Old 12-26-2013, 11:26 PM   #365
AG3NT_5CARFAC3
86 Owners of New England
AG3NT_5CARFAC3's Avatar
Drives: Toyota GT86
Originally Posted by jonzhuxD View Post
How is the switch hooked up? Directly to a relay to the fogs?
yeah :/
AG3NT_5CARFAC3 is offline   Reply With Quote
Old 12-26-2013, 11:42 PM   #366
Mr122
Drives: FRS
Does anyone have a pinout for the pigtail in the USDM fog kit. I plan on tapping into the connector that's already there when I install mine.
Mr122 is offline   Reply With Quote
Old 12-27-2013, 01:16 PM   #367
jonzhuxD
Drives: Ultramarine FR-S
Originally Posted by AG3NT_5CARFAC3 View Post
yeah :/
Sorry buddy, think you're out of luck there.
jonzhuxD is offline   Reply With Quote
Old 07-03-2014, 11:17 PM   #368
burnt_rice
burnt_rice's Avatar
Nonauto fog switch.
Any one order the nonauto switch from Nigel-jdm? The one I received is a momentary switch. Meaning you turn the fog light switch and it springs back to the off position so they don't stay on in my car. Also had to repin the fog light connector on the stalk.
burnt_rice is offline   Reply With Quote
Old 11-09-2014, 08:50 PM   #369
Knshro13
Drives: 10 series FRS
sorry to bring up an old thread.
Did anyone figure out how to wire the Euro-spec GT86 stalk with auto and rear fog to power rear fog? fully functioning with rear fog indicator in dash as well. I am in the US.
I understand there is no rear fog wiring in our cars. but if anyone has figured it out, i would like to know. thanks
Knshro13 is offline   Reply With Quote
Old 11-09-2014, 08:59 PM   #370
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
Can't be done to oem spec unless you change the ecu to euro version. Alternative, is to wire it yourself to the reverse fog switch on the stalk itself. Trust me, it's more trouble than it's worth. In the end I just wired it in series with my front fogs.
Sent from my GT-I9500 using Tapatalk
Tama-Y is offline   Reply With Quote
Old 11-09-2014, 09:22 PM   #371
Knshro13
Thanks for the info. I was already under the impression that i would have to wire it to the stalk myself. I was wondering if anyone had done it. And if so, would the indicator light up?
Thanks again for your reply. i appreciate it
Old 11-09-2014, 09:38 PM   #372
Tama-Y
Tama-Y's Avatar
Drives: ZN6, DC2
Np. I believe the indicator won't light up because that is controlled by the ecu.
Direct wiring, if you get it done. Mind sharing?
Old 11-11-2014, 12:22 PM   #373
nigel-jdmparts
nigel-jdmparts's Avatar
Drives: 86
We have the Toyota 86 stalk for sell @ $80
In stock and ready to ship
nigel-jdmparts is offline   Reply With Quote
Old 05-18-2015, 11:40 AM   #374
SillySaxon
SillySaxon's Avatar
Drives: Sc10n Series FR-S
Not exactly but I know this much:
Black/yellow is ground, and I connected by black ground cable on the switch to that.
Purple is Ignition power, I connected one of the reds to that.
I'm not sure about the white and black/white nor which they correspond to on the switch itself....
I figure as long as you smile while driving the car, you're doing it right.
SillySaxon is offline   Reply With Quote
Old 11-28-2015, 12:52 AM   #375
ganjara
ganjara's Avatar
Drives:
Originally Posted by iketiak View Post
If anyone is planning to install EDM/JDM headlights with auto level, looks like there will not be any harnesses available for plug and play.
Anyone with GT86 headlights can confirm what the grey connector is for? and if they also have the same plastic capped wire bundle?
I have been searching for the exact same wiring! Can't see evidence of it but I'm sure it must be there hidden somewhere. Is back breaking whilst your squished under the steering wheel
Has anyone found the OEM wire harness and been able to successfuly fit the headlight leveling ECU?
ganjara is offline   Reply With Quote
Old 12-11-2015, 11:28 PM   #376
nigel-jdmparts
Drives: 86
We have the 86 Stalk available….
Old 02-05-2016, 07:59 AM   #377
itsAlex
itsAlex's Avatar
Drives: 2016 4Runner / 2016 FR-S
This is where I put my on/off switch:
Attachment 61249
It would just be nice that when the switch is pushed in (fogs are on), the fog indicator on the dash would also come on; I'm sure it can be done, I just dont know what wire I would have to tap into to make that work.
I know your post is fairly old and I don't know if you figured it out yet, but it is possible to do what you're asking as I've managed to accomplish the same thing on my 2011 RAV4. I'm even using the same push button you're using.
itsAlex is offline   Reply With Quote
Old 02-05-2016, 08:41 AM   #378
itsAlex
itsAlex's Avatar
Instrument Panel Illumination
For those who are still trying to get the fog light indicator on the instrument panel to illuminate, this is how you do it via factory operation:
However there are two issues:
1) I'm not sure which relay is the one for the fog lamps, if there are any installed at all. If it is installed, you might hear a "click" in the relay box when you turn on the fog lights via Pin#4 on the stalk.
2) The reason why the fog relay is important to identify is because most of our cars don't come prewired from the factory with fog light harnesses, meaning we need to make/buy our own. By knowing which relay is for the fog lights, we can modify that relay to use as the +12V for our fog lights, as the relay would have done if your car had fog lights from the factory. Here's how I modified my fog relay in my 2011 RAV4:
The relay is still insertable in its slot in the relay box, and the black wire is the +12V for the fog lights, which is running through the firewall.
That's what it looks like installed in the relay box.
The black wire is fished through the firewall to the fog lamps.
The fog light indicator (left side) illuminates when they're turned on. Also note my RAV4 also uses pin #4 on the stalk, so I assume pin#4 is universal on all recent Toyotas?
Who here has LEDs in their fogs/DRLs in their GT? RZ86 Cosmetic Modification (Interior/Exterior/Lighting) 10 03-30-2013 10:54 PM
Fogs wiring; Will this work? Khánh Cosmetic Modification (Interior/Exterior/Lighting) 12 02-16-2013 12:44 PM
BRZ HID Bulb + HID Fogs delusional DIY (Do-It-Yourself) Guides 4 02-05-2013 05:09 AM
new Camry fogs fit the frs?? hislargeness Cosmetic Modification (Interior/Exterior/Lighting) 3 09-26-2012 03:20 AM
for everyone thinking of using rear fogs xpicer Cosmetic Modification (Interior/Exterior/Lighting) 4 07-04-2012 12:53 AM
