Old 01-02-2014, 06:01 PM   #1
sid3way5
Drives: 13 wrb brz greddy evo3 catback.....
faulty a/f o2 sensor
my check engine light came on the code said faulty heater in the a/f o2sensor so I had a new one installed at the dealer and the code is still there they think its the relay....my car is boosted and i have a af guage at idle the car is very rich around 10.9 and its very lean during normal driving trying not to drive it unless I have to... any ideas?
fa20 kit
303/250
sid3way5 is offline   Reply With Quote
Old 01-02-2014, 06:06 PM   #2
kjdd787
Drives:
My boy had the problem in his ms3 a good pro tune solved this problem
Sent from my SCH-I545 using Tapatalk
kjdd787 is offline   Reply With Quote
The Following User Says Thank You to kjdd787 For This Useful Post:
Mr.EvoMR (01-02-2014)
Old 01-02-2014, 08:38 PM   #3
sid3way5
I text my tuner he said to check all the wires from the sensor to the ecu going to let a subie tech look at it sat
fa20 kit
303/250
Old 01-02-2014, 10:18 PM   #4
kjdd787
Drives:
Running lean could be an actual tuning issue
Old 01-04-2014, 09:00 PM   #5
wparsons
wparsons's Avatar
Who did the install on your a/f gauge? Is it tapped into the stock front O2 sensor, or is there an extra sensor installed for it?
It's possible that the wiring for the gauge is mucking things up.
flickr
Old 01-06-2014, 11:06 AM   #6
sid3way5
found the problem the fuse for the o2 sensor blew out changed it drove fine till I was under boost and let off it came back on .. the fuse blew again checked the second o2 sensor that was lower down the down pipe we found it was hitting the engine going to relocate the o2 sensor today... great job by toni at fa20club with the position of the o2 sensor
fa20 kit
303/250
O2 Sensor ? grostoine Engine, Exhaust, Transmission 4 02-21-2016 10:20 PM
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
Stock FA20 Crankshaft Angle Sensor - Anyone know what type of sensor and output? Acree Engine, Exhaust, Transmission 2 08-26-2013 06:39 PM
Passenger elec window faulty with flashing switch GavinAnt Issues | Warranty | Recalls / TSB 4 04-04-2013 02:38 PM
Passenger weight sensor faulty? Trashed675 Issues | Warranty | Recalls / TSB 5 01-27-2013 01:20 PM
