Old 01-07-2014, 04:18 AM   #2535
Tobz
Tobz's Avatar
Drives: Toyota 86 GTS
Hey guys,
Wondering if anyone can tell me if this knocking noise I get is normal. U can really hear it at the end of the clip. Thought it might have been oil, so in drained it and out new oil in, but noise remains. Seems to only be at idle. [ame="https://www.youtube.com/watch?v=4t958LgZCuE&feature=youtube_gdata_player"]Super charger sound - YouTube[/ame]
Also is the oil meant to be exactly at the engraved line on the dip stick?
Tobz is offline   Reply With Quote
Old 01-07-2014, 04:50 AM   #2536
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Wow that is a nasty sound and not normal.
The booklet say fill 5.31 US fluid ounces or 157 milliliters.
When I check mine it is just on that line on the dipstick.
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
Tobz (01-07-2014)
Old 01-07-2014, 06:18 AM   #2537
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Originally Posted by Tobz View Post
Hey guys,
What's your idle go down to? I ask as some folks said heard similar around 600-700rpm. They took in for the TSB and it was raised to 850+ and smoothened out and silent. So I'd you hold peddle steady at say 800+ is your noise still there? Something to do with low rpm relevant to lower oil pressure then lifter knock etc... Just trying to help is all not sure on this.
The Following User Says Thank You to OICU812 For This Useful Post:
Tobz (01-07-2014)
Old 01-07-2014, 06:27 AM   #2538
Calum
That Guy
Drives: 2013 asphalt FRS MT
Aren't guys having trouble going to a smaller pulley because the 75mm pulley is already making 11 psi? I don't think more boost would help, atleast not to the point of 300 whp on pump gas. I'm guessing they'd have to be making the compressor more efficient to get those results.
Old 01-07-2014, 06:29 AM   #2539
Tobz
Tobz's Avatar
I'll try the 800 rpm thing tmrw. But if you guys think of anything else that would be awesome.
Old 01-07-2014, 07:07 AM   #2540
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 01-07-2014, 10:51 AM   #2541
vgi
Drives: frs
Originally Posted by Khorne View Post
Well i'm not allowed to share just yet, other than Sprintex are calling it the 210 Plus.
Over 300whp on pump gas, so 98RON/93AKI. They haven't given me a solid date yet other than soon, ill be down there as soon as they release it to get some of that!!!!!
Yup that sounds exactly right
well, considering it is supposedly a fairly easy bolt-on and looking at what some folks have done could it be something like 3" CAI, 68 or 70 mm TB, bored out supercharger intake manifold and maybe some stuff to reduce the IAT like self adhesive insulation to the under side of the discharge manifold?
but doubling the HP of the intercooled kit on the same blower is just hard to believe.
PS add an oil catch can as well as it seems people are able to advanced timing a bit (up to 1*) when oil vapor doesn't make it into blower.
vgi is offline   Reply With Quote
Old 01-07-2014, 12:46 PM   #2542
xxscaxx
Drives: 2013 SWP BRZ
Is this going to be an upgrade for current 210 users, or something that will be replacing the original 210?
Happy about this but bummed because I wanted to go get dyno tuned in a couple weeks. I know I will go get tuned, then whatever this "secret" is will come out, and I will have to go back again
xxscaxx is offline   Reply With Quote
Old 01-07-2014, 01:17 PM   #2543
phloozy
phloozy's Avatar
Drives: Scion FR-S
Agreed, I am going to wait on this before I touch the car again. Although this may mean new clutch time :/
phloozy is offline   Reply With Quote
Old 01-07-2014, 02:55 PM   #2544
Ryan86
Road Warrior
Ryan86's Avatar
I agree with you, I'm pushing 11 to 12 psi on 75mm pulley on the coast, however when I drive inland to 1000m above sea level boost dropped to 8psi.
So the guys at altitude are using 70mm and getting 11psi boost.
Old 01-07-2014, 02:57 PM   #2545
Ryan86
Road Warrior
Ryan86's Avatar
I note my idle is also 600 to 700, I asked my tuner why so low as I was always idling at 800 prior to SC.
Old 01-07-2014, 06:04 PM   #2546
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
I wouldn't call it a fairly easy bolt on, Sprintex are also using it in tandem with a 70mm pulley at sea level to achieve that power result.
And as i said earlier i have no idea if Innovate is going to bring this to the US as well.
Build thread
Old 01-07-2014, 10:11 PM   #2547
xxscaxx
Seeing as everything that has been released over seas has been released in the US, i'm hoping it comes to the states.
Old 01-07-2014, 10:16 PM   #2548
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
We were running 285whp/225 tq (275/210 uncorrected; hot day) on E85 no problem with the 70mm pulley in the summer. Then the JDL header went on, then it got colder. Once it got below freezing the clutch said it's goodbyes. Not sure how much HP/TQ since the dyno has not yet been fully unpacked from the move, but it's definitely faster. I'd say stock clutch is good for no more than 225 uncorrected tq, probably closer to 210 for any serious span of time.
For the record we just run some 255 Goodyears 240 treadwear and don't get too wild with launch control. It is just power pulling it loose above 3500 in higher gears. In the summer it was 200 UNCORRECTED tq, so figure at least 220-240 in the cold on e85 with the JDL unit. Car is dramatically faster in the cold without the IC, and we're able to run some seriously advanced timing on e85 in these temps.
Xero-Limit is offline   Reply With Quote
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
