Old 01-20-2014, 01:58 AM   #15
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Originally Posted by HATED1 View Post
I had a few lights go on after installation. Just get it aligned and they will go. It's because everything is out of spec.
Originally Posted by Dwood11 View Post
After I recently installed my hotchkiss springs and some lca's and my car was doing the same thing. The car was scarry to drive. The car knows its out of spec and is telling you something is terribly wrong. Out of curiosity did you put in the lower lcas? Once you get an alignment you should be good. Oh and this should be moved to the suspension thread if a mod sees this please. You will have more luck with answers there.
It's the alignment, trust me.
Originally Posted by SubaSteve View Post
Do this any time you modify anything on the car.
sorry to hear man. In my situation, after putting on the coils, the wheels where way of spec. After the alignment everything cleared after driving it a few miles on the freeway.
I love the advice given above... really sound advice.
Never knew a car would know what a good alignment is from a bad one. I bet my car also knows I ate shitty food tonight and will throw me a CEL for that.
Edit: I don't know what caused you guys to reach this type of conclusion, but there is no way a bad alignment can be causing a CEL or other code.
To the OP: something is causing the sensors to go bad. You might want to inspect the parts that could be causing a bad reading, such as speed sensor, ABS sensor, ABS lines, etc.
I don't know about what coilovers you're running, but my Ohlins just has a simple tab for the ABS sensor to be mounted. Sometimes you could install something, have the lines bind, and put the car down on the ground and pull apart a sensor or line.
-alex
Old 01-20-2014, 01:32 PM   #16
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
-alex
Thanks Alex I just booked an appointment with a Subaru dealer tomorrow at 3. Hopefully they'll diagnose the problem without giving me shit for the coilovers..
Eelusive is offline   Reply With Quote
Old 01-20-2014, 01:34 PM   #17
mav1178
mav1178's Avatar
If you have time, take off the front wheels and inspect the connections. You might not need to go to a dealer for this.
Rear wheels aren't as affected, since suspension install in the rear doesn't touch the ABS/wheel speed sensor. But always a good idea to check.
Frankly the last thing you want is a dealer to give you crap for modding the car, because then they'll always use that as an "out" for legitimate problems. More trouble than what it's worth.
-alex
P.S. I should clarify: you should try to solve this problem on your own, because if it is indeed an ABS sensor line issue, the dealer won't be helpful on this matter to you and may add info to your vehicle file that could cause problems with future warranty claims.
Old 01-20-2014, 01:42 PM   #18
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
-alex
Already checked them they seemed fine... We even traced them all the way into the engine bay.
Old 01-20-2014, 01:45 PM   #19
mav1178
mav1178's Avatar
Check fuses too.
-alex
Eelusive (01-20-2014)
Old 01-20-2014, 02:50 PM   #20
Pneub
Drives: Dark Grey BRZ
I had this same issue awhile back. It was a single sensor that went bad that caused exactly what you're describing. Once that sensor was swapped it was fine. I'll come back with more info in a bit.
Pneub is offline   Reply With Quote
The Following User Says Thank You to Pneub For This Useful Post:
Old 01-20-2014, 03:05 PM   #21
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Check fuses too.
-alex
Fuses were A ok as well.
Thanks keep me informed!
Old 01-20-2014, 03:12 PM   #22
stugray
Drives: 2013 GBS BRZ Limited
If the dealer needs to fix anything due to the mods being installed, they will likely NOT cover it under warranty.
And I also agree that the car shoudld not know that the alignment is messed up UNLESS it changed the spacing between the ABS sensor and the wheel.
Old 01-20-2014, 03:24 PM   #23
Pneub
Ok so it appears we ended up jacking up the line to the speed sensor. I'd check that sensor and the line.
Old 01-20-2014, 03:25 PM   #24
raul
Lap time enthusiast
raul's Avatar
Drives: Asphalt '13 FR-S 6MT
It's possible you yanked on the ABS/Wheel speed sensor line hard enough to damage it. Other than that, I can't think of any other electronics that might be involved with installing coilovers.
raul is offline   Reply With Quote
The Following User Says Thank You to raul For This Useful Post:
Old 01-20-2014, 03:33 PM   #25
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
I think I just have to replace the abs/speed sensors. Probably the cause of this, the shop installing my coilovers was putting to much pressure on the lines... I think it would be safe to come to the conclusion that he probably fucked over the wires internally.
Old 01-20-2014, 03:49 PM   #26
Pneub
I would do this before taking it to the dealership
Old 01-20-2014, 04:03 PM   #27
Chee-Hu
Chee-Hu's Avatar
I would take it to the shop and let them take care of it.
Chee-Hu is offline   Reply With Quote
Old 01-20-2014, 04:18 PM   #28
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Why would they void my warranty?
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 10:22 PM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 01:52 PM
All RED interior dash lights and hvac ? Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2013 09:41 PM
Holy crap tail lights!! raul Cosmetic Modification (Interior/Exterior/Lighting) 9 10-05-2012 07:11 PM
HELP!!! FR-S Shutdown all lights on the dash came on!!! tric Scion FR-S / Toyota 86 GT86 General Forum 64 09-15-2012 02:57 PM
