Old 12-29-2013, 04:37 PM   #99
airmanmurphy02
Petrol head
airmanmurphy02's Avatar
Drives: 2013 Subaru BRZ
Originally Posted by Sellout View Post
What's with the red light?
Shift light
Sic Semper Tyrannis!
airmanmurphy02 is offline   Reply With Quote
Old 12-29-2013, 05:39 PM   #100
CSG David
CSG David's Avatar
Originally Posted by TylerLieberman View Post
it sounds like you guys were taking it fairly easy in the accleration run. I timed it and it came out to just over 7 seconds dead 0-60.
I'm curious to see how much different it would be with a good lauch and faster shifts. 1st and 2nd gear didnt seem too much different from stock in that video. 3rd and 4th though you can tell.
That shifting method is a preventative measure to reduce DI seal wear.
Set the shift light at 3500 RPM for break-in, but haven't changed it since.
On a side note, we put over 100 miles on track yesterday.
The Following User Says Thank You to CSG David For This Useful Post:
B L U E S L A T E (12-29-2013)
Old 12-29-2013, 05:43 PM   #101
xjohnx
Grip>Slip
xjohnx's Avatar
Is that still an issue with the updated tune? or is this more out of an abundance of caution based on your past experiences?
Old 12-29-2013, 05:50 PM   #102
CSG David
CSG David's Avatar
It is an abundance of caution based on past experience. There isn't much to gain from fast shifts, other than accelerated wear for a minor drop in lap times. Learning to shift properly without mashing on the gas also improves driving smoothness. In fact, Mike's driving has improved dramatically since we got CSG BRZ 1.0.
Old 12-29-2013, 06:01 PM   #103
jjkerr626
jjkerr626's Avatar
Drives: 2013 Subaru BRZ Sport Tech
I recently saw that ECUTek has some features on their tune that allow you to keep the throttle down while shifting, would this hurt the DI seals?
Performance Parts: Innovate Motorsports Supercharger, Mishimoto Oil Cooler, Borla UEL Header, Perrin Cold Air Intake, Perrin Cat Back Exhaust, Perrin Crank Pulley, Perrin Rear Shifter Bushing, Perrin Transmission Bushing, Perrin Master Cylinder Brace, Billet Pro Short Shifter. Handling Parts: Perrin Control Arm Braces, Perrin PSRS Offset Steering System, Perrin 22mm Front & 22mm Rear Sway Bars, Perrin Spherical Rear Endlinks
jjkerr626 is offline   Reply With Quote
Old 12-29-2013, 11:13 PM   #104
CSG Mike
CSG Mike's Avatar
We're not intending to drag race... sorry! Someone else will have to do that video, but I'm sure it'll be done soon...
Old 12-29-2013, 11:32 PM   #105
Skyllz
Drives: Something fun.
How long you expect the stock clutch to last? Street and mild track driving?
Reaaaaaaaaaaaaaaaaaaaaaally interested in this once I get my car out of storage in March(I cry myself to sleep every night, until I remember that my Yaris outside getting eaten by salt while my BRZ is tucked away in a heated garage).
Skyllz is offline   Reply With Quote
The Following User Says Thank You to Skyllz For This Useful Post:
Calum (12-30-2013)
Old 12-29-2013, 11:54 PM   #106
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I understand that.
It's just that its a $5,000 modification and from that video, it doesn't APPEAR to be that much of a difference through the first couple gears. Hopefully somebody does a video where they go all out through the gears.
I don't drag race or anything either but with a bit of a launch and more expedited shifting, I think the difference between stock and this kit would be more apparent.
Old 12-30-2013, 01:17 AM   #107
TrogDor the Burninator
TrogDor the Burninator's Avatar
Drives: 2013 Hot Lava FR-S 6 MT
If you were looking for just straight line speed you'd have to have a built engine or a swap really ...
On the track, you are going to spend most of your time in 3rd and 4th gear at 5k plus rpms ... downshifting to 2nd more rarely and hitting 5th gear if the track has some decent straights ... so the power band for Superchargers or Turbos works out nicely ... You are likely to be in a nice boost level all the way around the track ....
The advantage of the supercharger is the near immediate addition of increased power - albeit in a less dramatic fashion than a turbo. It's a predictable application of power, where as flooring a spooled up turbo can have you sideways before you know it lol.
The current superchargers all seem to stay within what seems to be a level of power the stock engine internals can handle. The clutch might not handle 280hp or more for any length of time. There's also a concern at that power level of the rear axles failing especially if you are lowered significantly ...
5k is a lot of money ... agreed ... But adding 80 to 100 HP to this car and its low weight makes a really quick car in the turns ...
2013 Scion FR-S Hot Lava 6MT Current Mods: KW V3 Coilovers - Raceseng CasCam Plates - Volk TE37SL Black Edition 18x9 +45 - Dunlop Direzza ZIIs 255/35 - Tomei Expreme Ti 60S - FT86 SpeedFactory UEL Catted Header
TrogDor the Burninator is offline   Reply With Quote
Old 12-30-2013, 01:27 AM   #108
ramiram1984
Drives: 2016 STi DGM
I understand that.
Dunno if you've seen this but this is on stock tires and recorded with iPhone
http://www.ft86club.com/forums/showp...&postcount=180
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
Old 12-30-2013, 01:30 AM   #109
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
I've solicited comparos with Vortech and Kraftwerks owners. They all declined. If any Vortech and Kraftwerks owners are interested, please let me know here, and we will cover your track day entry.
Please feel free to quote this post and tag owners that I may be unaware of.
If you volunteer your car, please know that I will be driving your car on track, while taking a full datalog. You are more than welcome to ride shotgun. We're more interested in the data, not lap times, as the lap times can have a large variance depending on the other modifications on your car.
I would volunteer my car, however we are not in the same region
F1point4 is offline   Reply With Quote
Old 12-30-2013, 02:09 AM   #110
CSG Mike
CSG Mike's Avatar
If you're not slipping it, it should have no effect on the clutch's life. A clutch is either engaged, or not engaged (except when you're slipping it, or the clutch can't handle the torque), and neither of those two wear it.
Old 12-30-2013, 02:51 AM   #111
OrbitalEllipses
Drives: Attitude
$5K gets you ~60hp.
Originally Posted by OICU812 View Post
@hamlet
Interesting review, realistic let's face it outsiders especially old dudes are pickier about the whole picture lol.
I still draw ire from my mother about the exhaust I had on the WRX.
Old 12-30-2013, 04:15 AM   #112
The dyno pasted in this thread showed 70 HP gain on a carb tune ... there's more there than 60 HP ....
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Drift-Office : Jackson Racing Supercharger Installed! (Tune Tommorow!) Drift-Office Forced Induction 164 06-20-2014 01:43 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
