Old 01-12-2014, 09:43 AM   #43
ramiram1984
Drives: 2016 STi DGM
Originally Posted by ericmpena View Post
I wish I could just drive both a SC and Turbo car so I could decide as well. At first I was leaning towards SC, but then I got so much crap about how you get more bang for your buck with a Turbo, so Idk.
Personally, 98% of my driving is below 4,000 RPMs. Maybe I'm just too careful with my car, but I rarely push it when on public roads...which is 100% of the time because I've never tracked my car. lol.
If that's the case, SC would be a better option since I believe SC's give better low end torque? Turbos work better when you're reved higher, yes? Or maybe I'm all wrong about that.
Personally I'd prefer to keep most of the stock parts when it comes to the engine. I don't want to add this and that along with a SC or Turbo in order to make it work. I just want to be as simple as possible and install it and get results. Is that not possible? Or if it is, would that be a SC or Turbo?
I too usually drive between 3-4k. Punch it or downshift now that am FI. And I'm avg about 30.1 mpg.
But, it Sounds like sc is for you. I knew I wanted to go SC, so I didn't mind buying header(s) and other mods way before going SC. It'd even been a big waste of $ if I would have gone turbo.
Just depends what you want and what power you're looking to put down and of course, $.
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following 2 Users Say Thank You to ramiram1984 For This Useful Post:
ericmpena (01-12-2014), otterpop (02-16-2015)
Old 01-12-2014, 11:28 AM   #44
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by spc2125 View Post
Well this thread has swayed me towards a SC than turbo
Well yeah it will do that to anyone that hasn't already lost their mind to "More Powwwaaaaa!"
The Following User Says Thank You to Kiske For This Useful Post:
spc2125 (01-12-2014)
Old 01-12-2014, 12:09 PM   #45
spc2125
Drives: 06 spec b
I've gone from wanting to turbo it, to keeping it NA, to supercharging.... and I dont even have one yet !! (Late April is my window)
I'm going to keep it NA and see how it drives when I push it to its limits before I upgrade to FI. Once its payed off in a couple years, then the fun begins !
But in the meantime, I do need to find people around me that have a s/c and turbo frs/brz to ride shotgun in.
spc2125 is offline   Reply With Quote
Old 01-12-2014, 12:47 PM   #46
LBC Por Siempre
LBC Por Siempre's Avatar
Drives: 2008 Toyota Prius, 2012 911 Turbo
Originally Posted by ecko04 View Post
I sit on the toiletlmao
No pun intended?
LBC Por Siempre is offline   Reply With Quote
Old 01-12-2014, 01:50 PM   #47
shaunsweeney
shaunsweeney's Avatar
Drives: 2014 FR-S MT Asphalt Grey
Sounds like you would both really enjoy a twin scroll turbo as well.
shaunsweeney is offline   Reply With Quote
Old 01-12-2014, 01:58 PM   #48
ramiram1984
I wouldn't have minded trying out all systems but JR rotrex was way to go.
-2014 SSM BRZ MT
Old 01-12-2014, 02:15 PM   #49
mid_life_crisis
Drives: FR-S 10 #103 AT
You have it backwards. Superchargers are tied to engine rpm, so they don't build boost as well until the rpm climbs. Turbos can be sized to spool and make power at low rpms.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 01-12-2014, 02:34 PM   #50
ericmpena
ericmpena's Avatar
Drives: Subaru BRZ Limited
Ohhh. I'm completely clueless about this stuff. So when you say Turbos can be sized, what do you mean? Do you mean 1 turbo can be adjusted to spool either at low or high rpm's? Or that different turbos come in different sizes depending on what you want, i.e. Small turbo spools low, and large turbo spools high? Lol. I'm sure that sounds super noob, but I'll never learn unless I ask!
ericmpena is offline   Reply With Quote
Old 01-12-2014, 04:33 PM   #51
xwd
The short answer is "yes".
Turbos are powered by exhaust gas. Large turbos need higher RPMs because the engine is pumping more air at higher revs.
On the new Subaru Forester XT and WRX they are using a fairly small twin-scroll turbo and the turbo makes full torque at 2800RPM. It spools pretty much instantly since due to the design and size it doesn't need as much exhaust gas to spool and create boost pressure.
As for the whole SC vs. Turbo argument, it's generally easier to make more power these days with turbos. That's why even though they are probably a little more complex than a SC every OEM uses turbos. If you look at a turbo kit like the AVO one which uses a smaller turbo right off the header it makes more torque at low RPMs than any supercharger does, but there is always going to be the 1/4-1/2 second on/off throttle delay while it spools back up versus the instant response of the SC.
The Following User Says Thank You to xwd For This Useful Post:
Old 01-12-2014, 04:52 PM   #52
shaunsweeney
Twin scroll is what I plan on running in the same location as AVO. Should be a fun project when I'm ready.
Old 01-13-2014, 04:43 PM   #53
Robftss
Drives: VW
It seems OEM's use turbos and PD supers to increase torque at more useable rpms...kinda the opposite of what centri's do.
Robftss is offline   Reply With Quote
Old 01-13-2014, 06:28 PM   #54
shaunsweeney
The more I look at them the less I like centrifugal sc. Too much of a compromise IMHO.
Old 01-13-2014, 07:11 PM   #55
DJCarbine
Thupercharged
DJCarbine's Avatar
Not for everybody. Used to have a turbo car so I have some frame of reference....
In the end there is no wrong choice IMO
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
terbo?
Supercharger vs Turbo MPG ? LoCo Forced Induction 23 06-27-2015 05:24 PM
Turbo or supercharger dparnell Southeast 7 11-07-2013 02:40 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
supercharger or turbo? RussellRockets Forced Induction 137 11-28-2012 06:54 AM
Looking for a Frs for R&D on a turbo and supercharger Toxic Forced Induction 38 10-23-2012 03:13 PM
