Old 01-04-2014, 09:19 PM   #1
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
OEM Oil Temp Sensor Location
Hey guys i was wondering if anyone knew where the stock sensor was located?
Not in terms of it's physical location but in terms of the oil flow, like is it reading the oil returning from the filter, going too or the oil that just chilling in the engine?
230rwhp/184ftlb on 98RON/93AKI
Build thread
Red 86 GTS MT | Sprintex Intercooled Twin Screw SC | Invidia N1 | Mocal 10 row | Invidia Front Pipe | Motiv Overpipe| Enkei RPF01 with Bridgestone RE002s | MCA Blue Coilovers | Radium Catch Can
Khorne is offline   Reply With Quote
Old 01-05-2014, 02:13 PM   #2
HapaHaole
Drives: Grocery cart
Based on the location and the oil lines, it looks like it reads either the temp in or out of the oil filter. OE repair manual does not show a great description, but based on the location of the sensor on the block and the oil flow diagrams it has to be either of those 2 lines.
HapaHaole is offline   Reply With Quote
Old 01-05-2014, 10:36 PM   #3
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Oil temperature is not measured on these cars.
Suberman is offline   Reply With Quote
Old 01-06-2014, 12:02 AM   #4
Khorne
Super 86
Khorne's Avatar
Drives: Red 86 GTS
...Yes it is? With the stock gauges no, but there is an oil temp sensor and the ECU does measure it.
Build thread
Old 01-06-2014, 12:17 AM   #5
stugray
Drives: 2013 GBS BRZ Limited
Logged via OBDII port on my Droid:
The Following User Says Thank You to stugray For This Useful Post:
Suberman (01-06-2014)
Old 01-15-2014, 10:38 PM   #6
Dezoris
Dezoris's Avatar
Sensor plugs into bottom of oil filter sandwich plate.
FT-86 low temp THERMOSTAT ft86-UAE Engine, Exhaust, Transmission 52 08-30-2016 03:46 PM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
STRI DSD SLM II Gauges (boost/oil temp/oil press/water temp/egt) BNIB ziptiedae86 Interior Parts (Incl. Lighting) 0 10-29-2013 11:50 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
water temp driver01 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 30 04-11-2013 02:57 AM
