#323 | |
Drives: Subaru BRZ Sport Tech Satin White
Might be pretty exciting in a crash... |
#324 | |
Driving downhill is far more difficult and dangerous, especially with extra weight in the trunk! |
#325 | |
Drives: 2013 WRB Subaru BRZ
Yesterday I drove up a VERY steep hill by my house that was complete ice. There were actually vehicles sliding down towards my car as I EASILY drove up it. I had no choice as I was already halfway up so I chose to just weave around the sliding cars. Also went past a truck with 4WD spinning out near the top. This car just doesn't cease to amaze me in winter driving conditions. I would take it anywhere (and have!), without worry or concern. I would even promote it as the most fun, safest RWD sports car for winter driving!! Are there better ones out there??? Yes, but not RWD, or nearly as much fun! Put some sand bags in the trunk and get out there! The gas mileage difference is very minimal. |
#326 |
i'm sorry, what?
Drives: Canada
if this was true, any uphill climb would settle the rear end by an inch.. would it not... mon fraire?
#327 | |
Drives: BRZ Sport-tech
See attached img |
| The Following User Says Thank You to PMPB For This Useful Post: | Frost (01-07-2014) |
#328 |
i'm sorry, what?
Drives: Canada
neat!
![]() now would be interesting to know aproximate suspensed weight of the chassis
#329 | |
Drives: 2003 S2000, 2008 Fit
Or is it an inevitable conclusion that the car will swap ends or slide down sideways? |
#330 | |
Hail Magnet
![]() The best advice I can give on these kind of things I learned when I was but a wee lad: Keep your momentum uphill. Whatever you do, don't stop, and pray that the guy in front of you doesn't stop, or you 1) wont be able to get started again, or 2) slide back down the hill and cause a multi-car accident. So, the other best option, if your nose is no longer pointed uphill, is to use physics to your advantage. Take the car out of gear and apply the parking brake. This locks up your rear wheels and allows your fronts to move. More friction being at the back now, your front will eventually swing downhill (can be assisted by steering to force it). Once your nose is pointed downhill again, you can release the parking break and attempt to navigate. Granted, this is a thought experiment. Attempt at your own risk. Just seems to make sense to me! |
#331 | |
This don't work with rwd. With TC fully on you won't experience this combination of slide sideways and backwards. The TC tricks the Torsen into biasing more torque to the wheel with grip. The secret is to ease the throttle to minimize the TC interference and give both rear tires a chance to grip. One drawback of LSD including the Torsen torque bias diff is both rear wheels can spin simultaneously. This is both an advantage and presents a challenge. |
#332 | |
If not, just turn the wheel the front end just swing around easily given the weight distribution, and the fact that car turn really well while going backwards! |
| The Following User Says Thank You to PMPB For This Useful Post: | daiheadjai (01-08-2014) |
#333 |
Drives: Ultramarine FRS 6MT
2nd gear hard to engage
Has anyone experienced difficulty engaging 2nd gear when it's really cold? Does changing the transmission oil help?
#334 | |
#335 | |
CASC-OR T.A. Director
Drives: '13 Prius, '22 BRZ
Granted the Corolla wasn't THAT bad but the fact that my MR2 had none was hilarious! I had driven standard Imprezas before and even then felt some torque steer but the MR2... that was a super enlightening moment.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK |
#336 |
Drives: FR-S MT
| Tags |
| 7thgear rulz, kryptonite allergy, suberman cant drive |
| winter driving | jmaryt | Scion FR-S / Toyota 86 GT86 General Forum | 88 | 11-11-2013 12:15 PM |
| Winter Driving Tip. | NOHOME | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 03-06-2013 06:38 PM |
| Practice winter driving | 4U-GSE | Scion FR-S / Toyota 86 GT86 General Forum | 4 | 01-26-2013 11:29 AM |
| How many are planning on winter driving? | NV Auto | CANADA | 109 | 01-11-2013 10:30 PM |
| winter driving | paraguin | BRZ First-Gen (2012+) — General Topics | 25 | 08-03-2012 06:26 PM |
