Old 01-20-2014, 07:52 AM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
What does it mean when tractions off and check engine come on?
This morning i didnt let my car warm up and drove it. Got a check engine light with traction off. Stoppes turned car off and then on and revved the motor a little and the traction light went away. Has anyone expeienced this?
Frs32907 is offline   Reply With Quote
Old 01-20-2014, 08:10 AM   #2
ProTekk
ProTekk's Avatar
Drives: Whiteout FR-S
Check your gas cap. It's happened to a ton of us. Remove your gas cap and then tighten it until it clicks. Simple and stupid but it's the actual fix. If that doesn't do it, move on to scanning for codes.
ProTekk is offline   Reply With Quote
Old 01-20-2014, 09:15 AM   #3
Frs32907
Hope thats all it is call was tuned friday worked great for 2 days now check engine
Old 01-20-2014, 07:18 PM   #4
Frs32907
So car tuned with the vortech 2.5 bar map sensor and the code that it threw this morning was p0068. So my tuner thinks the car is either trying to relearn the throttle postions or the map sensor needs to go to a 3 bar
Old 01-20-2014, 10:14 PM   #5
pche
Guy on internet
Drives: Slowly
lol love how the plot thickens, from just an innocent little cold start CEL....
pche is offline   Reply With Quote
The Following User Says Thank You to pche For This Useful Post:
strat61caster (01-21-2014)
Old 01-21-2014, 01:14 AM   #6
laurenholmes
Drives: BMW
The track off light means your traction button is off..........you can fix it by pushing the button under your stereo. As for the check engine light or CEL, that could mean a number of things. Do you have an after market intake??? What kind of mods do you have???
laurenholmes is offline   Reply With Quote
Old 01-21-2014, 10:27 AM   #7
pche
Guy on internet
Drives: Slowly
Incorrect. The traction and cruise control light comes on every time the CEL comes on.
Old 01-24-2014, 09:19 AM   #8
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Umm... Why not put in the original post that the car has a Vortech and a tune? Because those things couldn't possibly cause a check engine light?
Do we have to ask if you've done anything else to the car?
Grimlock is offline   Reply With Quote
Old 01-24-2014, 09:33 AM   #9
Foobar
SLO NO MO
Foobar's Avatar
That code is related to MAF. Check for leaks in your SC setup, make sure everything is good, then send some datalogs to your tuner so they can troubleshoot it better.
Who's the tuner? The ECU learning the throttle wouldn't trigger that, and your Vortech should be fine with the 2.5 BAR MAP sensor, so long as your tuner scaled to it correctly.
Check engine light. Help!!!!! sf86 Issues | Warranty | Recalls / TSB 2 06-05-2013 03:51 AM
Check engine light with no symptoms? ultra Issues | Warranty | Recalls / TSB 6 03-12-2013 12:48 PM
Check engine light? czar07 AUSTRALIA 0 09-01-2012 02:50 AM
Engine sputtering while idling with check engine light flashing, WTF speedy racer Scion FR-S / Toyota 86 GT86 General Forum 15 08-27-2012 06:50 AM
Check Engine Light b.e Scion FR-S / Toyota 86 GT86 General Forum 9 06-17-2012 09:50 PM
