Old 01-19-2014, 01:20 PM   #1
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Crap lights on my dash after installing coilovers.
Well anyways.. I decided to put my car on some coilovers, Ksports to be exact, and for the love of god I don't need anyone being a complete fuck hole and tell me how I made a bad choice on coilovers. On to the main course, everything was running fine of course before I put the car on the lift, swapped out the stock for the coils. Put the wheels back on then when I started my beauty up the Tract light was on the CEL, ABS, Electric Steering light was also on wtf. So we hooked it up and scanned it with OBDII, it gave me a P0500 code for speed sensor A, and it also said something about the instrument panel... Any ideas what could have went wrong? We checked all the speed sensors and none of them where mangled or anything..,
Eelusive is offline   Reply With Quote
Old 01-19-2014, 01:52 PM   #2
HATED1
HATED1's Avatar
Drives: 86
I had a few lights go on after installation. Just get it aligned and they will go. It's because everything is out of spec.
HATED1 is offline   Reply With Quote
Old 01-19-2014, 02:25 PM   #3
ihaskrayon
The Comedian
Drives: SWP BRZ Limited
It's because you made a bad choice on coilovers
ihaskrayon is offline   Reply With Quote
The Following 12 Users Say Thank You to ihaskrayon For This Useful Post:
azngolfur (01-22-2014), chas3wba0 (01-20-2014), Chee-Hu (01-20-2014), DookDookDGM (02-18-2014), fledonfoot (01-20-2014), Ganthrithor (01-20-2014), Kevstra (02-12-2014), Pneub (01-20-2014), Ramster (01-20-2014), ubersoph (01-20-2014), weedtank (01-20-2014), yberther (01-20-2014)
Old 01-19-2014, 02:28 PM   #4
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Thanks for the insight, are you sure it can't be something more simple than that?
Old 01-19-2014, 02:56 PM   #5
Dwood11
Dwood11's Avatar
Drives: 2014 SWP BRZ LIMITED
After I recently installed my hotchkiss springs and some lca's and my car was doing the same thing. The car was scarry to drive. The car knows its out of spec and is telling you something is terribly wrong. Out of curiosity did you put in the lower lcas? Once you get an alignment you should be good. Oh and this should be moved to the suspension thread if a mod sees this please. You will have more luck with answers there.
Dwood11 is offline   Reply With Quote
Old 01-19-2014, 03:10 PM   #6
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Thanks for the reply, I did replace the stock front end links with the adjustable ones. The lower LCAs are still stock >_>
Old 01-19-2014, 03:26 PM   #7
HATED1
HATED1's Avatar
Drives: 86
It's the alignment, trust me.
The Following User Says Thank You to HATED1 For This Useful Post:
Old 01-19-2014, 10:11 PM   #8
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
just got my alignment... lights still on.
Old 01-19-2014, 10:15 PM   #9
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
try to reset ECU by removing Negative Battery
The Following 2 Users Say Thank You to zc06_kisstherain For This Useful Post:
ubersoph (01-20-2014), whataboutbob (01-19-2014)
Old 01-19-2014, 10:26 PM   #10
Byebye
Byebye's Avatar
I put coilovers on my car in my garage and didn't get any lights. Some wire is loose or broken. I don't get how your car can tell you that you are out of alignment and have an entire Christmas tree of light go off from a coilover install.
Byebye is offline   Reply With Quote
Old 01-19-2014, 10:34 PM   #11
Eelusive
Night Raid
Eelusive's Avatar
Drives: '14 CBS BRZ
Done that
Old 01-19-2014, 10:49 PM   #12
wheelhaus
wheelhaus's Avatar
There's no way the car can tell the wheels are out of alignment, especially when the car has just been started and isn't even moving.
THe only possibility a poor alignment could cause anything like this is if the alignment is SO HORRIBLY FUCKED that the wheels are scrubing and causing them to rotate at different speeds, or cause chassis yaw that the car thinks shouldn't be happening (such as driving in a straight line.
The speed sensors may not look mangled, but one may not be installed correctly or the wires may be damaged internally. If they were attached and the hub was lowered, the wire may have been pulled, or while things were moving one may have been pinched.
Old 01-19-2014, 11:00 PM   #13
HATED1
HATED1's Avatar
Drives: 86
sorry to hear man. In my situation, after putting on the coils, the wheels where way of spec. After the alignment everything cleared after driving it a few miles on the freeway.
Old 01-20-2014, 12:49 AM   #14
SubaSteve
Captain Cocoa
Drives: CBS BRZ MT
Do this any time you modify anything on the car.
SubaSteve is offline   Reply With Quote
Door Unlocked dash light coming and going after installing subwoofer tbertran Electronics | Audio | NAV | Infotainment 0 01-01-2014 10:22 PM
BEWARE when installing aftermarket tail lights, you must seal the area ! Kayzer Soze Cosmetic Modification (Interior/Exterior/Lighting) 5 08-27-2013 01:52 PM
All RED interior dash lights and hvac ? Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 2 06-05-2013 09:41 PM
Holy crap tail lights!! raul Cosmetic Modification (Interior/Exterior/Lighting) 9 10-05-2012 07:11 PM
HELP!!! FR-S Shutdown all lights on the dash came on!!! tric Scion FR-S / Toyota 86 GT86 General Forum 64 09-15-2012 02:57 PM
