Old 01-17-2014, 11:47 AM   #3081
fenton
Originally Posted by Robftss View Post
Attachment 63932
Vs. stock battery
2" longer
9 lbs heavier
PC 925 to be trunk mounted (25lbs)
That looks really clean Rob!
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 01-17-2014, 12:15 PM   #3082
jpit
Drives: Subaru BRZ
"I've never run a battery to the trunk. How hard is it?"
I'll let you know later today, hopefully. I'm using a 4 gauge positive lead (this would be the minimum size) and running right down the center console. Need to connect this to a 150 amp fuse at the positive terminal (can anyone confirm that we have a 130 amp alternator?) Have to find a location for the PC 925 battery. The real challenge is connecting all the leads up front. The wires that connect to the negative terminal should be fine connected to the chassis. The wire connectors will have to be modified.
jpit is offline   Reply With Quote
Old 01-17-2014, 12:41 PM   #3083
Robftss
Drives: VW
Name:  trunk start.JPG
I've done this before. (Not on this car)
U1 battery case, a couple flag posts, ground to chassis.
I would use a 200 to 250 Amp fuse (mega-ANL), stereo guys use these.
In the engine bay, use the stud (13mm) that is on the positive terminal clamp, to bolt the eyelet from your + extension.
Something like that.
Robftss is offline   Reply With Quote
The Following User Says Thank You to Robftss For This Useful Post:
DAEMANO (01-18-2014)
Old 01-17-2014, 06:17 PM   #3084
Gary in NJ
Gary in NJ's Avatar
Drives: WR Blue BRZ, 240Z
Wow, that's a lot of batteries.
Phantom ESC, ECUtek Tune, Nameless Front Pipe & Axle Back, Enkei RS+M 17x8 et35, OEM+Ref
Gary in NJ is offline   Reply With Quote
Old 01-18-2014, 06:32 AM   #3085
raven1231
Not hard at all. I did it on my old single turbo t67 3000gt.
Old 01-18-2014, 10:33 PM   #3086
jpit
Drives: Subaru BRZ
Installed the 4 battery system today. Install when pretty smooth except trying to locate a location for the starter battery. I was hoping to sit it on top of the spare tire but there wasn't enough clearance so I removed the spare tire and jury rigged the battery. Did a quick 0-60 run in 6.2 which is the best I've done but I don't do that very often. Car drives like before and I will try to get down to Speed Drift for a dyno after the batteries have been conditioned.
The Following 4 Users Say Thank You to jpit For This Useful Post:
DAEMANO (01-19-2014), fenton (01-18-2014), Robftss (01-21-2014), Sojhinn (01-18-2014)
Old 01-18-2014, 10:35 PM   #3087
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
What path did you take for the wires?
Installed Mods:
Old 01-18-2014, 10:47 PM   #3088
jpit
Drives: Subaru BRZ
Just the positive wire right down the center console. Only problem I had was the extra cable length presented a problem for my amplifier so I had to wire it direct to the new location. In the bottom photo you can see how I hooked up the ground wires. Installed a terminal right at one of the ground connections and it works fine.
Old 01-18-2014, 10:53 PM   #3089
fenton
Looks good!
I need go get my engine bay that clean.
Old 01-19-2014, 04:09 AM   #3090
silent runner
Drives: 93'Camry, 82'Corolla, 76' Celica
Me too. I need to clean my engine bay up. So much melting going on lately, and the city has no mercy about all the crappy salt it is spreading. I just pulled a late nighter finalizing the first installation of my old TQ250, on an old Toyota Camry V-6. Did a few extra torture tests, before I parked her for the night. Ever see an old (93') 3.0L, automatic Camry smoke its tires (On dry pavement) for 30-40ft across an intersection?
I also did a couple of rolling pulls, and it accellerates so much harder in an effortless way... no fuss no burps, something must be wrong.
silent runner is offline   Reply With Quote
The Following User Says Thank You to silent runner For This Useful Post:
Old 01-21-2014, 01:23 PM   #3091
radroach
Drives: car
This thread is useless without video!
Old 01-21-2014, 06:35 PM   #3092
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
And we have lift off (TQ250 installed) this morning
TQ300 will be tested later this week
Shiv@Openflash is offline   Reply With Quote
The Following 7 Users Say Thank You to Shiv@Openflash For This Useful Post:
DAEMANO (01-22-2014), fenton (01-21-2014), Luckrider (01-21-2014), normancw (01-21-2014), Robftss (01-21-2014), SKELLINGTON (01-21-2014), WRB5titch (01-22-2014)
Old 01-21-2014, 07:03 PM   #3093
Sojhinn
Sojhinn's Avatar
Shiv still coming down?
Installed Mods:
Old 01-21-2014, 11:51 PM   #3094
Shiv@Openflash
Drives: 2013 FRS
Yes indeed. Just don't have exact dates yet. Should know in a couple of days and will let you know
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 04:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 06:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 07:07 AM
