go_a_way1
Old 01-16-2014, 11:55 PM   #3067
schmearcampain
Drives: 2014 Argento FRS 6MT
Originally Posted by Luckrider View Post
I was on my way home today thinking about the Phantom ESC and I propose an official name for this type of technology. Turbochargers are gas driven turbines from the exhaust of the engine. Superchargers are mechanical turbines powered by output shafts or belts of the motor. The Phantomcharger is an electrically driven turbine.
Phan·tom·charg·er
noun
1.
a turbine compressor driven by (an) electrical motor(s).
Edit: Another thing I realized was that turbo super and phantom are all two syllable words.
Electrocharger.
schmearcampain is offline   Reply With Quote
Old 01-17-2014, 12:42 AM   #3068
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Post MOAR! Let's get a poll and come up with an official name for this damn technology.
Luckrider is offline   Reply With Quote
Old 01-17-2014, 11:25 AM   #3069
Urmyson
Originally Posted by jpit View Post
I'll be upgrading to four batteries as soon as I receive the new controller and harness. I will be moving the starter battery to the trunk and am now working on locations to install it. Rob believes that this will increase pressure by over 1/2 psi through the entire range. That is the neat thing about the esc being able to upgrade without too much investment. There is nothing more I can add to the normal set-up other than the fact that you forget that you have installed --- until you floor it and the car takes off like a jack rabbit.
Would a big 24v Deep cycle(Like one for a trolling motor) be easier than the little batteries? I would think it would have more juice and deep cycle's are designed to be depleted a lot. What are your thoughts?
Urmyson is offline   Reply With Quote
Old 01-17-2014, 11:29 AM   #3070
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
So the system can handle 48 volts? And how does the controller and motor handle this? Also Rob if you need someone to test out the tq 300 after @shiv@vishnu tunes for it I can always help. .
Installed Mods:
Old 01-17-2014, 11:39 AM   #3071
fenton
I think he is referring to something like I have. Two 24v dump packs wired together not for 48v bit for more lead at 24v.
Right now I have the standard 2 batteries plus 2 small additional batteries that increase capacity by 50percent. I'm guess that he is relocating his starter so that he can put 4 big ones in and increase total capacity by 100 percent.
Sent from my HTC One using Tapatalk
fenton is offline   Reply With Quote
Old 01-17-2014, 11:39 AM   #3072
Urmyson
Wouldn't you run them in parallel for more capacity?
Old 01-17-2014, 11:42 AM   #3073
Sojhinn
Sojhinn's Avatar
Full throttle Electric Supercharger Build Thread
Interesting. And thank you for the clarification. Would be fun to see the difference on the dyno.
Installed Mods:
Old 01-17-2014, 11:50 AM   #3074
fenton
More lead keeps the load more stable. There is usually about .25 to .5 psi more when increasing the reserve capacity. This resulted in about 5 HP more on the tq250 when we were testing earlier.
The extra capacity is a requirement for the tq300 system because it draws a extra 1000 watts.
Old 01-17-2014, 11:52 AM   #3075
Sojhinn
Sojhinn's Avatar
Were you able to put all the batteries in the engine bay? And I'm assuming the tq 300 would benefit from the larger battery setup.
Installed Mods:
Old 01-17-2014, 11:53 AM   #3076
jpit
Drives: Subaru BRZ
Rob is putting together the harness and I assume the batteries are wired in parallel and not series - so we should still see 24 volts. Should have some results tomorrow. The four batteries will fit with a new battery tray but I have to move the starter battery to the trunk area. Don't mind this as it spreads out the extra weight a little.
jpit is offline   Reply With Quote
Old 01-17-2014, 12:04 PM   #3077
fenton
Yes you are. You can see the two small batteries in the middle between the larger starter battery and the original dump pack batteries. They are half the size of the original two dump batteries.
Only problem is the wiring gets a little convuluted unless you take a lot of car routing it.....which in my car we did not.
What you see is the largest starting battery plus a 50 percent reserve capacity add on plus 2 reachargers.Name:  uploadfromtaptalk1389974564429.jpg
Old 01-17-2014, 12:06 PM   #3078
Sojhinn
Sojhinn's Avatar
What you see is the largest starting battery plus a 50 percent reserve capacity add on plus 2 reachargers.Attachment 63929
Damn that's huge. (That's what she said) thanks for the heads up guys.
Installed Mods:
Old 01-17-2014, 12:46 PM   #3079
Robftss
Drives: VW
Vs. stock battery
2" longer
9 lbs heavier
PC 925 to be trunk mounted (25lbs)
Robftss is offline   Reply With Quote
The Following 2 Users Say Thank You to Robftss For This Useful Post:
DAEMANO (01-18-2014), Gums (01-17-2014)
Old 01-17-2014, 12:46 PM   #3080
Sojhinn
Sojhinn's Avatar
Originally Posted by Robftss View Post
Attachment 63932
Vs. stock battery
2" longer
9 lbs heavier
I've never run a battery to the trunk. How hard is it?
Installed Mods:
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
