Old 02-27-2012, 12:34 PM   #155
dsgerbc
Drives: BRZ(sold), STI
Originally Posted by maxeveland View Post
not if no ones around
If 'there's no one around' - you're the only car on the road and if the cop hears you squealing tires in many states you'll get a ticket. In a couple of states it will come with misdemeanor charge, expensive fine and a bunch of points on license.
Old 02-27-2012, 05:56 PM   #156
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by no_name View Post
I know it doesn't make much difference on FWD, but a RWD car without an LSD is really painful to drive in the winter. If you're trying to just start moving and break traction with one wheel you're not going anywhere.
Wait I thought traction control takes care of that right? Doesn't it brake the slipping wheel to send power to the other wheel? I imagine it's not set up as well as say McLaren's "brake steer" system, but it should get the job done right?
Old 02-27-2012, 07:15 PM   #157
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
TC doesn't send power to any wheel..it limits power to the wheels to control slip.
RWD w/ open Diff in slippery road conditions sucks, even if the TC kicks in your not effectively gaining any additional traction during an emergency.
RWD w/ LSD has an effective control of available traction, and matted with TC. Most computers can control the available traction dynamically.
WingsofWar is offline   Reply With Quote
Old 02-27-2012, 07:22 PM   #158
dsgerbc
Not really. Electronic/software "eLSD"implementation based on brake application can't send much power to the wheel with traction. It will help if you're stuck on your all-seasons on a half-inch of dusting, but not much beyond that.
He's not talking about TC. He's talking about software implementations that will brake one wheel that is slipping just enough to send some power to the other rear wheel. Like some new Beemers do. SoftLSD or smth.
Old 02-27-2012, 09:15 PM   #159
miata
Drives: 2006 Miata 5 spd
In an open diff if you hold one wheel the other will spin twice as fast as when both wheels are spinning.
2006 Miata
miata is offline   Reply With Quote
Old 02-27-2012, 10:46 PM   #160
Spaceywilly
ZC6A2B82KC7J
Spaceywilly's Avatar
Drives: 2002 WRX
You brake the wheel that is spinning. It gives the other wheel something to push against so it can move again. Torque in an open diff goes to the path of least resistance.
Straights are for fast cars. Turns are for fast drivers.
Spaceywilly is offline   Reply With Quote
Old 02-28-2012, 12:06 AM   #161
dsgerbc
^ It does not take much in terms of brake torque to stop the spinning wheel completely (and you need to apply even less not to stall the engine) . And that's as much torque as this softLSD will send to the wheel with grip. If it's enough to get moving - fine.
Old 02-28-2012, 12:08 AM   #162
miata
I agree. electronic faux diffs work. Just the downside is it wears down the brakes and heats them up also. That would be bad for the track use.
2006 Miata
Old 02-28-2012, 11:58 AM   #163
no_name
no_name's Avatar
Drives: 2005 Hyundai Accent
I was speaking from the perspective of not having any traction control - old open diff AE86. I got stuck in the snow more times than I can count. My current car doesn't have TC either but just being FWD helps. Actually I've never owned a car with TC or ABS.
GT86: "This car has two steering wheels: one is circular, the other is operated with the right foot."
no_name is offline   Reply With Quote
Old 02-28-2012, 12:46 PM   #164
Spaceywilly
ZC6A2B82KC7J
Drives: 2002 WRX
If you apply the ebrake lightly in an open-diff car (not enough to lock up both wheels, but enough to give the wheel that has traction something to push against) it can have the same effect as the "e-diff" and help get you unstuck.
Old 02-28-2012, 12:58 PM   #165
miata
That's a good idea.
2006 Miata
Old 02-28-2012, 01:30 PM   #166
Kunzite
Drives: Toyota Auris
I used it with my old car, it definitely works.
That was one of the few FWD cars that could do this trick
Kunzite is offline   Reply With Quote
Old 02-29-2012, 06:38 PM   #167
tranzformer
Delights in pure handling
tranzformer's Avatar
Drives: Zoom Zoom
That's a good idea.
Miata, check your pm. Sent you a message.
tranzformer is offline   Reply With Quote
Old 03-01-2012, 01:11 PM   #168
chate
Pharmasaurus Magnificus
chate's Avatar
if the veloster turbo really is 21k like rumored, what price would the FRS need to hit to stay competitive? How much more would you pay?
chate is offline   Reply With Quote
Hyundai Veloster Siriusly.Andrew Other Vehicles & General Automotive Discussions 110 10-01-2013 09:25 PM
