Old 01-23-2014, 12:48 AM   #1
enivid
enivid's Avatar
Drives: WRB JR BRZED
RS05RR Setup
Was going to run some 17x8 Wheels but I like the RS05RR.
Thinking about RS05RR 18X8.5 +42 square with 245/35 michelin pss.
The car will be running around 250ish whp.
Any cons/concerns with that setup?
enivid is offline   Reply With Quote
Old 01-23-2014, 01:21 AM   #2
Pete156
I like to eat!
You may need spacers to get flush. ~+38/35 may be better offset.
Pete156 is offline   Reply With Quote
Old 01-23-2014, 01:44 AM   #3
executivekoala
executivekoala's Avatar
Drives: fr-s
15-20 offset. I run a =10 in my 17x8.25 xxr's
executivekoala is offline   Reply With Quote
Old 01-23-2014, 01:58 AM   #4
donutfilling
donutfilling's Avatar
Drives: frs
Setup should fit fine. No rubbing or hitting another. Depending on camber settings and such you can go with a lower offset as someone said if you want a more "flush" look.
donutfilling is offline   Reply With Quote
Old 01-23-2014, 08:41 AM   #5
charged86
charged86's Avatar
Thinking about RS05RR 18X8. square with 245/35 michelin pss.
Michilen dosent have a 245/35-17. If you want a oem height you need the 245/40. Which I have. @250 wheel youll have good traction. 375wheel is a different story. Lol
Old 01-23-2014, 10:02 AM   #6
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
You will be fine, enjoy it, will be very fun
Old 01-23-2014, 11:06 AM   #7
dsgerbc
Drives: BRZ(sold), STI
Do not go below +30-ish in offset, otherwise you royally screw up your handling, but changing the sign of the scrub radius.
Wheel Directory: Enkei RS05RR 18x9.5 +43 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 129 09-22-2019 10:39 PM
Wheel Directory: Enkei RS05RR 18x8.5 +42 dabocx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 206 03-02-2018 05:23 AM
Enkei rs05rr x rocket bunny RocketBunny86ph Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 01-30-2014 01:55 PM
