Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AFRICA
Old 12-30-2013, 12:16 PM   #1
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Drives: Toyota 86 Vortech SC
Oil Temps
Anyone else monitor oil temps?
I'm a little concerned that mine are running a bit high, and maybe I need an oil cooler.
But I'm basing my judgement on many years ago, so I could be (probably) worried about nothing.
Modern oils are likely much better than I'm used to.
Pre FI, the highest temps I saw were coolant 93°C and oil 120°C
Post FI, I see coolant up to 96°C and oil 130°C.
It's the oil temp that worries me a bit.
130°C seems quite high, and that's not even pushing it really hard.
I'm planning to do some track days soon, and I'm not sure where I stand...
Whadderyathinkanall?
Fish Eagle is offline   Reply With Quote
Old 12-30-2013, 01:12 PM   #2
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Short vid, sorry about the poor quality.
Recorded on my very old Nokia non-smartphone...
Bottom left on the display is oil temp.
You'll see it goes from 100°C to 107°C in under 20secs.
[ame="http://www.youtube.com/watch?v=PlQD6igrb30"]Toyota 86 Oil Temps - YouTube[/ame]
Old 12-30-2013, 03:31 PM   #3
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
If you hitting 130 I would consider oil cooler.
RMS supercharger in Durban I'm maxing at 126 deg, I'm told we good to 130 thereafter oil cooler necessary.
Average oil temps at 106 and coolant 86 degrees
Ryan86 is offline   Reply With Quote
The Following User Says Thank You to Ryan86 For This Useful Post:
Fish Eagle (12-30-2013)
Old 12-30-2013, 04:00 PM   #4
Jacques Blom
Turbo 86
Jacques Blom's Avatar
Drives: Toyota 86 Turbo
I added a oil cooler to my Tubo setup..just to be on the save side..cost about R 4000.00..small price to pay for a safety.. Will monitor my oil and report back.
Jacques Blom is offline   Reply With Quote
The Following User Says Thank You to Jacques Blom For This Useful Post:
Fish Eagle (12-31-2013)
Old 12-31-2013, 02:22 AM   #5
Fish Eagle
Platinum Member
Fish Eagle's Avatar
My ave oil temp is similar, but my coolant runs a bit higher - ave about 89-90°
I wonder if that's my intercooler interfering with the rad a bit? Or slightly different thermostats? @Ryan - do you have an i/c?
I won't get oil temp to 130° on the level no matter how hard I drive.
It's up hills that it gets hot, like having a burn up a mountain pass.
Old 12-31-2013, 07:02 AM   #6
Ryan86
Road Warrior
Ryan86's Avatar
Yes have the Spritex RMS Imtercooled kit.
Pushing .7 bar 188wkw 277Nm
We have tested at intake temps of 40 degrees, max coolant 103 and max oil 126 and kit holds strong.
Dyno testing we ran 3 runs and the highest numbers recorded on run 3, which was good to see the twin screw maintains power.
Your Vortech should be good without any requirement to add on. But if you have spare cash oil cooler won't hurt.
Old 01-05-2014, 01:25 PM   #7
Fish Eagle
Platinum Member
Fish Eagle's Avatar
I did a hard and fast high effort run up a local pass today which is very similar to track conditions - and my oil temp looked great.
Never went over 122°C which I think was a lot cooler than my tyres.
I've seen it up to 130°C, but that's with uphill high speed runs.
It looks like frequent braking, and feathering the throttle through slower corners gives the oil temp a breather.
I'm ready to go on track and see what happens and that'll happen later this month.
I'll start another thread to see it anyone's interested in getting a few 86's together for some track fun.
The Following 2 Users Say Thank You to Fish Eagle For This Useful Post:
JouMaSeHoes (01-06-2014), Ryan86 (01-05-2014)
Old 01-06-2014, 09:37 AM   #8
Jacques Blom
Turbo 86
HI Fish ,Ryan and Eagle ,, I am using Torque Pro ( Android) but not able to find the Oil temp reading. What software do you use or am I missing a set-up screen or do I need to install the Oil PID ?
Old 01-06-2014, 12:00 PM   #9
Fish Eagle
Platinum Member
Fish Eagle's Avatar
With Torque Pro, you need to create the PID.
I don't remember how, but I got the info on this forum somewhere.
I'll see if I can find it again.
Most of the time mine works perfectly, but sometimes everything else works but the oil temp doesn't.
Then I just exit Torque, restart the Torque app, and it's fine again.
Not a big issue, but still a bit of a PITA...
Old 01-06-2014, 12:20 PM   #10
Fish Eagle
Platinum Member
Fish Eagle's Avatar
@Jacques Blom
There ya go, post #2, item #1
http://www.ft86club.com/forums/showthread.php?t=23530
The Following User Says Thank You to Fish Eagle For This Useful Post:
Jacques Blom (01-07-2014)
Old 07-07-2014, 03:03 PM   #11
Jacques Blom
Turbo 86
Hi Fish, ,my oil runs ave 102 degrees..with my oil cooler..
Old 07-07-2014, 05:33 PM   #12
Fish Eagle
Platinum Member
Fish Eagle's Avatar
Interesting. That seems about normal for road use and I also get about that temp when not under heavy load. But my oil temp rises quickly at WOT.
However, I believe that it's important and necessary for oil temp to frequently exceed 100°C to ensure boiling off of any water condensation in the oil.
Since that post of mine in January, I've done several track days and my oil temp maxes out at 130°C at Midvaal, and 126°C at Zwartkops. I think that's where the cooling fans kick in because it seems to not go any higher. I've done quite a bit of research and that's considered OK, but close to the upper limit of what's acceptable.
I still think that I'll fit an oil cooler soon because I'm likely to continue tracking my car.
Old 07-08-2014, 03:12 AM   #13
Die$eL
Die$eL's Avatar
Drives: Toyota MR2 Spyder Turbo
I'm a big believer in oil coolers.
On my turbo spyder it was burning oil quick. Also the oil went black within 100kms.
Added an oil cooler and all sorted. Unfortunately I cant monitor oil temps on that car.
I used the works engineering cooler. If i remember correct it was around R2000.
Chat to Wesley on the forum he can get them.
Die$eL is offline   Reply With Quote
Old 07-22-2014, 06:53 PM   #14
MacJunkie
MacJunkie's Avatar
Drives: Toyota 86 STD
Hi all found this thread interesting, has some insight on the oil temp and pressure on the 86 motors. http://www.ft86club.com/forums/showthread.php?t=63723
MacJunkie is offline   Reply With Quote
HKS Oil Cooler Kit - Keep those oil temps down. - Photos FT-86 SpeedFactory Engine, Exhaust, Transmission 23 08-10-2015 04:08 PM
Reduce under the hood temps? sw20kosh Tracking / Autocross / HPDE / Drifting 24 01-24-2014 09:35 AM
Oil coolers = lower temps + oil starvation? ultra Engine, Exhaust, Transmission 7 12-12-2013 08:41 AM
Intake air temps mrk1 Engine, Exhaust, Transmission 2 07-10-2013 08:56 PM
