Old 03-10-2013, 03:04 AM   #43
Pin Flare
Luna
Pin Flare's Avatar
Drives: 2016 FRS Release Series 2.0
Originally Posted by wparsons View Post
As it's been said before, a 275 is hugely overkill, especially on stock power and just for daily driving. Adding too much width can make the balance worse, steering feel worse, and it makes the car tram line (follow grooves in the pavement) worse. IMO, 245's already look plenty wide on these cars (especially up front!). If you want 305's get a big v8 muscle car
And your opinion is just that. Slamming a car on the ground is overkill, loud exhaust is overkill, widebody kits are over kill, big wings are over kill. But why do we do it? Because its our cars and we can do what we want to our cars and express ourselves through our cars. I like big tires so that's what I put on.
For all those wondering there is still plenty of clearance all around and I could put a 285 on there and maybe even a 295 with fender rolling.
2016 FRS RS 2.0 #347 of 1000
2013 SCION FRS DEAD AND GONE THANKS TO A FLOOD.
Pin Flare is offline   Reply With Quote
The Following 2 Users Say Thank You to Pin Flare For This Useful Post:
Gixxersixxerman (03-10-2013), ScionFR-S (03-10-2013)
Old 03-10-2013, 03:43 AM   #44
Tansey86
Tansey86's Avatar
Drives: 2003 Subaru Outback
Yeah derp 275 is overkill for 200hp, but if you have 400 or 500 hp like a lot of people do, if anything 275 might be UNDERkill. It doesn't matter what kind of car you have, if you make more power you need wider tires plain and simple. " If you want 305's buy a big v8 muscle car " has to be one of the most mindbogglingly idiotic statements ive heard on this forum, and there's been a lot of dumb comments on here.
Why cant people wrap their head around people making big power in these cars? Because its " meant " to be used for autocross? Scion and Subaru gave us these cars to do what we want with them, build our own dream car. Let people have their dream car and do what they want with them.
Tansey86 is offline   Reply With Quote
The Following 4 Users Say Thank You to Tansey86 For This Useful Post:
Gixxersixxerman (03-10-2013), Pin Flare (03-10-2013), PRORICAN (03-10-2013), Sportsguy83 (07-03-2014)
Old 03-10-2013, 11:18 AM   #45
wparsons
wparsons's Avatar
Tire compound >>> tread width. A much narrower good sticky tire will get way more grip than a wider mediocre tire.
Like I said, if you're doing it for the look then that's your call, but if you're after grip and performance a hugely wide tire isn't the answer.
flickr
Old 01-07-2014, 10:49 PM   #46
Dan@AWD
Drives: 2013 Argento FR-S
Anyone try these yet?
http://www.tirerack.com/tires/tires....TADR&tab=Sizes
I'm lowered 2" on stock struts. Do you think they will hit the spring perch?
Sent from my SAMSUNG-SGH-I337 using Tapatalk 2
Dan@AWD is offline   Reply With Quote
Old 01-07-2014, 11:18 PM   #47
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Why not opt for toyo r888 ?
regarding the size im not sure
http://www.tirerack.com/tires/tires....omCompare1=yes
Old 01-08-2014, 11:26 AM   #48
charged86
charged86's Avatar
Originally Posted by Jive Turkey View Post
i ran a 275/35/18 on my sti, its the perfect width IMO. the issue is all tires run different. some 255's are as wide as other companies 275's so when you buy, look up the width in inches.
here is what that looked like:
those are sumitomo HTR Z III 275/35/18 they are middle of the range as far as width. i know Starspecs run really wide so do michelin PSS. if my sti wasn't hit, i was going to step up to the same sumitomo's but in a 295/30.
however, anything bigger than a 255, as long as it's a good grippy tire will be over kill for the brz. i plan on doing 9.5' wide all around with a 255/35 PSS tire. adding so much rubber will make it a purely momentum car, and it'll struggle to really turn it. by saying change the way it drives, the car will not rotate as easily, so you really will have to turn in and hammer the gas to get it right. you dont want to simply slap on maive tires in the rear and keep something skinny in the front either, a nice square setup will be perfect for this car. just do a start spec or a michelin PSS in a 255, trust me those run wide.
this bug eye is running a 255/35/18 starspec on 18x9.5 +38 works...look how meaty it looks:
jut remember, when it comes to tires its not the width aspect that counts, but its compound and the actually contact patch you put down. bigger doesn't mean more contact...
can anyone tell me the name and model of the tire seen above?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
Old 01-09-2014, 12:40 PM   #49
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
did you not read the post at all? i clearly listed the sizes and names.
one is a 275 sumitomo the other is a 255 starspec.
Jive Turkey is offline   Reply With Quote
Old 01-09-2014, 01:15 PM   #50
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
seems like any post longer than 50 words these days needs a TL;DR at the end.
I blame Reddit.
-alex
Old 01-09-2014, 01:52 PM   #51
Dan@AWD
That's a road course tire. I need a drag radial.
Old 01-09-2014, 01:54 PM   #52
FunCon5
FunCon5's Avatar
I'd go with 255/35/18's. But the widest tire you "could" fit IMO is a 285/30/18. Depending on offset and camber of course.
FunCon5 is offline   Reply With Quote
Old 01-17-2014, 11:13 PM   #53
Dan@AWD
http://www.discounttiredirect.com/di...%2FPerformance
Does anyone think these would fit on the rear with stock struts and 1" drop?
Old 01-18-2014, 05:41 PM   #54
ScionFR-S
ScionFR-S's Avatar
Drives: Raven Scion FR-S
What's your offset?
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
ScionFR-S is offline   Reply With Quote
Old 01-26-2014, 11:23 AM   #55
Dan@AWD
Originally Posted by ScionFR-S View Post
What's your offset?
Enkei RPF1 18x9.5 +38 offset.
Old 07-03-2014, 09:46 AM   #56
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
thread necro!
the BFG probably wont fit if theres any possible chance of it hitting with a street tire. the bfg drags run wide in general. plus its a pretty garbage drag radial compared to everything else out there. its a 14yr old design now.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
WTB: 1 OEM wheel with or without tire #87 Wheels and Tires 11 01-31-2013 01:21 AM
tire/wheel setup? kosoku Tracking / Autocross / HPDE / Drifting 0 11-25-2012 09:53 PM
What is the widest tire for these wheels? ngabdala Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 09-12-2012 09:20 AM
18x9 wheel fitment and options? epson1 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-31-2012 05:36 PM
Widest rear tire for a staggered setup? Jeff Lange Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 5 05-22-2012 08:52 PM
