Old 01-05-2014, 01:40 PM   #43
nelsmar
Originally Posted by jamesm View Post
to be accurate, only 14.7:1 can ever be targeted in closed loop, the logic doesn't work any other way. the values in the closed loop section of the map that *arent* 14.7:1 actually arent targets, they're there to generate trims, but that's another topic for another day.
suffice to say that the ecu can only truly target 14.7:1 in closed loop, even if it acts like it isn't sometimes.
Whic is why there is no reason for subaru I calibrate the oem wideband to such extent.
My flickr - Canibeat
Local magazine scout
Old 01-05-2014, 01:51 PM   #44
jamesm
exactly. they use the resolution around 1 where they need it in closed loop.
Old 01-05-2014, 02:41 PM   #45
1086
1086's Avatar
Drives: UM86 - 6MT
Where do you live? What is your elevation? Perhaps I overlooked that detail, but elevation plays a pretty decent part (amongst other variables of course) in power output.
1086 is offline   Reply With Quote
Old 01-05-2014, 02:42 PM   #46
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
Sea level iirc
Sent from my IBrick
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
1086 (01-05-2014)
Old 01-05-2014, 04:23 PM   #47
Fresh86
Fresh86's Avatar
Drives: 2013 Scion FRS
Why not just purchase a stage 2 tune from ecutek? other people making 190whp on pump gas?
Fresh86 is offline   Reply With Quote
Old 01-05-2014, 04:43 PM   #48
AdrianG
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Why own a car when you can call a taxi?
- AdrianG
AdrianG is offline   Reply With Quote
Old 01-05-2014, 05:23 PM   #49
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
I'm not a tuner but I had a similar 'power ceiling' issue with my car in Dubai.
Long story short - getting past 180whp turned out to be a matter of going for a full, proper exhaust (headers + overpipe + front pipe + mid pipe + back box).
I've had 3 exhaust combos on my car (bit of a hodge podge, sorry):
Combination 1:
Stock headers, overpipe & front pipe + Remus mid pipe & back box
= 181.5 whp
Combination 2:
JDL UEL header + stock overpipe & front pipe + Blitz NurSpec C-TI mid pipe & back box
= 175 whp
Combination 3:
JDL UEL header + JDL Overpipe + HKS Hi Power (catted) front pipe, mid pipe & back box
= 189.9whp.
PS - Panel filter only; AFRs tapering down to 12.7 ish at redline IIRC (opted for a safe-ish, richer tune)
TL;DR Go for a full exhaust man & good luck with your tuning!
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 01-05-2014, 07:00 PM   #50
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
183 is about right for pump gas timings on a Dynojet. Since you didn't up the timing, then you won't really run any more hp race gas or pump. We've hit 192 now on pump with a header, full exhaust, intake. Just remote tune on that same dyno hit 183 as well when that one first rolled up.
@ultra looks like you did a good comparo on the exhaust stuff. We've found that if you're going to do exhaust, the front makes a difference, but the whole system is where it counts. If you match a full 2.5 (and make sure flanges are all lined up on slotted types!) then you get a nice, smooth laminar exhaust and it actually makes power. Just slapping on one piece or another is usually not great since you get abrupt steps and lots of turbulence.
Otherwise on race gas the OP should be able to get it close to 200 with the setup in the sig.
Xero-Limit is offline   Reply With Quote
Old 01-05-2014, 11:22 PM   #51
Fresh86
Fresh86's Avatar
- AdrianG
This has nothing to do with tuning atleast what I said was a solution to his power problem
Old 01-06-2014, 06:53 AM   #52
wparsons
wparsons's Avatar
Unless they made 190whp on the same dyno this guy is using it's irrelevant.
I could tweak the setup so that my car dynos 200whp stock, doesn't mean it's accurate to anyone else.
flickr
Old 01-06-2014, 07:42 AM   #53
AdrianG
The guy is doing his own dyno tuning, comes up to a barrier and asks the community for advice. Your advice is to give up, switch products, and pay someone to do it for him.
Ever heard of the term "built not bought"? Some people enjoy doing things themselves.
- AdrianG
The Following User Says Thank You to AdrianG For This Useful Post:
brn12345 (01-07-2014)
