#43 | ||
Hella Flush
Drives: 2013 SWP BRZ
#44 |
Senior Addict
Drives: 86 GT
I'm looking at getting a set of coilovers soon, deciding between this and the Bilstein B14. Anyway....would you mind giving us another short review on how you're getting on with this (especially the ride quality) now that you've had it on for awhile..?
#45 |
i shoot cars
Drives: asphalt grey
this review is exactly what i was looking for. thanks! +1 for another review now that you've had these for a few months
#46 | |
Drives: Raven FR-S
Other than that, no clunking or other weird noises. The car definitely feels more planted with less body roll during hard cornering. If you need help with install, ask OP bc he helped me a lot lol. I used the links below for the install - might help if you choose to DIY. http://www.ft86club.com/forums/showthread.php?t=32414 http://www.ft86club.com/forums/showthread.php?t=12864 |
#47 |
Drives: 2014 Subaru BRZ Limited 6spd
Bumping an old thread here, but I have a question that pertains to this thread:
If I were to install these without changing anything else camber related, would I have issues? I'm only looking to lower the car 1.5in, so not slammed by any means. I'd rather go ahead and order anything else before I get these. Thanks!
2014 BRZ Limited 6speed
-Stock -WRB |
#48 | ||
Drives: 2014 BRZ Limited
You can find more info about it here: http://www.ft86club.com/forums/showt...t=48846&page=5 Quote:
SPC LCA's for the rear are not that expensive at all, and camber bolts for the front are really not that expensive at all either. My recommendation would just be to get them and if you don't end up needing them for some reason, just sell them, lots of people would buy them off these forums. Cheers!
| The Following User Says Thank You to Anomie For This Useful Post: | Ny Brz (12-20-2013) |
#49 | |
12% Done with the car.
Drives: FRS
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
#50 |
Drives: 2013 Premium White, 2006 TL
So a question here. Do you have to use part of the old spring/strut system to install the ST coilovers? Do I need a spring compressor?
#51 | |||
Hella Flush
#52 |
#53 |
#54 |
#55 |
I might be wrong, as I had my shop install my ST's, but I don't think you need a spring compressor. The fronts at least use a helper spring that you should be able to compress by hand if needed.
| The Following User Says Thank You to mike the snake For This Useful Post: | skye67 (12-28-2013) |
#56 |
I have done many spring removals in my younger days. I would unscrew the last few theards with an open ended wrench and let it go sailing across the garage floor. Of course only on light cars. Thanks for the input. Is it worth getting the KW V1 so I don't have to deal with stock caps? Would you guys say the the V1 have the same feel and ride qualities as the ST?
| RS*R Sports-i coilovers - install & review | ultra | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 50 | 07-27-2022 05:29 PM |
| Suspension Review: KW v3 Coilovers | DarrenDriven | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 53 | 07-09-2015 11:42 PM |
| Mann Engineering Coilovers review | l8apexr | CANADA | 10 | 03-11-2014 12:11 PM |
| FR-S Coilovers Review | sraggs42 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 8 | 05-14-2013 12:16 PM |
| Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 04-27-2013 03:50 PM |
