| Software Tuning Discuss all software tuning topics. |
#43 |
Trust me, I'm the Doctor
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#44 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | himbo (01-09-2014) |
#45 |
Yep, that's my bad. I got you mixed up with SkullWorks.
#46 |
Getting the two yellow lights doesn't totally disable tc. It's mostly off, but certain circumstances WILL cause it to kick in some, and the tc skid light (center of the console inside the tach circle) will come on meaning tc has activated.
I've seen it happen on my vehicle. The pedal dance is the only way to actually FULLY disable the nannies, but you turn off EBFD in the process as well, which is something most of us decidedly do NOT want to do.
#47 |
Drives: '13 BRZ Ltd WRB
There's an item for 08+ Subarus called Setting Saver (IIRC). It would basically record your button presses and save it like a macro. So you'd have TC/VSC off and throttle set to S# whenever the car starts, or whatever combo you want.
Perhaps something like that can be implemented for this platform.
#48 | |
Drives: UK GT86
.: Stealth 86 :.
#49 | |
My Other Ride's a Jeep
Drives: 2013 BRZ Limited
#50 |
^^ That's the EBFD system giving the loose side of the diff some resistance. A Torsen diff requires some resistance on the low traction side and if there isn't enough resistance it'll unload like an open diff. To stop this the ECU will apply a bit of brake to keep the diff from unloading. It's not a stability thing, it's a keep the diff from unloading thing.
#51 |
Drives: Lightening Red BRZ Ltd.
Interesting observation on my end. Seems the tc/vsc turns off when pressing the tc button LONGER than 5 seconds. Seems like the 3 seconds doesn't fully deactivate the systems.
#52 |
Fanboy
Drives: 2013 ultramarine frs
Zomg
I'm done helping those who won't help themselves.
TL;DR: ![]() -Duke |
#53 | |
http://www.jeepforum.com/forum/f309/...stems-1177616/ Here is my basic info compilation thread for when that subforum first started. I had some awesome tech articles and this one got stickied (and links to others). http://www.jeepforum.com/forum/f309/...ation-1173618/ |
| How to disable the 120 kph warning - UAE | captaindubai | ASIA | 25 | 05-21-2023 03:54 PM |
| How to disable DRL in FRS | whitefrs | Cosmetic Modification (Interior/Exterior/Lighting) | 12 | 12-13-2016 02:11 PM |
| Dealer won't disable Ecu features? | DBacon1052 | Scion FR-S / Toyota 86 GT86 General Forum | 28 | 01-09-2014 08:30 AM |
| Dealer refusing to disable DRL's? | zaptorque | Scion FR-S / Toyota 86 GT86 General Forum | 64 | 09-17-2013 04:20 PM |
| Is there a way to disable the immobilizer? | schtebie | Issues | Warranty | Recalls / TSB | 5 | 09-22-2012 06:09 PM |
