Old 01-14-2014, 07:35 PM   #267
sklimo
In the sc vs sc thread I think it shows what you're looking for
Old 01-17-2014, 06:47 PM   #268
mad_sb
Drives: 2013 Asphalt FR-S
I don't think my question was covered in the SC vs SC thread, then again i did not read every page of it.
Old 01-17-2014, 07:12 PM   #269
CSG Mike
CSG Mike's Avatar
Originally Posted by mad_sb View Post
So, i was under the impression that the benefit of a rotrex unit would be that you could spin up the compressor earlier than with say a Vortech to get boost down low and then limit the boost up top by using inlet restrictors.... I'm not seeing that in this application though... it seems the rotrex units are not making any more boost down low than the vortech units.... this is based on the dyno plots (power output) i have seen, not actual boost plots...
Is it possible that with a larger impeller and a smaller inlet we could get the best of both worlds with more boost and torque down low without "over" boosting up top?
I am asking as a prospective customer of one of the rotrex kits, not as a fanboi of one of the other options.
Yes, you can via restrictor, but it has not been engineered in this application, since it's not necessary, and the Rotrex is already being spun up to about 90% capacity.
mad_sb (01-20-2014)
Old 01-17-2014, 07:18 PM   #270
DJCarbine
Thupercharged
DJCarbine's Avatar
The traction drive gearbox is what makes it possible, the rotrex units have a non-newtonian fluid (as far as I know) which allows greater "traction" of the fluid and enhances low RPM/High load operation so the speed of the impeller is quicker than it SHOULD be than if the fluid was not under so much load.
This means instead of a impeller RPM plot that has a constant state of rise, you actually get a speed plot that is a bit "fatter" in the lower speed range and performs better than traditional helical/straight gear direct drive. This is also why the rotrex has oil reservoirs, I believe the nature of the friction drive generates heat.
This is how I understand it, I could be completely wrong... its very interesting operation
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 01-17-2014, 07:21 PM   #271
CSG Mike
CSG Mike's Avatar
"the Rotrex traction drive uses a special traction fluid. These fluids are a new family of synthetic hydrocarbon oils and greases offering a series of unique performance advantages. Developed specially for its use in Rotrex superchargers, the traction fluid momentarily increases viscosity under high surface pressure, enhancing the traction drive performance by securing the optimum friction between rolling elements while cooling and protecting the system."
Sounds non-newtonian to me.
Old 01-17-2014, 07:53 PM   #272
Sellout
Mr. Cranky Pants
Sellout's Avatar
Drives: 2013 Argento FR-S
Sounds a whole lot like the clever wording I referred to in another thread on the subject of Rotrex units. That "fatter midrange", that the Rotrex customers-to-be always reference when discussing their reasoning, amounts to what? 3 ft lbs?
If the Vortech kit was limited to the same amount of airflow that the Rotrex kits are, I suspect that the boost curves and midrange power would be identical. It damn near is now.
Sellout is offline   Reply With Quote
Old 01-17-2014, 08:38 PM   #273
Calum
That Guy
Drives: 2013 asphalt FRS MT
It's a planetary gear system, not a fluid coupling. I'm pretty sure Mike hit the nail on the head, non-newtonian.
Old 01-17-2014, 09:06 PM   #274
DJCarbine
Thupercharged
DJCarbine's Avatar
I think they use a planetary traction drive, which has no gears
2013 FRS
Vortech V3 11psi
Old 01-17-2014, 11:34 PM   #275
lfuentes92
master boxxy driver
lfuentes92's Avatar
Noob question here and probably ignorant can a aftermarket bov be put into this setup I know it uses a recirculating valve but for my personal joy I would like a louder bov would this be possible again I apologize for my lack of knowledge
Sent from my SM-N900P using Tapatalk
lfuentes92 is offline   Reply With Quote
Old 01-18-2014, 01:55 AM   #276
CSG Mike
CSG Mike's Avatar
Yup. Make sure your tuner is aware of the BOV.
lfuentes92 (01-18-2014)
Old 01-18-2014, 02:09 AM   #277
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
It has to be placed before the MAF as well correct?
shaunsweeney is offline   Reply With Quote
The Following User Says Thank You to shaunsweeney For This Useful Post:
Old 01-18-2014, 07:37 AM   #278
Calum
That Guy
I stand corrected. I thought it was just marketing hype, but they actually did make a new design.
Old 01-18-2014, 01:14 PM   #279
Sellout
Mr. Cranky Pants
Sellout's Avatar
Yeah their drive system is cool. The only problem with it is that it's not really explained well to the people on internet forums...
Old 01-18-2014, 01:44 PM   #280
Calum
That Guy
Care to expand on it then? I'd love to know more about what they're doing and how it works. I thought about searching for the patent, but laziness took hold. Well, that and the hangover.
The Following User Says Thank You to Calum For This Useful Post:
Sellout (01-18-2014)
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
