said if you want a more "flush" look.
#5 |
Michilen dosent have a 245/35-17. If you want a oem height you need the 245/40. Which I have. @250 wheel youll have good traction. 375wheel is a different story. Lol
#6 |
Ridge Racerrrrrrrrr
You will be fine, enjoy it, will be very fun
#7 |
Drives: BRZ(sold), STI
Do not go below +30-ish in offset, otherwise you royally screw up your handling, but changing the sign of the scrub radius.
| Wheel Directory: Enkei RS05RR 18x9.5 +43 | FT-86 SpeedFactory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 129 | 09-22-2019 10:39 PM |
| Wheel Directory: Enkei RS05RR 18x8.5 +42 | dabocx | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 206 | 03-02-2018 05:23 AM |
| Enkei rs05rr x rocket bunny | RocketBunny86ph | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 01-30-2014 01:55 PM |
