#15 |
Drives: 2013 FRS
#16 |
Drives: UM86 - 6MT
Sorry I was just attempting to be comical.
In your post, Total Requirements: basic computer knowledge Great update though! Can't wait to take advantage of it during my break. |
#17 |
Drives: Subaru WRB BRZ Limited
So we will have a choice between the current system and the new 3 button process?
I kind of like the current process better |
#18 |
Drives: FT86
With this updare can you still copy your original ROM from the OFT to the laptop to store a backup copy in case the OFT craps itself or needs a full reset. I would hate to loose my stock ROM
#19 | |
Drives: 2013 FRS
And of course, regardless of what choice you make (preloaded map database vs loading your own maps) your stock file is always saved and available to download and back-up. |
#20 |
AIM4APX
Drives: 2013 WRB BRZ Limited
Ah...after re-reading for the third time I think I have it now...this was just for the initial setup?
"It's very difficult to present technology as an overtly positive sales device to people who want an emotional car" -Chris Harris
#21 |
that'll definitely make for a lot friendlier process for people who aren't into messing with such things. hooking a computer up to your car scares a lot of people away.
#22 |
Drives: 2013 FRS
Hi guys,
Quick update: Finally got this working last night And we also have brand new v1.50 OTS maps ready to launch as well. Perhaps a good trial run for those willing to give this a go would be launch the new maps in Tune File Database (.dev) format. One very nice thing about this new format is that each tune files is no longer a 1.3mb ROM file. Instead, the .dev file a set of instructions given to the OFT processor on how to modify the original/stock ROM. This saves a lot of space and uploading-to-OFT time. For instead, our first database file will contain nearly 50 maps (all C, D, G, I, J, N and O ROMs supported) and will be less than 500k in size. As opposed to 65mb! (50x1.3mb) in standard ROM (.bin) format. In database format, these tune files will not be downloadable (from the OFT) but they will eventually be posted in standard .bin format on the website. That will allow you to view and edit as normal.Later this week, I'll let you guys know when this is ready for ya ![]() Cheers shiv |
#23 |
The Mechanic
Drives: Civic Turbo,FR-S
any plan to add features that control tcs? like removing that 8 second delay for cutting it off... also to adjust hard and soft redlines
#24 |
Drives: 2013 FRS
No plans to do any changes to how TCS is enabled/disabled due to liability concerns. You can already adjust the hardness/softness by either changing the hysteresis value (RPM delta between the on/off rev limits values) and/or by adjusting the ignition advance values in the last RPM breakpoint which provides torque reduction just before fuel cut.
#25 | |
How much flash memory is on the OFT?
#26 |
Drives: 2013 FRS
#27 |
Drives: Scion frs
What will be the differences in the 1.50 ots maps as compared to the 1.34 ?
#28 | |
Drives: 2013 FRS
-Closed loop mapping changes for all gasoline (non E85) ROMs. -AVCS mapping changes for all gasoline (non E85) ROMs. -Added full RomRaider XML support for ZA1JA01O and ZA1JA01I ROMs |
| Key FOB programming | milkesfrs | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 5 | 10-21-2015 03:56 PM |
| Anybody have any experience programming MiniDSP? | mid_life_crisis | Electronics | Audio | NAV | Infotainment | 2 | 12-02-2013 09:07 AM |
