View Poll Results: Which wheel would best meet my needs in the first post?
Enkei Racing RP03s 11 33.33%
Kosei K1 TSes 3 9.09%
Kosei K4Rs 19 57.58%
Voters: 33. You may not vote on this poll
Old 01-11-2014, 05:37 PM   #1
TheLaughingMan
TheLaughingMan's Avatar
Question Enkei RP03 vs Kosei K4R vs Kosei K1 TS
I've decided after much research to finally go with some 17x8 wheels. I'd prefer that in the end the wheel/tire combo be lighter than stock. I plan on using these as my daily driver/spirited driving/occasional track set, and put snow tires on the stock wheels for winter.
I've also decided on 225/45R17 Dunlop Direzza ZIIs...I think. I am less solid on this one because despite trying to read about the pros/cons of different tire sizes, I still only have a rough understanding at best. I realize that particular tire size is not very different from the stock, but should give more grip and better response? I could go wider...but that would be more weight and I'm not sure I'd really use that extra width.
Finally, onto the wheels... I've come down to three: The Enkei Racing RP03s, Kosei K1 TSes, and the Kosei K4Rs. The Koseis win in terms of being the lightest at 15.5lbs and 15.8lbs respectively. They are also cheaper. The Enkeis are 17.9 lbs which is a little heavier on each corner, but I'm wondering if that also means stronger? Since I'm going to be using these as my daily driver wheels, I'd prefer they not bend at the tiniest bump.
Thoughts? Anyone with experiences with these wheels (or tires for that matter) care to share?
Enkei Racing RP03
Kosei K1 TS
Kosei K4R
TheLaughingMan is offline   Reply With Quote
Old 01-11-2014, 06:22 PM   #2
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
chulooz is offline   Reply With Quote
Old 01-11-2014, 06:27 PM   #3
fatoni
the k4r is probably the best in terms of performance and price but i think they are ugly.
Old 01-11-2014, 06:59 PM   #4
swilliams
swilliams's Avatar
Drives: 13 WRB BRZ
I plan on going 17x8, as well, but I'm leaning towards Pilot Super Sports. I have Direzza Z1 Star Specs (which are fairly worn) on my M3 and they are very noisy but grip very well. Unless the ZIIs have improved wet performance over the ZIs, I'm not convinced they are the safest for daily driving.
I think the K4Rs look the best from your options. No experience with any. They don't look too small and I'm a fan of gunmetal/grey on this car. I added them to my shortlist.
swilliams is offline   Reply With Quote
Old 01-11-2014, 10:30 PM   #5
TheLaughingMan
Originally Posted by chulooz View Post
added
also I'm less asking about aesthetics and more about safety and performance (although I do appreciate your opinions as well)
Old 01-11-2014, 10:47 PM   #6
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I would go for the Enkei wheels.
Originally Posted by humfrz
I'm old and lazy
Old 01-11-2014, 11:19 PM   #7
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
do you not like RPF1's?
out of those....looks wise, i like the K4Rs actually
SoCal909 is offline   Reply With Quote
Old 01-12-2014, 12:06 AM   #8
chulooz
Registered you sir
chulooz's Avatar
The weight and strength (performance and safety) are so close that unless you are a champion racer the differences will not make a difference. Nor will you be able to notice. Thus, the only thing that really matters is which set you prefer to look at. Tires will be your real performance-setting purchase. Good luck.
Old 01-12-2014, 12:20 AM   #9
Apoc
Apoc's Avatar
Drives: Raven FR-S 6M
I have Kosei K4R.
“The World is Flat”
[||•]=(86)=[•||]
Apoc is offline   Reply With Quote
Old 01-12-2014, 01:04 AM   #10
TheLaughingMan
Originally Posted by Apoc View Post
I have Kosei K4R.
what are those wrapped in?
square setup?
Old 01-12-2014, 01:05 AM   #11
TheLaughingMan
would the kosei rims bend easier being lighter?
Old 01-12-2014, 01:37 AM   #12
chulooz
Registered you sir
chulooz's Avatar
No. Not necessarily at least. I believe all 3 are cast wheels thus their relative strength will be similar. Certain mishaps will bend even the finest forged wheels.
The Following User Says Thank You to chulooz For This Useful Post:
TheLaughingMan (01-12-2014)
Old 01-12-2014, 02:39 AM   #13
Apoc
Apoc's Avatar
square setup?
235/40/17 Sumitomo HTR Z II all around. They are seriously cheap.
“The World is Flat”
[||•]=(86)=[•||]
Old 01-12-2014, 08:13 AM   #14
Captain Insano
I really like the K4Rs look and weight. I've thought about getting them for my winter wheels.
Captain Insano is offline   Reply With Quote
enkei, k1ts, k4r, kosei, rp03
Wheel Directory: Kosei K4R 17x8.0 +36 Vracer111 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 59 05-01-2017 11:39 AM
Is anyone using Kosei K4R 17x8 +36 wheels? Dave-ROR Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 19 02-02-2015 02:09 PM
Kosei K4Rs vs Enkei Racing RPF1 Metallic BRZ Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 25 10-21-2014 04:02 PM
Kosei TS EUrope Skurj Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 02-28-2013 09:30 PM
Enkei RP03 denkigrve Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 9 02-10-2013 03:24 AM
