Old 12-29-2013, 12:15 PM   #1
WorkoArt
Wheel Directory: Gram Lights 57Xtremes 18x8.5 +45/18x9.5 +40
Took over 9 months to get my Gram Lights 57Xtremes 18x8.5 +45 F 18x9.5 +40 R with Michelin pilot sport A/S 3 225/45/18 F 255/40/18 rear. Other mods: KW V3 coilovers, Injen cold air intake, Perrin cat-back exhaust, Stance rear control arms. Here are some shots to show fitment. Note, I raised the rear about 1/2" after these shots were taken due to some rubbing on the top of the wheel well.
WorkoArt is offline   Reply With Quote
The Following 3 Users Say Thank You to WorkoArt For This Useful Post:
DrDuquette (01-04-2014), hasanaltan (09-20-2015), SkAsphalt (12-31-2013)
Old 12-30-2013, 10:04 PM   #2
DarrenDriven
NW Region Moderator
DarrenDriven's Avatar
Drives: FR-S No More
Added to the Wheel Directory:
http://tinyurl.com/86wheels
Old 12-31-2013, 03:56 PM   #3
toysub
Drives: DGM
Nice and neat!
toysub is offline   Reply With Quote
Old 01-02-2014, 10:39 AM   #4
ironsurfer129
Drives: Whiteout FR-S
Will this set up fit stock suspension? I don't plan on messing with my suspension just yet so would like input on this.
Thanks
ironsurfer129 is offline   Reply With Quote
Old 01-02-2014, 10:49 AM   #5
BRZFern
Drives: 2013 SSM BRZ
18's in SP SPEC? How did you get your hands on these? Congrats looks fantastic!
BRZFern is offline   Reply With Quote
Old 01-03-2014, 11:14 AM   #6
MyRx
MyRx's Avatar
Mind taking a close-up pic of the front and rear's lips? I like how the tires sit right up on the lips. I have 18" 57x w/ 225/40 f and 245/35 r Michelins Pilots and I have lips. Looking for new Michelins and wanting to get rid of the stretched look. Yours I like. I just want to see if your 57x have different lips than mine. Then I can decide 245/40 f and 265 or 275/35 rears. TIA, looks great!
Old 01-04-2014, 08:37 AM   #7
WorkoArt
I used several charts/tools provided by this incredible thread when deciding on my setup for wheels/offset/ride height/tire size etc. I am including some useful information here. Just glancing at the chart, with stock height, your fitment may actually be a bit more flush than mine since I am lowered. I can't comment on what the gap would be (I would imagine just fine but don't take my word for it, I had the coilovers installed after only 800 miles on the car). Use this link, as I found it pretty helpful: http://www.frsproject.com/tire_size.php and a few others (repost from the beginning of this thread):
Fuji Online Shopping Simulator
Tire Rack Simulator
Tire Size Calculator (miata.net)
Wheel/Tire Size Comparer Light (rimsntires.com)
Wheel Offset Calculator (1010tires.com)
Wheel Weight Topic (m3post.com)
WillTheyFit.com
Also, the chart at the first page of this thread.
Last edited by WorkoArt; 01-04-2014 at 08:39 AM. Reason: chart didn't paste properly
Old 01-04-2014, 09:04 AM   #8
WorkoArt
In regards to getting my hands on 18's in SP SPEC...it wasn't easy. Shopped around quite a bit and knew that it wasn't going to be easy/quick. Ended up speaking with the guys at Vividracing.com and they said that the way it works is Rays in Japan will not machine these until there is multiple orders. I have no idea if it takes 10 or 20 or what, all I know is it was very painful having to wait nine months for these babies. Worth the wait, but I was expecting more like 4-5 months at most. Rays takes their time but they are incredibly well made.
Old 01-04-2014, 09:06 AM   #9
WorkoArt
I'll get some shots of the lips later on and post. The 225's are a tad "stretched" up front but I'll get a shot of front and back for you to have a look.
Old 01-04-2014, 01:04 PM   #10
WorkoArt
Close-ups
Hopefully this gives you what you were looking for regarding the lips. I took these quick. Hope it helps. First three are Front next three are Rear shots.
The Following User Says Thank You to WorkoArt For This Useful Post:
hasanaltan (10-07-2015)
Old 10-26-2016, 10:37 AM   #11
Daver
Can't get a straight answer Elsewhere so I'm asking here! I have the same wheel set up (18x8.5+45 F 18x9.5+40 R) and need to know if I need spacers, and if so on F, R, or both? How about hubcentric rings? my tire intentions are 235/40/18 and 265/35/18
Anyone give me a confirmed answer?
Daver is offline   Reply With Quote
Old 10-26-2016, 12:42 PM   #12
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Can't confirm with out more info. Do you have coilovers? LCA? Camber adjustment?
Hub rings are always a good idea. (unless the wheel is specifically for the 86 platform and already has a hub bore of 56.1)
You do not need spacers in the rear. Some guys are running 18x8.5 +33 front, so, if that is the look you are going for, then yes you will need some in the front.
Old 10-26-2016, 12:54 PM   #13
Daver
I am putting these on Stock Suspension (4x4 I know )
I was under impression I would not have any camber issues untill I mess with suspension? It is my intention to add coilovers and LCA next spring, did not want to write the whole check at once.
Old 10-26-2016, 01:45 PM   #14
Leonardo
Country Boy 4 Life
Leonardo's Avatar
http://www.ft86club.com/forums/showthread.php?t=41083
Read page one.
http://www.ft86club.com/forums/showt...t=41083&page=7
Check out post #90.
IMO, 265 is too big without, at least LCA. I would think about 225/40 & 255/35. In post 90 he has the same size wheels and offset as you. He talks about the closeness in the front and needing coilovers to add room for camber. You could also run a spacer, but that would add poke, which I am assuming is why you went with +45.
I run 245/35 square on staggered wheels.
Edit: You are getting +40 rear, which would push the wheel out 5mm compared to the rear wheel in post 90. Which will be really flush, and convinces me further 265 is too wide without the other suspension parts.
Scion FR-S with 18x8.5 Gram Lights 57xtremes all around? IAmNotTheDriftKing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 50 11-22-2015 03:36 AM
Wheel Directory: Rota RKR 18x8.5 +44 / 18x9.5 +44 Hindi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 99 06-08-2015 08:07 AM
Wheel Directory: Gram Lights 57Xtreme 19x8.5 +43 / 19x9.5 +45 86 FRS Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 35 05-19-2014 12:28 AM
Wheel Directory: BBS RS 18x8.5 +35 / 18x9.5 +35 JRoldy Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 03-07-2014 08:10 AM
FS: Gram Lights 57Xtreme 18x8.5, 18x9.5 funcheung Canada Classifieds 7 09-16-2013 05:01 PM
