Old 01-06-2014, 01:17 AM   #15
Respect BRZ
Old Mechanic
Drives: 2013 Limited BRZ
Originally Posted by Anthonytpt View Post
Please let me know if they get yours up and running. Good luck!
my appt is for next monday morning, so not soon.
Respect BRZ is offline   Reply With Quote
Old 01-06-2014, 01:28 AM   #16
Anthonytpt
Anthonytpt's Avatar
Drives: '13 Argento 6MT FR-S
I'll stay tuned. Mine has been like this since December 2012.
Anthonytpt is offline   Reply With Quote
Old 01-12-2014, 05:48 PM   #17
Vincenttam
WtsTofu
Vincenttam's Avatar
Drives: Ultramarine fr-s
Originally Posted by modena View Post
Well, Looks like a new BIU Controller.
Part is on order and have an appointment for January 6th.
Dealer wanted a full day, (with the Holidays and all) so he has plenty of time, seems like the car needs to be reprogrammed too.
They just wanted to know if I "cut" any wires or added LED's...
(None were added or wires cut)
What's the update on this
Vincenttam is offline   Reply With Quote
Old 01-12-2014, 06:08 PM   #18
Luis_GT
As the title stated: (2013 BRZ)
Upon opening driver, or passenger door the dome light does not turn on.
Proximity key does not turns the dome light on neither.
It works when switched to "On".
Both doors lower the windows and the lights on the door pockets turn on too.
Checked fuses (found 2 in the owners manual) in the engine bay.
Measured the voltage on the dome light and it only outputs 3 volts...
Disconnected the battery for an hour.
Any other fuses I need to hunt down?
Have a dealer appointment on Wednesday for an oil change,
just want to make sure I do not get the "run around" at the dealer.
There's a very thin blue wire, with a little plastic covered in foam near the ECU under the drivers side air vent, the dealership appointed alarm guy accidentally cut that cable and I lost the dome light, I just spliced some new wire and reconnected it and had my dome light back.
Old 01-12-2014, 08:37 PM   #19
modena
modena's Avatar
Drives: BRZ Limited WRB MT
Hopefully I will know tomorrow evening.
My appointment from last week was rescheduled,
(Part was not in and we had a mayor snow and cold spell)
KartBoy SS | BlackVue DR550GW | Valentine1
GrimmSpeed MC Brace | GrimmSpeed Hood Struts
OEM Armrest | OEM STI Badges | 20% Tint
Rydeen duo | Halo's as DRL
Rexpeed Wide Mirrors
modena is offline   Reply With Quote
Old 01-14-2014, 04:34 PM   #20
modena
modena's Avatar
Update, It was the BIU controller
Dealer had an issue after replacing it,
He thought replacing it would do the trick.
It did, but not without reprogramming the modules and resetting all settings.
I had to set the shift light and gear indicators again, so it looks like the BIU control module has an effect on a lot of settings in the car.
All was done under warranty too.
Thumbs up to My Dealer for a job well done!
Old 01-14-2014, 07:59 PM   #21
Vincenttam
WtsTofu
Vincenttam's Avatar
I had a little better luck than you. Went to longo and told them it wasn't functioning. Fixed it under warranty. They had me leave my car there over night. Apparently they had 1 module in stock and gave me a rental. (2014 corolla s auto.) Worst 24 hours of my life, felt like i was driving my fr-s in first gear the whole time. I think it took them a little less than an hour to fix it. Told me the mechanic fixing the problem would come in the next day at 10am, they called me at 10:43am. Guy told me he already had all the paper work done when he called me. They had to replace the board, rewire, and reflash all three of my keys. Even though 1 of them is just a key... Whatever, it was under warranty and the total would of costed me 780$. I'm a happy camper, and no more corolla.
Old 03-13-2014, 12:09 AM   #22
Respect BRZ
Old Mechanic
Got mine fixed today... went in yesterday and they said oh its probably the dome fixture, I said um I doubt it, its all over the forums that the BIU is at fault and they said oh ok, we'll order one overnight come back tomorrow morning and we'll replace it. I'm like ok cool, a dealer that listens to owners... thanks to Riverside Subaru in Little Rock, AR.
Sent from my DROID RAZR using Tapatalk
Old 03-16-2014, 11:53 PM   #23
Respect BRZ
Old Mechanic
Then a day later it quit again... so I checked the dome light fuse and started working again, for about an hour. So I put the incandescent bulb back in and it worked so I put the led back again, didn't work, changed the polarity, and its been working for two days now.
Old 03-17-2014, 06:09 PM   #24
ratters
Drives:
Is the dome light fuse located in the engine bay or under the steering wheel?
Sent from my C6903 using Tapatalk
ratters is offline   Reply With Quote
Old 03-17-2014, 06:27 PM   #25
Respect BRZ
Old Mechanic
In the rh big fuse box in the engine bay. But I think it is more than just the fuse for the light. I think it is for the BIU.
Map/Dome Light Dis-assembly/Phastek Performance LED Dome Light F1point4 DIY (Do-It-Yourself) Guides 9 03-25-2014 09:39 PM
OEM Dome Light Bulb? ScionFR-S Interior Parts (Incl. Lighting) 4 12-09-2013 11:33 AM
FS: Cool White LED Lighting (dome, door, and trunk lights) fourvalleys Interior Parts (Incl. Lighting) 0 11-18-2013 06:55 PM
Interior Dome Light in DOOR mode works in reverse! shaoster Cosmetic Modification (Interior/Exterior/Lighting) 1 04-07-2013 01:37 AM
