Old 01-07-2014, 11:17 PM   #2549
Snoopy_TXR
Snoopy_TXR's Avatar
Drives: 2013 Raven FR-S & 2005 BSP X-Runner
Originally Posted by Tobz View Post
Hey guys,
Wondering if anyone can tell me if this knocking noise I get is normal. U can really hear it at the end of the clip. Thought it might have been oil, so in drained it and out new oil in, but noise remains. Seems to only be at idle.
Also is the oil meant to be exactly at the engraved line on the dip stick?
Sounds like a bad throw out bearing. Step on clutch and listen for any changes.
Mods: Buddy Club Racing Spec Coilovers, Enkei RPF1/17x9/5x100/+ 35, Potenza RE-71R 255/35/17, TRD Air Filter, 5:AD Spoiler, Beat-Sonic Shark Fin Antenna, PTuning DS-325 Cat Back Exhaust, FT86SF Catted UEL Header, Tanabe Overpipe, HKS Resonated Front Pipe, HKS GT V3 S/C, HKS Flash Editor, Full Blown Aluminum Radiator, 12" Radiator Slim Fans.
Snoopy_TXR is offline   Reply With Quote
Old 01-07-2014, 11:20 PM   #2550
phloozy
phloozy's Avatar
Drives: Scion FR-S
Originally Posted by moto-mike View Post
We were running 285whp/225 tq (275/210 uncorrected; hot day) on E85 no problem with the 70mm pulley in the summer. Then the JDL header went on, then it got colder. Once it got below freezing the clutch said it's goodbyes. Not sure how much HP/TQ since the dyno has not yet been fully unpacked from the move, but it's definitely faster. I'd say stock clutch is good for no more than 225 uncorrected tq, probably closer to 210 for any serious span of time.
For the record we just run some 255 Goodyears 240 treadwear and don't get too wild with launch control. It is just power pulling it loose above 3500 in higher gears. In the summer it was 200 UNCORRECTED tq, so figure at least 220-240 in the cold on e85 with the JDL unit. Car is dramatically faster in the cold without the IC, and we're able to run some seriously advanced timing on e85 in these temps.
Thanks Mike. I have only destroyed 1 clutch and it went instantly (upgrading to stage 2 legacy gt without doing the clutch). Recently I noticed that I have a slight burning clutch smell sometimes but havent experienced any slipping. Could this be a sign or is my nose just playing tricks on me?
I was looking for your email today also and couldnt find it anywhere on your site. Could you pm you email address?
phloozy is offline   Reply With Quote
Old 01-08-2014, 03:12 AM   #2551
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
Originally Posted by xxscaxx View Post
Seeing as everything that has been released over seas has been released in the US, i'm hoping it comes to the states.
Hopefully with no delay this time unlike with the intercooler.
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
The Following User Says Thank You to Khorne For This Useful Post:
xxscaxx (01-08-2014)
Old 01-08-2014, 12:17 PM   #2552
xxscaxx
Drives: 2013 SWP BRZ
I'm not on E85 as you know but agreed, car is so much faster in this cold weather we have been having. I can't wait to install my intercooler on friday
what clutch are you running?
xxscaxx is offline   Reply With Quote
Old 01-08-2014, 03:30 PM   #2553
MINOCIN
MINOCIN's Avatar
Drives: Asphalt 2013 FR-S
Hi Guys,
I've been following this thread and thanks to everyone's input I decided to pull the trigger on the intercooled Innovate kit last black Friday. I'm happy to say that I will be picking the kit up from the UPS store later today after work
One of the reasons I chose this kit is because I like how clean and oem it looks. Also, people say the install only takes 3-4 hours. I thought about doing the install myself but then decided I would prefer to have a shop do it that has already installed a few of these before. From what I have heard on this thread the intercooled kits have cheap plastic nozzles that tend to leak if not tightened or easily break.
Things like this are what I'm hoping a shop that has done a few kit installs already will be able to anticipate and handle properly. So i'm turning to the community for help.
Can anyone recommend a shop that has already installed a few of these kits? I live in Santa Barbara (still technically SoCal) but I'm willing to drive to the LA or OC area if someone can recommend a good shop.
