Old 01-14-2014, 01:52 PM   #253
Sonolin
I can give you a rough speculation, if you give me a pulley size and redline.
It would be strictly a best guess, and assuming nothing else breaks, but it'll be fairly accurate.
Thanks Mike, I'm unsure of the pulley sizes but mostly just anticipating 3rd party dynos/videos.
Sonolin is offline   Reply With Quote
Old 01-14-2014, 03:35 PM   #254
Mad1723
Mad1723's Avatar
Drives: Asphalt FR-S
Few questions about the oil: The oil cooler is for the supercharger oil only I am guessing?
Also, what is the minimum temperature of that oil? The reason I ask this is because I drove my car in the snow this year and I should not have to next year, but some people in QC are getting such a kit and I was wondering if it was useable in our cold north temperatures! At what kind of temperatures do we need to preheat the oil before getting it started?
Thanks!
Mad1723 is offline   Reply With Quote
Old 01-14-2014, 03:38 PM   #255
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Thanks!
The oil cooler everyone is speaking of is for "engine oil"
The Rotrex has it's own included oil cooler.
Old 01-14-2014, 03:47 PM   #256
Mad1723
Mad1723's Avatar
So there is an oil cooler for the engine oil included in the kit? That makes it a great deal if so!
Sent from my SGH-T999 using Tapatalk
Old 01-14-2014, 04:07 PM   #257
OICU812
Just a dude
OICU812's Avatar
No that is coming however and I expect it'll be extra.
Old 01-14-2014, 04:07 PM   #258
Mad1723
Mad1723's Avatar
Ok! Hopefully it'll be available by the time I order my kit
Old 01-14-2014, 04:14 PM   #259
CSG Mike
CSG Mike's Avatar
Thanks!
It's for the supercharger.
The kit was tested in Colorado winters, which may or may not be comparable.
As for minimum temp for the Supercharger oil.... -40°C (-40°F) per Rotrex. Is that cold enough for ya?
There will be an engine oil cooler available from Jackson Racing that is modular with the Supercharger kit.
Old 01-14-2014, 04:20 PM   #260
Mad1723
Mad1723's Avatar
Thanks a lot! That clears things up nicely! I was asking about the oil because the Vortech had a problem where they didn't recommend using the system under a certain temperature that was very common in Quebec during winter. We don't get -40°c that often, so it should not be an issue for winter driving.
Is there an ETA for the dual oil cooler system or is it still in a development stage and it's a "when it's ready"?
Old 01-14-2014, 04:30 PM   #261
CSG Mike
CSG Mike's Avatar
Approximately "within a month", but no promises.
Old 01-14-2014, 04:33 PM   #262
Mad1723
Mad1723's Avatar
Which is excellent, since I'm planning on getting this after all my trainings in Germany during spring. I'll only consider it for this summer, so fine by me It'll give time to iron out the first release bugs for that new cooler and to get my finances ready
Thanks for the info Mike! Really appreciated
Also, will you be installing their oil cooler on your CSG BRZ? Because if so, I can't wait for the pictures and your impressions on it!
Old 01-14-2014, 04:39 PM   #263
CSG Mike
CSG Mike's Avatar
Yes, we'll be testing the oil cooler when it's ready, since it requires ZERO fab work to work with the supercharger on our car.
Old 01-14-2014, 04:49 PM   #264
OICU812
Just a dude
OICU812's Avatar
Oooooops that me bad thought we were speaking of a OC for engine by Jackson as I was speaking to Oscar Juniour he was saying they were making a bolt in OC to accommodate this kit.
Old 01-14-2014, 05:11 PM   #265
CSG Mike
CSG Mike's Avatar
They are
Old 01-14-2014, 07:04 PM   #266
mad_sb
Drives: 2013 Asphalt FR-S
So, i was under the impression that the benefit of a rotrex unit would be that you could spin up the compressor earlier than with say a Vortech to get boost down low and then limit the boost up top by using inlet restrictors.... I'm not seeing that in this application though... it seems the rotrex units are not making any more boost down low than the vortech units.... this is based on the dyno plots (power output) i have seen, not actual boost plots...
Is it possible that with a larger impeller and a smaller inlet we could get the best of both worlds with more boost and torque down low without "over" boosting up top?
I am asking as a prospective customer of one of the rotrex kits, not as a fanboi of one of the other options.
jackson racing, jrsc, rotrex, supercharger, track
Kraftwerks Rotrex Supercharger Discussion nelsmar Forced Induction 697 01-18-2022 12:06 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
Jackson Racing FR-S Unleashed FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 3 11-18-2012 02:29 PM
