Old 01-08-2014, 07:46 PM   #113
Mr.EvoMR
Mr.EvoMR's Avatar
Drives: 2013 Scion Fr-s
Same shit here 4,900 miles on mine. I put the key in, turn it and it struggles to start for about 5-10 seconds then finally starts up. Happened to me a bunch of times in cold and hot weather...embarrassing at times, as it is a brand new car
Mr.EvoMR is offline   Reply With Quote
Old 01-08-2014, 07:55 PM   #114
jonbonazza
4500 miles and no start issues, even with a lightweight battery.
jonbonazza is offline   Reply With Quote
Old 01-08-2014, 08:09 PM   #115
FirestormFRS
Cars start precisely when they should. Really 5-10 seconds of cranking isn't a big deal.
FirestormFRS is offline   Reply With Quote
Old 01-08-2014, 08:21 PM   #116
Mr.EvoMR
Mr.EvoMR's Avatar
I hope so...but in the moment it feels and seems very abnormal. Car shakes a little, everything that lights up(speedometer, radio, a/c knobs, etc) kind of dampens as if there isnt enough power, then it starts and it runs fine..
Old 01-09-2014, 03:21 AM   #117
QuikSilveRX-8
QuikSilveRX-8's Avatar
Drives: SE3P
Check and clean the terminals. would be wise to check what is the Cold Cranking Amps of the battery, as well.
Three moving engine parts, yet complicated... Or do I mean complex?
QuikSilveRX-8 is offline   Reply With Quote
Old 01-09-2014, 06:58 AM   #118
Muskokan
Drives: white Sport-tech
This happened once in the fall to me, 2nd try was good. Maybe a total of 10 seconds of crank before she turned over. I don't think it's the cold because it's been consistently under -25 here and hasn't happened since. Mt limited.
Muskokan is offline   Reply With Quote
Old 01-17-2014, 09:11 PM   #119
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Had the car over a year now and it would rarely have an issue where it would take a couple extra cranks and stutter in low rpms at start up before moving up to normal levels. It only happened occasionally. Although now with this cold weather it's been doing it frequently. Yesterday and today it took three tries, strong cranks but no start until the third try, and very stuttery.
Nevermore is offline   Reply With Quote
Old 01-17-2014, 11:26 PM   #120
You aren't pushing on the gas pedal before cranking, out of habit, are you .. ??
You might try changing gas stations (or at least pumps).
Old 01-17-2014, 11:41 PM   #121
AVodka14
AVodka14's Avatar
Drives: 2013 Raven FRS MT
Originally Posted by Bristecom View Post
The Evo X came with those same Panasonic batteries and we had problems starting almost every car with them. When we replaced them with an Optima battery, the problem was solved. I'm not sure if it really is the battery but having worked for a dealer that dealt with those batteries, I wouldn't be surprised.
I have an original Panasonic battery in my 2005 tC. Yeah, it is a 9 year old battery. Even had no problems firing up the car last week during the Polar Vortex.
Just an FYI that not all Panasonic batteries perform poorly.
AVodka14 is offline   Reply With Quote
Old 01-17-2014, 11:43 PM   #122
AVodka14
AVodka14's Avatar
My FRS has done this once. I think it's something electronic in nature. Not mechanical.
Old 01-18-2014, 02:39 PM   #123
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Never touch the gas when starting the car. I did put some shell v power in it just to see. I'm sitting at the dealership to get a diagnosis too.
The Following User Says Thank You to Nevermore For This Useful Post:
humfrz (01-18-2014)
Old 01-18-2014, 02:49 PM   #124
sofrsnsokleen
GEARS!!???
sofrsnsokleen's Avatar
Drives: raven black 2013 scion fr-s
Location: the southeast side of san antonio, where the players play!
It actually happened to me as well yesterday. I drive an auto as well. It'd happened a good while back too. I think it happens when you don't turn the ignition to where the needles flick on first and then crank it. i admit i started it really quickly yesterday, when normally i let the injectors prime first.
sofrsnsokleen is offline   Reply With Quote
Old 01-18-2014, 02:55 PM   #125
stugray
Drives: 2013 GBS BRZ Limited
This has never happened to me and I have BRZ w/ push button start and 15000 miles.
It starts every time in less than 2 seconds even when -20deg F outside.
And for those thinking that holding the pedal down might cause it to flood: This car is drive by wire.
The ECU likely ignores the position of the gas pedal until the engine is out of the "start state".
If the engineers did not write the code to work this way, they they should be fired.
The Following User Says Thank You to stugray For This Useful Post:
humfrz (01-18-2014)
Old 01-18-2014, 04:47 PM   #126
Nevermore
Wayward Member
Nevermore's Avatar
Drives: Hot Lava 86
Dealership found nothing wrong. The tech suggested a fuel intake cleaner but was hesitant to endorse it fully because he wasn't sure how it would work on a boxer engine. Thoughts?
After Market Problem Signals Fuse Popped- Car Wont Go into Gear ScionFR-S Issues | Warranty | Recalls / TSB 14 11-20-2012 02:34 PM
Car Won't Start schtebie Issues | Warranty | Recalls / TSB 25 10-15-2012 04:06 PM
trunk wont unlatch bakerr6 Issues | Warranty | Recalls / TSB 9 09-24-2012 01:32 AM
GTS come with push start? adam AUSTRALIA 13 06-04-2012 03:28 AM
Car won't start, no spark? #87 Other Vehicles & General Automotive Discussions 5 12-19-2011 12:29 PM
