Old 01-06-2014, 04:30 AM   #169
Photonic
Drives: 2014 Premium BRZ
Originally Posted by WolfsFang View Post
Never had my traction kick in when i was going around a corner sideways. People who say this are just crazy. Also would love to see someone with no ABS drive around my town when there are ice on the roads.
ABS isnt really going to do much in theory on ICE. Ice fucks everyone up regardless .... even ABS cannot save you from ice on poor tires.
I hate ice ...I dont know how I could handle it. But I would assume itd be like having sudden terminal grip loss on that axle ...I have experienced that recently and there was nothing I Could do. But There are things I could have done ..and Im still trying to figure out where I went wrong.
Honestly my car is the first car I have owned with ABS and I have owned about 11 cars ford ranger, 1500 silverado, dodge stealth, 3000gt, Acura Legend, 240sx, 240SX, 240sx, 240sx, FC rx7, Genesis Coupe . I am not used to these systems, much less TCS. My instincts told me to go ballistic but the ABS would not allow this to happen ...as such ...I felt the corners of my car gripping the road and pushing me on a path I did not want ..and I touched wet grass and forgot to center my wheel and focus on the middle of the road ..by then I had done 540 degrees and was airborne over a ditch.
You should never allow yourself to get into that situation to begin with.
So...Sure ..do what you want.
Photonic is offline   Reply With Quote
Old 01-06-2014, 04:34 AM   #170
Tgionet
SPACESHIP
Tgionet's Avatar
Drives: BRZ Ltd 6MT WRB
ABS is worse than no ABS on ice in pretty much every circumstance
Tgionet is offline   Reply With Quote
Old 01-06-2014, 04:45 AM   #171
Photonic
For a short stint absolutely. Manual pedal modulation as your axles clear the hazard and some good steering and throttle work can help you out alot.
The big deal on asphalt is the rapid rise in temperature of the stationary contact patch of the rubber with no ABS. I am sure someone will chime in to correct me, just laying out a foundation for discussion.
but believe it or not ICE creates a ton of friction and heat when rubber passes over it ... enough so that you can actually develop liquid water between the tread, but that depends on how hard you are going.
I would be curious to see what some folks have to say because this is also a major interest I have had lately. I am sure somebody understands more =D
The Following User Says Thank You to Photonic For This Useful Post:
userjack6880 (01-06-2014)
Old 01-06-2014, 09:35 AM   #172
enwave
That headunit though...
enwave's Avatar
Drives: 2013 Subaru BRZ Limited SSM
Originally Posted by diss7 View Post
You realise the computer can only do something after the human has alerted it to a situation?
You do realize that brake pumping and proper reaction/control (no matter how great of a driver you are) is slower and more difficult when your body and mind reacts to a surprise like a crazy lane change brake situation? It's not just about whether or not you are paying attention.
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300
Eibach Pro-Kit + Michelin PSS (stock size)
enwave is offline   Reply With Quote
The Following User Says Thank You to enwave For This Useful Post:
Old 01-06-2014, 09:35 AM   #173
Rossman
Rossman's Avatar
Drives: '22 BRZ, '17 BRZ (prev '13 FR-S)
Wow, nice sexist thread title...hey loser no-one cares if you pulled your ABS fuse. Why don't you keep your stupid thoughts to yourself.
Rossman is offline   Reply With Quote
Old 01-06-2014, 10:02 AM   #174
trekkie
Drives: 2011 Camry Hybrid
You know I was ambivalent about this thread until you did the **** move and made it all he man woman hater in the title. Having been alive when ABS was a pipe dream as a standard feature, there are merits to both.
Instead, you go and rename it and take a pot shot at girl clothing. Now you're proving you're a tool.
trekkie is offline   Reply With Quote
The Following 2 Users Say Thank You to trekkie For This Useful Post:
Rio (01-06-2014), Rossman (01-06-2014)
Old 01-06-2014, 10:46 AM   #175
Rossman
Rossman's Avatar
He's from New Zealand. They are all fucking racist retarded idiots down there anyway.
I lived there for five years, couldn't get out of that backwoods shithole fast enough.
