Old 12-21-2013, 12:23 PM   #15
whataboutbob
AutoX-10/10ths every run
I wouldn't think doing it early could be bad. I had mine done at 1500 miles just to be sure.
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
scionfrs2014 (12-22-2013)
Old 12-21-2013, 12:24 PM   #16
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Originally Posted by scionfrs2014 View Post
My FR-S will reach break-in soon. Some members suggest to change engine oil after break-in. Is this necessary?
No and not recommended. Old school out of date info.
Change as per Scion specification by time or mileage, whichever first occurs.
Suberman is offline   Reply With Quote
The Following User Says Thank You to Suberman For This Useful Post:
Old 12-21-2013, 12:28 PM   #17
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
In the event there was any casting sand or tiny metal chards floating around I changed at 1000 miles. It might have been unnecessary but since it made me feel better it was worth it.
whaap is offline   Reply With Quote
The Following 2 Users Say Thank You to whaap For This Useful Post:
Gords_zenith (01-03-2014), scionfrs2014 (12-22-2013)
Old 12-21-2013, 12:55 PM   #18
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
All lubricants replaced at 1500 miles. Engine/Tranny/Diff. But that's because I have the tools and means to do it quickly and easily myself.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
Old 12-21-2013, 01:53 PM   #19
bkblitzed
is better than you
bkblitzed's Avatar
Drives: 2013 raven FRS
I did mine at 1050 and the drain plug was covered with shavings.
bkblitzed is offline   Reply With Quote
The Following User Says Thank You to bkblitzed For This Useful Post:
Old 01-03-2014, 02:57 PM   #20
JS + BRZ
Drives: 2010 MS3
Which engine oil/diff oil/tranny and oil filter do you guys use?
Old 01-05-2014, 08:52 AM   #21
csjcsj
Drives: 2014 WRB BRZ Limited
This^^^^
csjcsj is offline   Reply With Quote
Old 01-05-2014, 09:48 AM   #22
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
There was a test done that found metal shavings in the first oil change, and not after that. I went ahead and did mine at 3700 because it was free. Ill start my regular 7500's at the 10k mark. Currently at 6800.
break-in, change, oil
BRZ Engine Break In Brahsbrah BRZ First-Gen (2012+) — General Topics 10 06-17-2013 04:31 PM
oil change after break in? its_the_biz Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 2 02-22-2013 12:26 PM
Fluids change after break-in yomny Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 08-05-2012 02:18 PM
Oil change after break in? oops86 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 32 08-03-2012 01:09 AM
How did you break in your engine? WolfsFang Scion FR-S / Toyota 86 GT86 General Forum 4 06-05-2012 02:12 AM
