Old 01-01-2014, 08:40 AM   #15
Pablitomarrero
Pablitomarrero's Avatar
Drives: FR-S 10 series
Originally Posted by maxjedi View Post
Nothing ugly here, 225 is exactly what i would expect from greddy turbo on 7 psi 91 oct and maybe 8-10 hp more on 93. Torque curve is very nice. Greddy kit is for driveability, not fancy dyno numbers.
Cool, thanks guys!! I was just a bit worried that the downpipe modification we had to do affected performance. Now I see not at all
Pablitomarrero is offline   Reply With Quote
Old 01-02-2014, 03:35 PM   #16
Dustin@Dynosty
the ones we have tuned were on E85 and made 313whp at 11psi IIRC
Dustin@Dynosty is offline   Reply With Quote
The Following 2 Users Say Thank You to Dustin@Dynosty For This Useful Post:
Pablitomarrero (01-02-2014), shiro (01-03-2014)
Old 01-02-2014, 03:39 PM   #17
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Originally Posted by Pablitomarrero View Post
My installer called me and told me that they ad finally pieced everything together BUT the downpipe supposedly does not match the perrin overpipe (also have perrin Frontpipe) that I also had installed. He wants to modify the downpipe to match it correctly! Anybody here have a similar problem? I was so excited that I was finally picking it up today after 2 weeks of agony
I would find a new installer or modify the Perrin overpipe instead of modifying the Greddy downpipe. With the downpipe installed to the turbo and the overpipe and frontpipe loosely installed, you should be able to manipulate them enough to get the clearance required.
Old 01-03-2014, 02:25 AM   #18
Evasive Motorsports
Evasive Motorsports's Avatar
Drives: 2012 FR-S and BR-Z
Send a message via AIM to Evasive Motorsports
Originally Posted by SmsAlSuwaidi View Post
sadly greddy and hks aren't what they used to be
Most of the time it isn't Greddy or HKS. They do the R&D with stock cars so most of it works with oem set ups. Also I bet Perrin didn't design the over pipes when the Greddy turbo kit came to mind. We had this problem with others brands as well.
-Randy
Evasive Motorsports is offline   Reply With Quote
The Following User Says Thank You to Evasive Motorsports For This Useful Post:
shiro (01-03-2014)
Old 01-03-2014, 02:34 AM   #19
Evasive Motorsports
@Pablitomarrero We had the same problem. Some are a hit or miss. We got some that worked and some needed fabrication. Good Luck but its a easy fix not that bad.
-Randy
Pablitomarrero (01-03-2014)
Old 01-03-2014, 02:56 AM   #20
Pablitomarrero
-Randy
The fix actually took less time than I thought. It took them a bit less than an hour to solve the issue. They just took some measurements and cut and resoldered the downpipe to the perfect shape. Thanks for the help guys! The car is a whole different animal now!
The Following User Says Thank You to Pablitomarrero For This Useful Post:
kombatlion (01-03-2014)
Old 01-03-2014, 03:06 AM   #21
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
-Randy
I totally understand that, but i stated that comment referring to what hks and greddy were back in 199x
Sent from my IBrick
Old 01-03-2014, 11:07 AM   #22
shiro
shiro's Avatar
Drives: 2013 Scion FR-S, 2014 Lexus IS350
Originally Posted by Kelbyat07 View Post
Let me know how you like your Greddy turbo, I am thinking about getting one.
I love the kit. It did seem harder to bolt on in some places since some tools/angles are too friendly. But the kit is sold. Don't freak out that the kit doesn't have a BOV port. It originally wasn't designed for it but you can always install one.
And honestly, any FI kit you go with will spice up the car like it was meant to be. Enjoy
Same here buddy. FullBlown tuned my Greddy kit on E85 @ 11psi doing just over 300whp. Feels like a small rocket ship if you ask me
-Randy
I agree with you on that Randy. It is a gamble when putting an aftermarket part with another aftermarket part and not an OEM. But majority of the time the parts can work together. It's important to check before making the purchase though.
shiro is offline   Reply With Quote
Old 01-03-2014, 11:13 AM   #23
Pablitomarrero
Well im running 225 on mustang dyno with just 7psi. It already feels like a rocket ship!! I installed the FV valve and the sound is just... Amazing!!! I still get the compresson surge sound when under high load with moderate RPM and the swoosh soun when WOT. Both sounds are amazing . I must say that combining this kit with perrin op and frontpipe was the best idea ever... The sound is... 8==D~
This is probably due to the fact that Perrin has one of the best exhaust notes and the Turbo kind of quiets it down. So its a very deep gruble, loud enough when steping on it and very aggressive and sexy feel. NO DRONE!! Im super happy with this. Best part? Has a stock look to it!!!
Old 01-03-2014, 12:39 PM   #24
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
Congratulations Pablito!!!!! if you need to need for more horses fuel pump and injectors tuning and you be good to go to be at 260 or 270ishh!!
kombatlion is offline   Reply With Quote
Old 01-03-2014, 01:21 PM   #25
Pablitomarrero
meh...ill probably leave them stock and install a meth kit and increase psi . I hate to mess w fuel... itll start to stink and use too much gas
Old 01-06-2014, 12:15 PM   #26
shiro
shiro's Avatar
That's great! Sounds like a really nice setup too. I will be putting an EVO 3 exhaust on my kit so I'm hoping it will sound good.
Old 01-06-2014, 06:24 PM   #27
Pablitomarrero
Only problem is I keep getting this check engine light... Seems to be MAP sensor an O2 sensor. I erase th but pop back up a few days later. Anybody know if i have to actually disable these codes? Will they keep poping back up if i dont?
Old 01-06-2014, 06:33 PM   #28
sw20kosh
Drives: 2013 Black FR-S
Changing injectors (and/or pump) will not cause your car to stink or consume more gas.
You will only consume more gas when WOT when you are pushing more HP through the engine.
Maintaining a water/meth setup is a hassle which I learned the hard way. It also adds a layer of complexity which will destroy your engine if it should ever fail/run out. PM me if you would like to hear more about my experiences with meth injection.
The Following User Says Thank You to sw20kosh For This Useful Post:
Pablitomarrero (01-07-2014)
Greddy turbo MikesFRS Forced Induction 104 11-24-2014 11:47 PM
Greddy turbo kit and AVO world turbo kit SPECIAL PRICING! THMotorsports.com Forced Induction 129 07-24-2014 06:51 PM
HKS Supercharger / Avo Turbo Kit / Greddy Turbo Kit - All Available at Import DPS!! rickspecd Forced Induction 4 07-12-2013 11:50 AM
Greddy turbo clayrush Forced Induction 12 12-18-2012 12:19 PM
GReddy in on-deck circle. GReddy turbo for FR-S/BRZ first up. 2JZ-DNA Engine, Exhaust, Transmission 46 04-19-2012 08:13 PM
