Old 04-04-2013, 02:08 PM   #1
GavinAnt
GavinAnt's Avatar
Drives: BRZ since 25 March, 2013
Passenger elec window faulty with flashing switch
My passenger electric window only operates when I use that door switch (not when I use the drivers door switch) and the window does not automatically slide up after opening door.
In addition, the light in the window switch on the passenger door flashes on and off permanently when the ignition is on
My dealer doesn't know how to fix it - I have one of the first BRZ's in South Africa.
Anyone know how to fix this?
GavinAnt is offline   Reply With Quote
Old 04-04-2013, 02:09 PM   #2
powerj2
powerj2's Avatar
Drives: 2013 Scion FRS
is the auto light blinking?
powerj2 is offline   Reply With Quote
Old 04-04-2013, 02:12 PM   #3
NYNOMAD
Drives: BRZ WRB LTD MAN
roll the window down - keep holding the switch a few more seconds after the window hits bottom then roll the window up again keep holding the switch for a few more seconds after the window reaches the top.
The fix should be in your owners manual... This should work unless it's a faulty switch...
NYNOMAD is offline   Reply With Quote
Old 04-04-2013, 02:24 PM   #4
GavinAnt
GavinAnt's Avatar
Thanks! Did try, didn't work.....
Must be switch!
Old 04-04-2013, 02:38 PM   #5
NYNOMAD
I forget if the car has to be running or not... it might work either way but door needs to be closed.
There is a new window switch available to fix the passenger auto up/down issue Subie Issues | Warranty | Recalls / TSB 51 04-13-2014 02:34 PM
Window switch lights? Narcoden Scion FR-S / Toyota 86 GT86 General Forum 4 05-01-2013 07:17 PM
Passenger window stuck. Marshman Issues | Warranty | Recalls / TSB 6 03-08-2013 07:39 AM
Window scroll button flashing mashal Scion FR-S / Toyota 86 GT86 General Forum 16 02-07-2013 10:26 PM
Passenger weight sensor faulty? Trashed675 Issues | Warranty | Recalls / TSB 5 01-27-2013 01:20 PM
