Old 12-21-2013, 01:27 AM   #43
Dr. BRZ
Dr. BRZ's Avatar
Drives: 2013 WR Blue Pearl BRZ Limited 6MT.
Originally Posted by DarkestBuddha View Post
I HAVE JOINED THE CLUB!
i added an extra diode on the power wire to have the DRLs turn off when the headlights come on
headlights on
impressions of this DIY: Its easy on paper, but actually doing it is a huge pain in the ass. so little space to work with.
but when you finish it, it feels good
the drls already turn off when the headlights are turned on....
Dr. BRZ is offline   Reply With Quote
Old 12-23-2013, 12:48 AM   #44
Lithium
Lithium's Avatar
Drives: like an asshat
Yes but if your "source wire" in his case being the DRL power will cause them to stay on unless a second set of diodes are placed in that source wire (which he did) to return the DRLs to a factory behavior. In others case including mine who didn't install that second set of diodes the DRLs stay on when the headlight HIDs turn on. You have two options with the DIY. One having the DRLs turn on all the time or have them turn off once the HIDs are on. The second set of Diodes determine this.
Lithium is offline   Reply With Quote
The Following User Says Thank You to Lithium For This Useful Post:
Trap63 (01-18-2014)
Old 12-23-2013, 12:49 AM   #45
Lithium
Lithium's Avatar
Originally Posted by FLYFISHR View Post
Is there a power source for the DRL's in the headlight harness that we couldtap into? instead of right at the DRL.
I imagine it could be. I didn't check the harness to be completely honest.
Old 12-29-2013, 11:29 PM   #46
lamptaco
Drives: 2014 BRZ
I just bought a 2014 and one click away from turning the headlights on turns both the DRLs and the horse shoe light on. Is that what you guys are trying to accomplish? Is it new to 2014s? I'm going to do this in order to keep the DRLs on when the headlights turn on
lamptaco is offline   Reply With Quote
Old 12-30-2013, 10:50 AM   #47
ktech
Drives: '13 BRZ Ltd, 6MT
This isn't what the thread is about - the tutorial is to tie the halos/horseshoes to the DRLs that are activated by disengaging the parking brake/shifting into gear. ETA: so we can leave our lights on auto.
Sent from my One using Tapatalk
ktech is offline   Reply With Quote
Old 01-17-2014, 05:36 AM   #48
Hachiroku14
Drives: 2014 BRZ World Rally Blue
did this today! Amazing writeup! had to add another diode to make it look stock when headlights are on. Now the automatic mode on the stalk makes more sense. Good job OP!
Hachiroku14 is offline   Reply With Quote
The Following User Says Thank You to Hachiroku14 For This Useful Post:
Lithium (01-18-2014)
Old 01-18-2014, 09:01 PM   #49
Lithium
Lithium's Avatar
Glad you got it working, would you say the install was difficult?
Hachiroku14 (01-19-2014)
Old 01-18-2014, 11:20 PM   #50
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Started this project tonight, but am going to have to finish tomorrow. I gotta say, this is way more difficult (and scary) than I thought it'd be. There's so little slack in any of the wires, I'm just afraid I'm not going to be able to get a nice clean solder, I've only done quick spot soldering so far. The main issue I have is that I got 12-gauge wire, per your instructions, and it's really thick compared to the stock wiring, so soldering them together is becoming a big pain....
Deathalo is offline   Reply With Quote
Old 01-19-2014, 07:44 AM   #51
Hachiroku14
Hardest part for me was wiring the anode...so little space....
Old 01-19-2014, 10:59 AM   #52
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
I did it to my car last night while the bumper was off. It makes it WAYYYY easier when the bumper is off.
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
Old 01-19-2014, 06:21 PM   #53
Deathalo
Finished it up today, wasn't able to check DRL though, sun was already going down and 'auto' just turned the headlights on. I did, however, see that the original DRL LED strips were still lit with the headlights on, so I guess it worked? I'll be able to check for sure tomorrow.
I finally was able to put enough solder on everything to get it all secure, doesn't look nearly as clean as yours, taping it up in that tight quarters was difficult and I wanted to make sure it was all covered. I noticed that the Diodes do not solder easily, I'd put a good solder on the wire and Diode, but the Diode would just slip in and out, had to really cover it and be careful handling.
Old 01-19-2014, 09:53 PM   #54
Lithium
Lithium's Avatar
It sounds like you might have been using rosin core solder which doesn't work as well as lead core.
Old 01-19-2014, 09:56 PM   #55
Lithium
Lithium's Avatar
I'm sorry you thought 12 gauge wire was difficult to work with, I actually suggested 18 gauge to 12 gauge wire for this project. Maybe I should be more specific next time. Glad to see you got the job done, congrats for accomplishing a difficult DIY!
Old 01-19-2014, 10:30 PM   #56
Deathalo
Used lead free electrical solder and flux for lead free solder. I'm not all that familiar with soldering specifics, so I obviously wouldn't have known, definitely my most challenging soldering job yet!
WTB Stock headlight projectors from retrofit OR a broken headlight official_george Exterior Parts (Aero, Lighting, Etc.) 3 12-02-2013 03:32 PM
Right headlight wont turn on Matt90 Issues | Warranty | Recalls / TSB 9 11-11-2013 03:56 PM
My turn. =( jonbonazza Scion FR-S / Toyota 86 GT86 General Forum 28 07-15-2013 02:57 PM
Voice Commands with new turn by turn in IOS6? jadewbj Electronics | Audio | NAV | Infotainment 0 09-21-2012 10:11 AM
