Old 01-06-2014, 12:41 PM   #561
wootwoot
Drives: FRS
I got one of theses types. I found a 70mm version off ebay which should fit inside the intake tube right in front of the MAF.
http://www.treadstoneperformance.com...t.phtml?p=2096
I also got one of these.
http://www.jscspeed.com/catalog/AEM_...d3-5016-1.html
Old 01-06-2014, 03:06 PM   #562
nelsmar
If that AEM one fits inside the actual airbox... thatd be great. You want to attempt to fix the flow before the MAF if possible. Mind you, you will most likely need to shift your MAF scaling on your tune.
My flickr - Canibeat
Local magazine scout
Old 01-06-2014, 03:59 PM   #563
wootwoot
Drives: FRS
Indeed.... I figured you could help with the MAF scaling. Are you interested? Assuming I can make them fit in my box before I send them to you? Would be an interesting experiment..... And it could result in the best intake for the platform....
Old 01-06-2014, 04:14 PM   #564
nelsmar
I can help with maf scaling. If you have ecutek... I can help you remotely using your vehicle as well.
Old 01-06-2014, 04:17 PM   #565
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
Innovate Twin Screw Supercharger seems to be the only FI setup that MIGHT fit along with the trd intake. Can anyone confirm this? Looking into FI later down the road.
Carlitoz3 is offline   Reply With Quote
Old 01-06-2014, 04:33 PM   #566
nelsmar
the TRD intake has a rear facing throttle tube, while the OEM has a passenger facing throttle tube that has a bend in it. So the intake wont bolt up.
Old 01-06-2014, 04:36 PM   #567
nelsmar
It looks like @Ninjin ordered the AEM one. If your wanting to send the mesh one we can for sure test it out and do a quick MAF scale to see how it compares. PM me your number and we can talk this evening.
I am tired of bad info on intakes, tunes, etc! Things like this should be out in the open! I had multiple tuners tell me intakes were "bad" in the past but never explained why until I was able to start just logging cars my self and messing with them.
Old 01-06-2014, 10:52 PM   #568
Thorpedo
The SquadWhisperer
How the heck did you come to this conclusion? Outlets are in entirely different places and are perpendicular to each other.
Thorpedo is offline   Reply With Quote
Old 01-06-2014, 11:06 PM   #569
wootwoot
Drives: FRS
PM sent
Old 01-07-2014, 12:38 AM   #570
Carlitoz3
Carlitoz3's Avatar
I said 'MIGHT'. Was only judging based on online pictures of the engine bay
Old 01-07-2014, 12:01 PM   #571
DAN_BRZ
DAN_BRZ's Avatar
Drives: 2013 WRB BRZ Sport Tech
i also have this trd cai, i actually sold woot his, ill be following this very closely, maybe i can pick up a air straightener as well to help out. let me know.
DAN_BRZ is offline   Reply With Quote
Old 01-08-2014, 01:25 AM   #572
nelsmar
Well we made some tuning progress... At least log wise. Still have to hit the dyno to see if it actually helps. AFR's are more stable. I still have a few holes in my map, and need to do some general smoothing. This was done with speed density tuning instead of maf. We just completely ignored the MAF sensor. Mind you this log is far more detailed than the other ones i posted. the spots @ 3,600 & 5,000 will be smoothed out soon. We will then need to re-apply some cam changes and re-tweak (SD tuning takes a lot more work than MAF).
Custom map L is a wideband sensor.
The Following 2 Users Say Thank You to nelsmar For This Useful Post:
Thorpedo (01-08-2014), vtmike (01-18-2014)
Old 01-22-2014, 01:20 PM   #573
DAN_BRZ
DAN_BRZ's Avatar
any update? @nelsmar has anyone sent you a air straightener for testing yet?
Old 01-22-2014, 01:36 PM   #574
HunterGreene
Hail Magnet
HunterGreene's Avatar
I am pretty sure his car is dead right now. Could make testing difficult.
http://www.ft86club.com/forums/showthread.php?t=56141
It has priests in it?
The Following User Says Thank You to HunterGreene For This Useful Post:
DAN_BRZ (01-22-2014)
cold air intake vs short ram intake ? tnt Engine, Exhaust, Transmission 5 02-02-2014 12:43 AM
So cold air intake or air intake? bcmakesiteasy Engine, Exhaust, Transmission 12 02-01-2014 08:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 01:31 PM
