Old 01-09-2014, 08:07 PM   #43
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
Originally Posted by Boofneenee View Post
really? I never new that.
It's in the manual.
^GT5 Replay Photo Mode^
Old 01-09-2014, 08:15 PM   #44
CSG Mike
CSG Mike's Avatar
Originally Posted by himbo View Post
I have a miserable time trying to get through the snow. I tried to disable TC/VDC and it wouldn't stay disabled. Sometimes a little bit of slip is needed to keep momentum, and the nannies would intervene and make it impossible. I know there's a pedal dance to help put the braking system in diagnostic mode- and thereby disabling the TC/VDC systems- but I don't like the idea of not having ABS in these conditions.
My question for the tuners is - are there any tunes you can set up to allow us the ability to 100% disable the nannies? I'm not sure if TC/VDC are controlled by the ECU or another control module- but if they are, can you create tunes that will allow us to disable the systems completely when we turn off the TC button?
Thanks!
Sinan
You'll keep ABS with the pedal dance.
himbo (01-09-2014)
Old 01-10-2014, 01:57 PM   #45
wparsons
wparsons's Avatar
Sorry if I was commenting on a statement without considering the context of the discussion with SkullWorks.
Yep, that's my bad. I got you mixed up with SkullWorks.
flickr
Old 01-10-2014, 03:12 PM   #46
SirBrass
SirBrass's Avatar
Getting the two yellow lights doesn't totally disable tc. It's mostly off, but certain circumstances WILL cause it to kick in some, and the tc skid light (center of the console inside the tach circle) will come on meaning tc has activated.
I've seen it happen on my vehicle. The pedal dance is the only way to actually FULLY disable the nannies, but you turn off EBFD in the process as well, which is something most of us decidedly do NOT want to do.
Old 01-10-2014, 06:25 PM   #47
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
There's an item for 08+ Subarus called Setting Saver (IIRC). It would basically record your button presses and save it like a macro. So you'd have TC/VSC off and throttle set to S# whenever the car starts, or whatever combo you want.
Perhaps something like that can be implemented for this platform.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 01-11-2014, 04:20 AM   #48
Kodename47
Kodename47's Avatar
Drives: UK GT86
But did you feel anything happen? I suspect that light flashes whenever you lose traction and is not implying that the car is doing anything about your situation. It seems that when you lift off the road surface that the TC/VSC re-enables and the lights go out on the dash.
.: Stealth 86 :.
Kodename 47 DJ:
Old 01-11-2014, 01:21 PM   #49
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
It does something, but not much. In the snow with the TC in the don't turn back on position, it won't come on when drifting, but it will if one wheel is on snow and the other has traction while goosing the throttle.
Luckrider is offline   Reply With Quote
Old 01-11-2014, 10:08 PM   #50
wparsons
wparsons's Avatar
^^ That's the EBFD system giving the loose side of the diff some resistance. A Torsen diff requires some resistance on the low traction side and if there isn't enough resistance it'll unload like an open diff. To stop this the ECU will apply a bit of brake to keep the diff from unloading. It's not a stability thing, it's a keep the diff from unloading thing.
flickr
Old 01-13-2014, 09:32 PM   #51
himbo
Drives: Lightening Red BRZ Ltd.
Interesting observation on my end. Seems the tc/vsc turns off when pressing the tc button LONGER than 5 seconds. Seems like the 3 seconds doesn't fully deactivate the systems.
himbo is offline   Reply With Quote
Old 01-13-2014, 10:40 PM   #52
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Zomg
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 01-13-2014, 11:12 PM   #53
Luckrider
Luckrider's Avatar
I am not new to this technology at all. In fact, I wrote one of the best writeups on all of the 4wd systems for the newest generation of Grand Cherokee and this is a feature of the system (except they call them brake locking differentials).
http://www.jeepforum.com/forum/f309/...stems-1177616/
Here is my basic info compilation thread for when that subforum first started. I had some awesome tech articles and this one got stickied (and links to others).
http://www.jeepforum.com/forum/f309/...ation-1173618/
How to disable the 120 kph warning - UAE captaindubai ASIA 25 05-21-2023 04:54 PM
How to disable DRL in FRS whitefrs Cosmetic Modification (Interior/Exterior/Lighting) 12 12-13-2016 03:11 PM
Dealer won't disable Ecu features? DBacon1052 Scion FR-S / Toyota 86 GT86 General Forum 28 01-09-2014 09:30 AM
Dealer refusing to disable DRL's? zaptorque Scion FR-S / Toyota 86 GT86 General Forum 64 09-17-2013 05:20 PM
Is there a way to disable the immobilizer? schtebie Issues | Warranty | Recalls / TSB 5 09-22-2012 07:09 PM
