Old 12-20-2013, 08:06 PM   #15
raptor87
Drives: 2013 DGM BRZ Ltd
should probably sell the car and get a used wrx
raptor87 is offline   Reply With Quote
Old 12-20-2013, 08:39 PM   #16
1086
1086's Avatar
Drives: UM86 - 6MT
Are you trolling? He means catalytic converter
Someone made this exact thread a few days ago.... use search please. search by Thread title > Keywords can include rumble, exhaust, boxer rumble, etc.
Previous thread (12/16): http://www.ft86club.com/forums/showthread.php?t=53653
Hope this helps,
Track pipes (muffler delete):
http://ft86speedfactory.com/private-...-pipe-973.html
http://ft86speedfactory.com/nameless...track-813.html
Sound changer:
http://ft86speedfactory.com/trd-sound-changer-824.html
1086 is offline   Reply With Quote
Old 12-20-2013, 09:40 PM   #17
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
You want cheap? Make a 30 minute mp3 and play it through your sound system.
Old 12-20-2013, 10:32 PM   #18
mike the snake
Rumble is going to come from unequal length header, no two ways about that.
You can however do as Krulux did, and have a local muffler shop build you an exhaust.
I did this for my BMW and it sounded awesome, all for $250 or so. Catback systems started at $1400 for that car.
Originally Posted by krulux View Post
When I was looking at the off-the-shelf solutions for a nice cat-back exhaust every kit I looked at was about 2-3 times more expensive than what I felt they were worth.
When you get down to it... most are just mufflers and pipe, not exactly expensive items.
( I realize you are paying as much for the time they spent designing the kit, and in some cases name branding, as you are for the parts and profit by the seller)
So instead I went to a local muffler shop that offered custom exhaust services and spent some time telling the shop guy what I wanted... He offered to build a stainless 2.5" cat-back with a Magnaflow muffler and tossed in a set of tips as well, installed for $300.
Once he got started it took him about an hour to remove the old exhaust, custom bend the new pipe and weld/hang the new muffler and tips in place. The guy knew his stuff and wow it made a hell of a difference in sound and flow.
While he was doing the work I looked up the parts he was using and guesstimated he had maybe $200 in parts and likely could get it cheaper than what I found online. Even so... for about an hours work he netted at least $100 in an hour.
After driving the car for a few days I noticed more drone than I wanted during highway driving @ 70-80mph... so I went back to the muffler shop and had him add a 24" resonator for $100 installed. After all was said and down... I now have a custom Magnaflow cat-back for $400... and it sounds fantastic. Excellent rumble for a decent cost.
(btw - I am waiting on my Open Flash Header so I can get more flow and that classic Subaru burble! My exhaust guy quoted me $100 for the header install... soon!!!)
For you $100 you may be able to find a local muffler shop to swap your muffler for something with a little more flow. You may be surprised at how good a deal you can find if you look around... just make sure the shop is reputable.
Also - I got a significant sound change from simply buying a drop-in K&N air filter... nice and throaty growl under the hood over the stock sound...
Old 12-20-2013, 10:48 PM   #19
pche
Guy on internet
Drives: Slowly
Drill some holes! People particly give away their stock axle back these days so it's easily reversible.
pche is offline   Reply With Quote
Old 12-21-2013, 12:29 AM   #20
Originally Posted by KevinTJH View Post
I'd really like to enhance the sound the car makes, eg. louder, more aggressive, more sportscar-like.
What are my options if I'm looking to spend no more than $100?
Thanks in advance.
For a $100, you might try having a muffler shop cut the resonator out of the mid-pipe and weld in a piece of straight pipe.
I have no idea of how that would alter the sound.
Old 12-21-2013, 01:31 AM   #21
Kwise1
Kwise1's Avatar
Drives: Raven FRS
Don't do this it sounds too raspy, already tried and had it put back
Kwise1 is offline   Reply With Quote
The Following User Says Thank You to Kwise1 For This Useful Post:
humfrz (12-21-2013)
Old 12-21-2013, 03:06 AM   #22
Oh, OK .... good to know......
Old 12-21-2013, 03:56 AM   #23
diss7
Drives: AE86, 2x GT86, TE27
Track pipe. That's what I have. Nothing wrong with it.
I'll be cutting out the 2nd cat tomorrow and welding in a straight pipe in its place. I'll try and remember to take some before and after sound clips.
diss7 is offline   Reply With Quote
The Following 2 Users Say Thank You to diss7 For This Useful Post:
KevinTJH (12-24-2013), SKELLINGTON (12-21-2013)
How to get that boxer rumble? ryude Engine, Exhaust, Transmission 45 03-20-2014 02:30 PM
BEST EXHAUST FOR RUMBLE edrokone Engine, Exhaust, Transmission 57 01-08-2014 05:34 PM
Tire rumble noise Mokiki Issues | Warranty | Recalls / TSB 13 02-13-2013 03:59 PM
subaru rumble V1B Engine, Exhaust, Transmission 25 07-13-2012 07:03 AM
Rumble coming from rear end? No Quarter Scion FR-S / Toyota 86 GT86 General Forum 34 06-27-2012 02:14 PM
