go_a_way1
Old 01-16-2014, 10:14 AM   #3053
fenton
Originally Posted by VR46 View Post
We're coming up pretty quick on late January - how's it looking?
I have talked to Rob quite a bit this week. Last i heard he had everything EXCEPT the specially machined compressor wheels. Once he gets those he will have to verify they are machined to spec, assemble the kits and bench test.
We are getting close folks, I believe Rob has been in talks with the forum to get a Vendor account as well.
The only setback that i know of is these compressor wheels were supposed to be here at the begining of January.
fenton is offline   Reply With Quote
The Following 5 Users Say Thank You to fenton For This Useful Post:
DAEMANO (01-16-2014), Gums (01-17-2014), Pug (01-17-2014), SloS14 (01-16-2014), VR46 (01-16-2014)
Old 01-16-2014, 11:51 AM   #3054
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Old 01-16-2014, 04:03 PM   #3055
Sojhinn
Lightning McQueen Driver
Sojhinn's Avatar
Drives: Limited Red 6MT BRZ
Is @shiv@vishnu getting a 250 or 300?
Installed Mods:
The Following User Says Thank You to Sojhinn For This Useful Post:
Target70 (01-16-2014)
Old 01-16-2014, 04:04 PM   #3056
Sojhinn
Sojhinn's Avatar
Also, Rob I'm assuming you got my old controller by now. Did you discover anything weird on the pressure sensor?
Installed Mods:
Old 01-16-2014, 06:02 PM   #3057
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
This just in: German Shepherds like boost
Shiv@Openflash is offline   Reply With Quote
The Following 6 Users Say Thank You to Shiv@Openflash For This Useful Post:
Account Attempt No. 4 (04-13-2014), clintavo (01-17-2014), DAEMANO (01-17-2014), normancw (01-17-2014), Robftss (01-16-2014), s2d4 (01-17-2014)
Old 01-16-2014, 06:03 PM   #3058
Sojhinn
Sojhinn's Avatar
Did you get both?
Installed Mods:
Old 01-16-2014, 06:06 PM   #3059
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
Luckrider is offline   Reply With Quote
Old 01-16-2014, 06:19 PM   #3060
fenton
Originally Posted by Sojhinn View Post
Did you get both?
Ya Rob has said he was sending both to shiv.
Sent from my HTC One using Tapatalk
Old 01-16-2014, 06:21 PM   #3061
Sojhinn
Sojhinn's Avatar
Sweet that means I get to roll in the tq 300 soon. Shiv may be coming down to san diego to dyno.
Installed Mods:
Old 01-16-2014, 07:19 PM   #3062
jpit
Drives: Subaru BRZ
I'll be upgrading to four batteries as soon as I receive the new controller and harness. I will be moving the starter battery to the trunk and am now working on locations to install it. Rob believes that this will increase pressure by over 1/2 psi through the entire range. That is the neat thing about the esc being able to upgrade without too much investment. There is nothing more I can add to the normal set-up other than the fact that you forget that you have installed --- until you floor it and the car takes off like a jack rabbit.
jpit is offline   Reply With Quote
The Following 2 Users Say Thank You to jpit For This Useful Post:
DAEMANO (01-18-2014), Robftss (01-16-2014)
Old 01-16-2014, 07:22 PM   #3063
Robftss
Drives: VW
F.O.D from modifying the sensor to fit in the smaller control/charger unit...The new 5kW unit has a better arrangement.
wheels tic-toc!
Robftss is offline   Reply With Quote
Old 01-16-2014, 11:32 PM   #3064
schmearcampain
Drives: 2014 Argento FRS 6MT
Noob questions.
I checked out the install .pdf and it says to remove the air intake resonator. Why? Looks like the unit would fit with it still in place.
Also, why is there a resonator in the first place? To make the car sound a certain way?
What about if you wish to return the car back to stock, will eliminating the resonator have any effect? Will it void the warranty?
Thanks.
schmearcampain is offline   Reply With Quote
Old 01-16-2014, 11:43 PM   #3065
fenton
Originally Posted by schmearcampain View Post
Noob questions.
Thanks.
The intake has to be removed because there is a resonator attached to the side of the intake box that gets in the way of the compressor. You have to drill the rivits and remove the resonator. After that you just cap the hole where the resonator was. Rob includes a cap for this. This doesnt change anything at all with how the car drives or how it sounds(so far as I and others can tell....its actually a common mod to remove all the resonators). There are a bunch more resonators on the actual intake tube as well. For the most part people do not know what these do...
Removing the resonator will not void the warranty.
The Following User Says Thank You to fenton For This Useful Post:
schmearcampain (01-16-2014)
Old 01-16-2014, 11:44 PM   #3066
Luckrider
Luckrider's Avatar
I was on my way home today thinking about the Phantom ESC and I propose an official name for this type of technology. Turbochargers are gas driven turbines from the exhaust of the engine. Superchargers are mechanical turbines powered by output shafts or belts of the motor. The Phantomcharger is an electrically driven turbine.
Phan·tom·charg·er
noun
1.
a turbine compressor driven by (an) electrical motor(s).
Edit: Another thing I realized was that turbo super and phantom are all two syllable words.
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras Circuit Motorsports Member's Car Journals 4 03-21-2013 05:45 PM
Subaru BRZ : Full Throttle, powerslide, hard revving & ride ESBjiujitsu BRZ Photos, Videos, Wallpapers, Gallery Forum 20 05-30-2012 07:43 PM
86 Full Throttle Video + another. Aus86 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 2 04-02-2012 08:07 AM
