Old 01-02-2014, 05:30 AM   #1
brn12345
brn12345's Avatar
Got to 183whp - cant get more
So I spent the day at the dyno yesterday trying out various map changes. I started with Shivs Stage 2 1.42b map and the car baselined at 181whp. I then did the following tests and in each case I started out with Stage 2 1.42b and did the stated modification:
T1: Leaned out Primary Open Loop Fueling by 3% to compensate for trims
T2: Modified the Intake VTC by advancing in the higher rpm range (see photo)
T3: Retarded ignition timing by eliminating the advance in the Knock Correction Advance table, basically removing 1.76 advance (see photo)
T4: Flashed Shivs Stage 1 1.42b map
Ok so the results, in T1,T2,T3 the dyno graph was a near mirror image of the baseline Stage 2 1.42b map. In T4 there was a slight gain uptop from 6750 to redline
At this point I am happy with the 183whp but what is bothering me is why the changes I made had no impact on the dyno results. I am starting to think that I ran into a bottle neck that needs to be resolved before more power can be made. I am thinking the up pipe and midpipe are the only stock pieces I am running so they could be causing a bottleneck. My next tests will be with mid pipe replaced.
Attached is a dyno sheet of the baseline Stage 2 1.42b and the best result I got which was with Stage 1 1.42b.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
brn12345 is offline   Reply With Quote
Old 01-02-2014, 05:35 AM   #2
Bahraini86
Bahraini86's Avatar
Drives: Toyota GT86
Dyno looks good and you are making good amount of power. Your secondary cat cud be restricting some flow tho!
'73 240z Triple-Carbed '03 350z Supercharged (455whp) '09 135i Twin-Turbocharged (11.85@188km/hr)
Bahraini86 is offline   Reply With Quote
Old 01-02-2014, 05:43 AM   #3
Fast_Freddy
Drives: Passat
You're planning on replacing the wrong pipe! The oem front (up) pipe is much more restrictive than the mid-pipe due to the oem cat in the front pipe. According to Nameless and Super Sprint the gains from replacing the mid-pipe are slight.
Fast_Freddy is offline   Reply With Quote
Old 01-02-2014, 06:27 AM   #4
s2d4
s2d4's Avatar
Some questions if I may,
1. 4th gear?
2. What fuel?
3. 3% leaned out where?
4. Why the change with intake AVCS only? and also why the reduction?
5. Why did you you removing timing?
Old 01-02-2014, 06:48 AM   #5
FR-S Matt
You need to change out your exhaust up front. Stock exhaust is restrictive.
Old 01-02-2014, 08:04 AM   #6
brn12345
brn12345's Avatar
1. 4th gear?
2. What fuel?
1. Yes 4th
2. VP Motorsport 103
3. In all rev range in the 0.9 to 1.3 load range
4. Testing to see the effect of such changes. None observed.
5. Same as above
Old 01-02-2014, 08:27 AM   #7
s2d4
s2d4's Avatar
1. Yes 4th
5. Same as above
On 103, you should be able to add more timing without knocking, not sure why you are reducing them.
As for the 3%, it looks on the lean side between ~4900rpm to ~6500rpm.
The reduction in intake AVCS, this would take some playing around which I have not done as yet, perhaps try advancing and play with exhaust side as well since you changed the header which is more on the exhaust side?
Old 01-02-2014, 09:53 AM   #8
jamesm
you adjusted the fueling targets to compensate for fuel trims? you should adjust maf scaling to eliminate the trims to begin with, or set the high af learning bucket to 61g/s so they won't apply in open loop. you shouldn't ever have to change the fueling targets if everything else is right.
The Following 2 Users Say Thank You to jamesm For This Useful Post:
brn12345 (01-04-2014), s2d4 (01-02-2014)
Old 01-02-2014, 10:11 AM   #9
s2d4
s2d4's Avatar
What do you think is the reason why tuners change fueling target?
Some of the dynos/logs I've seen shows AFR of up to ~13.5 recently, do you think it is because they haven't scaled the MAF correctly?
Old 01-02-2014, 10:21 AM   #10
jamesm
yes. fueling targets are just that: targets. they will be hit assuming that airflow estimation is correct (ve if sd, maf if maf) and fueling calibration is accurate (di flow rate, port injector scaling, latency, etc.). if the ecu is making fuel volume calculations using inaccurate values, the end result will be off and you'll see fueling error.
some folks change targets to hit the afrs they want to see. that's fine, but your just masking a fueling error issue, and you'll chase your tail until you resolve that.
Old 01-02-2014, 10:23 AM   #11
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
you made 181 on the stage 2 but 183 on a unedited stage1??
IG-Joey_Soul
Old 01-02-2014, 10:32 AM   #12
s2d4
s2d4's Avatar
I believe he is just running a drop in filter, would that warrant maf scaling? Didn't think it would deviate much from stock by just the filter.
Old 01-02-2014, 10:36 AM   #13
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
I was able to achieve 183 whp on my invidia catback and injen intake on the dynoet as well. When you free up the front pipes and overpipe you see more gains
Ny Brz is offline   Reply With Quote
Old 01-02-2014, 10:37 AM   #14
jamesm
i think @mad_sb did some testing where he found the stock maf scaling to be pretty bad even with all stock components.
The Following User Says Thank You to jamesm For This Useful Post:
s2d4 (01-02-2014)
