#43 | |
Drives: 2016 STi DGM
But, it Sounds like sc is for you. I knew I wanted to go SC, so I didn't mind buying header(s) and other mods way before going SC. It'd even been a big waste of $ if I would have gone turbo. Just depends what you want and what power you're looking to put down and of course, $.
-2014 SSM BRZ MT
#45 | |
Drives: 06 spec b
I'm going to keep it NA and see how it drives when I push it to its limits before I upgrade to FI. Once its payed off in a couple years, then the fun begins ! ![]() But in the meantime, I do need to find people around me that have a s/c and turbo frs/brz to ride shotgun in. |
#46 |
Drives: 2008 Toyota Prius, 2012 911 Turbo
#47 | |
Drives: 2014 FR-S MT Asphalt Grey
#48 |
I wouldn't have minded trying out all systems but JR rotrex was way to go.
-2014 SSM BRZ MT
#49 | |
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
#50 |
Drives: Subaru BRZ Limited
Ohhh. I'm completely clueless about this stuff. So when you say Turbos can be sized, what do you mean? Do you mean 1 turbo can be adjusted to spool either at low or high rpm's? Or that different turbos come in different sizes depending on what you want, i.e. Small turbo spools low, and large turbo spools high? Lol. I'm sure that sounds super noob, but I'll never learn unless I ask!
#51 | |
Turbos are powered by exhaust gas. Large turbos need higher RPMs because the engine is pumping more air at higher revs. On the new Subaru Forester XT and WRX they are using a fairly small twin-scroll turbo and the turbo makes full torque at 2800RPM. It spools pretty much instantly since due to the design and size it doesn't need as much exhaust gas to spool and create boost pressure. As for the whole SC vs. Turbo argument, it's generally easier to make more power these days with turbos. That's why even though they are probably a little more complex than a SC every OEM uses turbos. If you look at a turbo kit like the AVO one which uses a smaller turbo right off the header it makes more torque at low RPMs than any supercharger does, but there is always going to be the 1/4-1/2 second on/off throttle delay while it spools back up versus the instant response of the SC. |
| The Following User Says Thank You to xwd For This Useful Post: | ericmpena (01-12-2014) |
#52 |
Twin scroll is what I plan on running in the same location as AVO. Should be a fun project when I'm ready.
#53 | |
Drives: VW
#55 | |
Thupercharged
In the end there is no wrong choice IMO
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
| Tags |
| terbo? |
| Supercharger vs Turbo MPG ? | LoCo | Forced Induction | 23 | 06-27-2015 05:24 PM |
| Turbo or supercharger | dparnell | Southeast | 7 | 11-07-2013 02:40 PM |
| HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! | rickspecd | Forced Induction | 4 | 07-12-2013 11:50 AM |
| supercharger or turbo? | RussellRockets | Forced Induction | 137 | 11-28-2012 06:54 AM |
| Looking for a Frs for R&D on a turbo and supercharger | Toxic | Forced Induction | 38 | 10-23-2012 03:13 PM |
