Old 11-23-2013, 06:40 PM   #295
SasaGT86
Drives: Toyota GT86 Lightning Red MT
It's the plate that is leaking. I was driving a bit faster I would say and when I pulled over started to smoke. And I saw oil dripping on the header. I'm taking the car over to Toyota and then I'll take it from there.
SasaGT86 is offline   Reply With Quote
Old 12-10-2013, 10:01 PM   #296
riironman
riironman's Avatar
Drives: asphalt fr-s
I am smelling oil also. Just hit 20, 000 miles
riironman is offline   Reply With Quote
Old 12-20-2013, 08:35 AM   #297
Extreme86
Live Free, Drive Hard
Extreme86's Avatar
Drives: 13 BRZ, 19 WRX, 10 GMC, 20 RAV4
Noticed mine leaking at 16,500 miles. Posted a DIY fix here: http://www.ft86club.com/forums/showthread.php?t=53949
So far, no leaks!
Extreme86 is offline   Reply With Quote
Old 12-30-2013, 01:59 PM   #298
ducky106
Drives: Scion FRS
i took my frs to toyota earlier today and just got a call saying its actually the valve cover gasket leaking and are replacing that. Hopefully this fixes it
Update: 12/31/13
Just got the car back from toyota and it turns out the main problem was a ring seal around the cam shaft was leaking causing it too look like the plate covering the vacuum pump was leaking. Here's the official write up from toyota.
ducky106 is offline   Reply With Quote
The Following 2 Users Say Thank You to ducky106 For This Useful Post:
Marrk (12-30-2013), pszuvela (02-11-2014)
Old 12-31-2013, 12:29 PM   #299
FV
FV's Avatar
Drives: 2007 Honda S2000, 2013 BRZ LMT
I have oil leaking also but it's from my drivers side, near the drivers seat. Does anyone know why this is? Never performed a oil change, car has 3200 miles.
Sent from my Samsung Galaxy S3 using Tapatalk 2.
FV is offline   Reply With Quote
Old 12-31-2013, 03:15 PM   #300
riironman
riironman's Avatar
My cam plate is leaking. Toyota is order parts to fix it
Old 12-31-2013, 04:49 PM   #301
I can't get a "fix" on where that is....?? ..
Do you have a backed out picture or a more detailed description .. ??
Old 12-31-2013, 04:59 PM   #302
FV
FV's Avatar
I'm going to get my car on a jack tomorrow and upload better pictures. Thanks for looking!
Old 01-20-2014, 08:42 AM   #303
Grimlock
Grimlock's Avatar
Drives: BRZ and NA
Has anyone noticed that the plate (from the outside) on the 2014 cars looks different than on the 2013s? I wish I took a pic when I was at the dealer. Did they make a running change?
Grimlock is offline   Reply With Quote
The Following 2 Users Say Thank You to Grimlock For This Useful Post:
Clipdat (01-21-2014), Marrk (01-20-2014)
Old 01-20-2014, 01:41 PM   #304
Marrk
Drives: Honda Fit
^^This could be interesting.
Marrk is offline   Reply With Quote
Old 01-21-2014, 02:21 PM   #305
pszuvela
pszuvela's Avatar
Drives: 2013 BRZ Limited - Manual, WRB
My plate has the leak. Quite a bit of oil actually. Bought it in December 2012. I noticed the smell a month or so ago but tried to ignore it thinking I was just hyper-sensitive to the smell of burning oil. Now after some more driving and more smell I checked it yesterday and found this to be the issue.
I've read every post in this thread and I encourage others to as well. There are lots of DIY options mentioned as well as botched dealership "repairs". As for me, I plan to take it to my local dealership and work with the same service writer who did my chirpy fuel pump repair. I'll give them one shot to get it right and if it leaks after that, I'll fix it myself. At least this way SOA will have another documented case.
Thanks to everyone in this thread for posting up their experiences. Great thread!
pszuvela is offline   Reply With Quote
The Following 2 Users Say Thank You to pszuvela For This Useful Post:
Clipdat (01-21-2014), Lonewolf (01-21-2014)
Old 01-21-2014, 03:08 PM   #306
Tt3Sheppard
Tt3Sheppard's Avatar
Drives: Whiteout FR-S
Originally Posted by pszuvela View Post
My plate has the leak. Quite a bit of oil actually. Bought it in December 2012. I noticed the smell a month or so ago but tried to ignore it thinking I was just hyper-sensitive to the smell of burning oil. Now after some more driving and more smell I checked it yesterdat and found this to be the issue.
I've been noticing a burning smell after I turn the car off. Smells like rubber or even clutch. Could this been the reason?
2013 Ford Focus St
2013 Scion FR-S
2007 Honda Civic Si
2003 Acura RSX Type-S
1998 Ford Escort ZX2
Tt3Sheppard is offline   Reply With Quote
Old 01-21-2014, 07:14 PM   #307
Fender0122
Drives: 2013 BRZ Limited SWP 6MT
Yup definitely have a leak. Havent driven it much but the last time it smelled real bad. Too cold to deal with it today but I'm sure as sht not going to take it to the dealer for a glob of hondabond. Oh well, now I feel bad I didnt do my own 5k mile check. Got it with 3.4k on it but it pretty much had its 5k check then.
OVR-SCCA Course Design and SSSI
Fender0122 is offline   Reply With Quote
Old 01-24-2014, 08:50 PM   #308
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
I get the same smell when I'm stopped at a light or after I turn off the car especially on the passenger side. For the longest time I thought I was burning my clutch even causing me to change my shifting habits. Looks like this oil leak is the culprit after finding drops of oil on the exhaust manifold in the cam plate area. Mine only has over 2,000 miles.
ronboogieon is offline   Reply With Quote
Still Leaking? 636 Issues | Warranty | Recalls / TSB 15 01-11-2013 03:41 PM
Leaking Oil? 636 Issues | Warranty | Recalls / TSB 11 01-05-2013 04:43 PM
Leaking front left shock Xauterus AUSTRALIA 10 11-06-2012 04:15 PM
Tires keep leaking EvoXDD Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 08-29-2012 03:03 AM
Brake Light Leaking Covered in Condensation Smokinbuffalo BRZ First-Gen (2012+) — General Topics 9 06-12-2012 04:43 PM
