Old 01-17-2014, 08:26 PM   #1
Rio
Rio's Avatar
Drives: 2014 Scion FR-S ハチ
2014 FR-S Head Unit + Subwoofer
I have searched everywhere in the forum and I have not found a clean solution to this. My 2014 is in dire need of a sub-woofer (which I already have).
This newer head unit does not appear to have a sub Pre-out jack. I really do not want to start splicing wires on this head unit. So who has the wiring diagram? Has anyone figured out a clean way to install an amp+sub on a 2014? If so please share your knowledge in the topic.
Rio is offline   Reply With Quote
Old 01-17-2014, 10:04 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
theres a toyota HU plug that adds em, but i forgot where i read about it
lbroskee is offline   Reply With Quote
Old 01-17-2014, 10:19 PM   #3
Luis_GT
Buy this and repin them, then connect it to the plug on the rear trunk amp and splice into it.
[ame="http://www.amazon.com/Metra-70-1761-Wiring-Harness-Speaker/dp/B0002BEQJ8/ref=pd_bxgy_e_img_y"]Amazon.com: Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker: Car Electronics[/ame]
[ame="http://www.amazon.com/gp/product/B0074VDYXI/"]Amazon.com: Reverse Wiring Harness for 1987-2007 Toyota Lexus Scion Vehicles OEM Radio (71-1761): Car Electronics[/ame]
http://www.ft86club.com/forums/showthread.php?t=42239
Old 01-18-2014, 12:05 AM   #4
Rio
Rio's Avatar
Wiring diagram
Does anyone have the wiring diagram?
Old 01-18-2014, 12:13 AM   #5
Plxdjake89
Plxdjake89's Avatar
Drives: 2013 Scion FR-S-white out
Splice into the cables on the amp
Plxdjake89 is offline   Reply With Quote
The Following User Says Thank You to Plxdjake89 For This Useful Post:
Rio (01-18-2014)
Old 01-18-2014, 12:17 AM   #6
I have no idea if this will help .....
Old 01-18-2014, 12:22 AM   #7
Rio
Rio's Avatar
Does the BRZ have the same head unit?
Old 01-18-2014, 12:26 AM   #8
Plxdjake89
Plxdjake89's Avatar
Watch this YouTube video, this is exactly how I wired my sub amp
[ame]http://youtu.be/ma5s8GLOd7w[/ame]
Rio (01-18-2014)
Old 01-18-2014, 12:35 AM   #9
I donno ...... (not much help - huh .?)
Old 01-18-2014, 12:38 AM   #10
Rio
Rio's Avatar
This is not the same head unit :-(
Old 01-18-2014, 12:41 AM   #11
Plxdjake89
Plxdjake89's Avatar
Ok....but nobody said you were messing with the head unit itself. If you want a subwoofer, the easiest place to tap into is the amp in the trunk.
Old 01-18-2014, 12:49 AM   #12
Rio
Rio's Avatar
Ok, so I don't have to mess with the headunit then? That's even better! I still have not seen this trunk amp. I will take a look tomorrow morning. Thanks guys! I guess I was not paying attention.
Old 01-18-2014, 01:09 AM   #13
oldpueblo
oldpueblo's Avatar
Drives: Scion FR-S 10 #853
I literally just did this, it was actually easier than I thought once all the research was done. Just some trial and error on my part that you can skip by buying those two harnesses and splicing them instead of the actual stock wires. This thread should have all you need:
http://www.ft86club.com/forums/showthread.php?t=12010
TLDR just run a power cable from the battery to the back, then splice into the signal wires from the amp, already in the trunk. Easy peasy. Make sure you run a power cable strong enough to support what you want in the future, I settled on a 6 gauge cable from a $35 amp kit from walmart. Good value since similar amp kits were at least $80-$100 at Bestbuy but were only 8 gauge, etc.
oldpueblo is offline   Reply With Quote
Old 01-18-2014, 01:36 AM   #14
Rio
Rio's Avatar
Thank You Everyone!
You guys rock!
How to change the start up screen on 2014 head unit? Choob Electronics | Audio | NAV | Infotainment 9 08-03-2014 06:24 PM
BRZ Audio Overhaul - Subwoofer, Amp, Speakers, Head Unit Replacements NeoMarine Electronics | Audio | NAV | Infotainment 4 10-18-2013 09:23 PM
2013 FR-S with 2014 Head Unit Exorcized Electronics | Audio | NAV | Infotainment 5 09-09-2013 02:12 PM
2014 MY head unit details? watts? Pablitomarrero Electronics | Audio | NAV | Infotainment 1 06-17-2013 08:38 PM
