Old 01-13-2014, 10:42 PM   #43
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Yes i think Whiteline have many good products!
o= FR-S =o
Mikepage is offline   Reply With Quote
Old 01-19-2014, 11:12 PM   #44
stueck9356
Drives: 2015 VW GTI SE
I'd like to add progress sway's to the list
http://www.progressauto.com/products.../productID/759
Had them on my miata, the bushing and brackets were over-the-top amazing and the bars were perfect.
stueck9356 is offline   Reply With Quote
The Following 2 Users Say Thank You to stueck9356 For This Useful Post:
chanomatik (01-21-2014), zdr93523 (05-13-2014)
Old 01-21-2014, 06:20 PM   #45
Mikepage
Mikepage's Avatar
Any input from others users? I think my list is not complete, I just send an email to Whiteline to get the missing information about the 22mm front.
o= FR-S =o
Old 01-21-2014, 06:26 PM   #46
Mikepage
Mikepage's Avatar
Done!
o= FR-S =o
Old 01-21-2014, 07:14 PM   #47
Mikepage
Mikepage's Avatar
Whiteline spec updated!
o= FR-S =o
The Following User Says Thank You to Mikepage For This Useful Post:
Old 01-29-2014, 06:13 PM   #48
stueck9356
Am looking at getting the progress I mentioned earlier and got some more in-depth info from them. Slightly softer than other options so I might pass.
The FRS/BRZ Progress sway bars are a solid bar design front and rear.
The front OE bar is 18mm. The Progress is 21mm nonadjustable a 70% increase in rate. With a rate of 225 lbs/in.
The rear OE bar is 14mm. The Progress is a 17mm 2 hole adjustable a 145% increase in rate. With a rate of 275 lbs/in adjusted by 15% between the 2 locations.
Old 02-02-2014, 02:31 PM   #49
fstlane
fstlane's Avatar
Drives: BRZ Limited
Does anyone have specs or feedback on the Tanabe 22mm hollow front bar? I'm looking for an alternative to the Strano unit due to fit and availability issues. I also like that the Tanabe bar uses antiwalking tabs. Thank you!
fstlane is offline   Reply With Quote
The Following User Says Thank You to fstlane For This Useful Post:
SuperTom (07-11-2025)
Old 02-03-2014, 11:09 PM   #50
Mikepage
Mikepage's Avatar
Maybe you can ask tanabe directly and let us know! And I will update the first page!
o= FR-S =o
Old 02-03-2014, 11:14 PM   #51
Mikepage
Mikepage's Avatar
FYI My current setup is : 16mm whiteline sway bar with braces for the rear and 25.4mm Hotchkis sway for the front. I love the setup and the feel with less body roll compare to stock.
Details : Soft, first hole position for the front bar and middle position for the rear.
o= FR-S =o
fstlane (02-04-2014)
Old 02-04-2014, 02:05 PM   #52
fstlane
fstlane's Avatar
Drives: BRZ Limited
I emailed them for technical specs and went ahead and ordered one. I'll update this post with data when I get it. Thanks for the useful list!
2/11update from tanabe-usa
Japan got back to us with some information regarding the front and rear Tanabe stabilizer bars. The stiffness rate for the Front is 205% and the Rear is 235% stiffer compared to Japan OEM. The difference OEM between*for the US and Japan is in the rear. The front outside diameter of the bars are the same but for the rear Japan is 14mm thick compared to the U.S. which is 13mm thick.
The Following 2 Users Say Thank You to fstlane For This Useful Post:
Mikepage (02-04-2014), SuperTom (07-11-2025)
Old 02-08-2014, 08:58 PM   #53
Mikepage
Mikepage's Avatar
First post refined!
o= FR-S =o
fstlane (02-08-2014)
Old 02-11-2014, 05:47 PM   #54
fstlane
fstlane's Avatar
Drives: BRZ Limited
Updated above. Thank you!
Mikepage (02-11-2014)
Old 02-11-2014, 06:22 PM   #55
Mikepage
Mikepage's Avatar
First post Updated. But am not sure about the size of the US rear sway bar... Who can confirm? I have my sway bar but its difficulty to measure without the correct instrument...
o= FR-S =o
fstlane (02-11-2014)
Old 02-14-2014, 09:50 PM   #56
fstlane
fstlane's Avatar
Drives: BRZ Limited
14mm appears to be the correct diameter for the US rear sway bar.
Source: http://www.motoiq.com/MagazineArticl...ne-Dodger.aspx
Mikepage (02-14-2014)
New F/I option SnapOv3st3r Forced Induction 41 03-24-2013 09:44 PM
Leather Option. l0aded Scion FR-S / Toyota 86 GT86 General Forum 20 03-02-2013 08:59 PM
Diffuser Option on the BRZ Markone AUSTRALIA 25 01-14-2013 03:21 AM
Scion FR-S Option list Crashoverride Scion FR-S / Toyota 86 GT86 General Forum 38 04-18-2012 03:37 PM
Considering this as another option 2011 WRX Draco233 Other Vehicles & General Automotive Discussions 5 04-01-2012 10:01 PM
