Old 01-06-2014, 04:13 AM   #15
koevasi
koevasi's Avatar
Drives: 1
Get the SPL arms. They're superior to the Cusco, IMO, and roughly the same price.
Biggest changes that I like? Forced Induction. If you strictly want to stick to your chassis/suspension/brake mods, then high end coilovers. You literally get what you pay for.
I will look into (SPL - pretty) arms. I will first have to figure out what I can expect from trailing arms! With higher-end coilovers, what price point are we talking about generally? I would go as far up as Ohlins (so around 3-4k) but I am not convinced - i.e. nobody seems to be raving about them.
I want improved steering feel and even faster turn in with 225 section or narrower RS3s or similar which is why I was thinking about reducing unsprung (sort of ) weight with lighter front lower arms.
koevasi is offline   Reply With Quote
Old 01-06-2014, 04:24 AM   #16
diss7
Drives: AE86, 2x GT86, TE27
Based on requirements of increased steering feel and turn in..
Increased front camber, via camber bolts or coilovers
Increased front castor, via offset bushing, flca or coilovers,
Try different (increase) front toe out (via alignment)
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
koevasi (01-06-2014)
Old 01-06-2014, 05:22 AM   #17
koevasi
koevasi's Avatar
Drives: 1
I am sitting on 2.4 degree camber up front with 0.1 toe out - was on 0.25 degree before and there was reduced steering feel. the car was also a little too vague on the straights even at moderate speeds.
It's not going to be easy to achieve my goals. maybe i do need wider tires.
Old 01-06-2014, 05:25 AM   #18
koevasi
koevasi's Avatar
Drives: 1
Originally Posted by andrewFT86 View Post
1. Driver Mod
2. Better Tires
3. ss brake lines and higher temp rated pads
4. re learn the car - driver mod
Already have 2 and 3.
I know I can never have enough of 1 and 4 but I just don't have the time to go to the track all that often. It's just too far where I am. (excuses, excuses)
Old 01-06-2014, 06:31 AM   #19
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Strut tower bar and Whiteline Sub Frame bushings
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Old 01-06-2014, 07:48 AM   #20
koevasi
koevasi's Avatar
Drives: 1
all those mods and it's those two? do you have a strut tower bar made out of palladium? lol
Old 01-06-2014, 08:57 AM   #21
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
For what I used my car for? The Essex Sprint front brakes. :shrug:
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The Following User Says Thank You to Dave-ROR For This Useful Post:
Old 01-06-2014, 09:43 AM   #22
CSG Mike
CSG Mike's Avatar
Turn-in-concepts steering rack bushings will improve feel.
RS3's will always lack feel, compared to AD08R, RE11A, etc.
Only way you can get faster turn-in is to get higher spring rates and matched damping for faster weight transitions.
koevasi (01-06-2014), Pizzman (01-06-2014)
Old 01-06-2014, 03:20 PM   #23
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Originally Posted by RehabJeff86 View Post
Dont waste money on front LCA, Cusco LCA, or any bushings
Can you elaborate on the bushings comment? I'm just curious. I only know from "Internet knowledge", less play and doesn't wear out like oem rubber.
mike_ekim1024 is offline   Reply With Quote
Old 01-06-2014, 07:12 PM   #24
koevasi
koevasi's Avatar
Drives: 1
I have the TIC bushings too - maybe it's time to do a sig.
Is it the softer sidewalls on the RS3s or some other factor?
Old 01-06-2014, 07:14 PM   #25
koevasi
koevasi's Avatar
Drives: 1
I think what he's referring to is that bushings will never bring about a 'night and day' difference?
Old 01-06-2014, 07:20 PM   #26
CSG Mike
CSG Mike's Avatar
It's the sidewalls
koevasi (01-07-2014)
Old 01-07-2014, 12:22 PM   #27
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
You are right about less play and longer wear life, but it comes with excessive NVH for DD.
For DD, OEM bushing will last a long time and keep ride quality and NVH in comfort zone and upgraded bushing will not add any benefit with DD
If you are hardcore racing or tracking then yes, all bushings will need to be upgraded.
Hope this help.
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
The Following 2 Users Say Thank You to RehabJeff86 For This Useful Post:
CSG Mike (01-07-2014), mike_ekim1024 (01-07-2014)
Old 01-07-2014, 01:19 PM   #28
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
The TIC steering rack bushings did not increase NVH in my opinion. The subframe inserts for the rear however added some.
Tye300 is offline   Reply With Quote
What is the Biggest Douchebag Car? JayNutter Other Vehicles & General Automotive Discussions 126 10-20-2014 10:20 PM
Biggest German Meeting so far Twinguin EUROPE 7 10-09-2013 05:51 PM
What was your single biggest adventure? whaap Off-Topic Lounge [WARNING: NO POLITICS] 26 04-16-2013 02:21 PM
Biggest gains yomchi1989 AUSTRALIA 5 09-28-2012 07:31 PM
Subaru BRZ - The biggest small car ever Laika BRZ Photos, Videos, Wallpapers, Gallery Forum 7 06-09-2012 01:21 AM