If you know of a good shop in SoCal that has installed a few of these kits then please PM me with their contact info.
Thanks!
MINOCIN is offline   Reply With Quote
Old 01-08-2014, 03:34 PM   #2554
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks!
Talk to @DeliciousTuning - He's out that way and should be able to point you in the right direction for a shop to install it. I'd also recommend having him tune your car for you.
Old 01-08-2014, 03:50 PM   #2555
MINOCIN
MINOCIN's Avatar
Thanks. @DeliciousTuning was my first thought and I PMed him already a couple days back, but my guess is he's really busy because I haven't received a reply back yet. From all the good stuff I've heard about his tunes and his overall support in this forum I definitely would like to have him tune my car.
I was just checking to see if anyone else had any good recommendation. I guess I'm just getting excited because I'm getting my kit today
Also, good to know about the catch can helping with the tune. Hopefully Radium releases their catch can kit for our cars soon.
Old 01-08-2014, 03:50 PM   #2556
xxscaxx
The only issue i've heard of the plastic fittings were the one on the back of the supercharger, which have supposedly been taken care of by innovate prior to shipping. They were finding that once it was heat cycled they would back off a bit.
I know the heat exchanger also has plastic fittings so I hope there are no issues with those. I'll let someone with the IC kit chime in. I kind of forgot about those actually, hoping they are ok as my kit comes in two days.
Old 01-08-2014, 03:52 PM   #2557
xjohnx
Grip>Slip
xjohnx's Avatar
Thanks. [MENTION=27981]
It's supposed to be available any time now. I bought their universal dual catch can setup in the mean time, hoping that I can order the FT86 specific bits separately when they're released.
whataboutbob (01-08-2014)
Old 01-08-2014, 11:11 PM   #2558
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Learnt a valuable lesson. If you want something done correct, do it yourself.
Pulled the SC off and I spent the entire day stripping it down to find the cause of my problem.
The cooler adapter o rings, seems out of the 6, 2 were not the correct size, causing the coolant to leak into the manifold.
Now this is puzzling me. After changing the coil pack on bank 1 and new plugs, the very next day the coolant started leaking, which I can only assume the bank 1 has been dead for sometime and once fixed the boost pressure caused the incorrect o ring to fail.
I took the opportunity to seal the L connectors again, apply grease and seal the kit properly.
Put kit back, started up, car running perfect
Hopefully that's the end of my problems.
Ryan86 is offline   Reply With Quote
The Following 2 Users Say Thank You to Ryan86 For This Useful Post:
1010110 (01-08-2014), whataboutbob (01-08-2014)
Old 01-08-2014, 11:23 PM   #2559
phloozy
phloozy's Avatar
Drives: Scion FR-S
Anyone else kinda jealous of the big silver FMIC the turbo guys get? I really want to remove my front grille but it will look so empty
Old 01-08-2014, 11:54 PM   #2560
wrxgoose
WUB WUB
Drives: 2013 Firestorm
a little bit, but i do like having a boosted sleeper. people don't expect them to be as fast as they are if they don't have a FMIC. atleast people around here don't
wrxgoose is offline   Reply With Quote
The Following 4 Users Say Thank You to wrxgoose For This Useful Post:
CK_Bladesmith (01-08-2014), Ryan86 (01-09-2014), whataboutbob (01-08-2014), xxscaxx (01-09-2014)
Old 01-08-2014, 11:57 PM   #2561
Pekingduck
Drives: 4 wheels
Hi Guys,
Thanks!
Try Evasive Motorsports I know they have installed a couple, plus they have a dyno on site. Most definitely get a tune after
Pekingduck is offline   Reply With Quote
Old 01-09-2014, 12:02 AM   #2562
phloozy
phloozy's Avatar
Drives: Scion FR-S
I have gotten so many waves from high end cars like porshes and vettes because of this. Just 2 days ago I had a cayman s try to ricer fly by me so I floored it and he couldnt pass. We ended up cruising for a bit and gave a thumbs up when I got to my exit. Same thing happened with a tuned Legacy GT, when he finally caught up you could see how surprised he was.
So yeah you are right sleeper can be fun.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