Old 01-06-2014, 11:04 AM   #176
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
I thought new Zealand was hippy and fairy heaven?
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
Old 01-06-2014, 11:05 AM   #177
Synack
Boosted
Synack's Avatar
Drives: Sideways
So many pansies posting in this thread.
Nismo 370Z 300whp -> FR-S Turbo 450whp on E85 -> Z06 Corvette 500whp
Synack is offline   Reply With Quote
The Following 2 Users Say Thank You to Synack For This Useful Post:
diss7 (01-06-2014), PoorMansRacing (01-06-2014)
Old 01-06-2014, 11:40 AM   #178
chrisl
Drives: 2006 Cayman S, 2007 Outback 2.5i
ABS works fine on ice. It will stop you just as fast or faster than you could do manually, and you will have more control than if you locked up all 4 wheels too. Sure, if you have crap tires, you won't stop much, but that's not the fault of the ABS (you'll still be stopping as fast as the tires allow, and turning off the ABS wouldn't help).
Where ABS is a detriment is on snow, especially if it isn't packed down very much. Then, locking up the wheels would allow snow to pile up in front of them, which is better than allowing the wheels to continue rolling (the same is true in many cases on dirt or gravel). Allowing the wheels to continue rolling will give you more control though, so even in these cases, ABS isn't completely negative.
chrisl is offline   Reply With Quote
Old 01-06-2014, 02:03 PM   #179
stugray
Drives: 2013 GBS BRZ Limited
Not in some of the new cars. Even the new Outback has stereo vision and can stop even if the driver is not paying attention.
The dealer even said the car wouldnt let you drive the car into a wall in a parking garage even if you tried.
Old 01-06-2014, 04:03 PM   #180
diss7
Drives: AE86, 2x GT86, TE27
Doh
diss7 is offline   Reply With Quote
The Following User Says Thank You to diss7 For This Useful Post:
Asurendra (01-06-2014)
Old 01-06-2014, 04:07 PM   #181
BRZ21
i kill cones.
BRZ21's Avatar
Drives: around cones in a parking lot
I'll admit I only read the first and last pages of this thread but I'm sure I can guess the rest...
here's my take...
I've never owned a car with any aids and sometimes it pisses me off when something intervenes, especially tc when the car falls on its face while merging or something...
with that said, I see a new "crashed my frs, is it totalled?" thread every other week... granted not all are the frs' driver's fault but a lot of times they are... some people think they are "great" drivers instead of just "good" drivers like they really are
overall, because it seems as though there are so many more bad drivers than good ones, people in general have to say things like "ALWAYS leave aids on" just so they don't have to take the chances of coming across a bad driver on a rainy day
2013 SSM BRZ Limited 6MT
BRZ21 is offline   Reply With Quote
The Following 2 Users Say Thank You to BRZ21 For This Useful Post:
phloozy (01-06-2014), TouchMyHonda (01-07-2014)
Old 01-06-2014, 04:16 PM   #182
SoCal909
SoCal909's Avatar
Drives: 2014 WRB BRZ 6MT
well ya done goofed' now
SoCal909 is offline   Reply With Quote
abs for noobs, aids suck, back to the 80's, brakes, driftin'alldayeveryday, i have aids, lots of aids, make believe abs systems, nanny aids, nanny boo-boos, no abs, old school, rock hard abs, waste of time read
Subaru BRZ tS Driving Impressions (Japanese) Gaiakai BRZ Photos, Videos, Wallpapers, Gallery Forum 7 09-13-2013 01:44 PM
Electronic Driving Aids trackmagic Scion FR-S / Toyota 86 GT86 General Forum 20 03-07-2013 07:45 PM
Initial Driving Impressions - BRZ Limited 6MT ShoNUFF BRZ First-Gen (2012+) — General Topics 17 12-21-2012 02:09 AM
FR-S Driving impressions Guaruja Scion FR-S / Toyota 86 GT86 General Forum 30 02-29-2012 05:20 PM
Kota Sasaki Subaru BRZ Driving Impressions illmatic BRZ Photos, Videos, Wallpapers, Gallery Forum 31 01-14-2012 12:24 PM
