Old 12-17-2013, 10:32 PM   #43
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Originally Posted by Ryan86 View Post
Bill, you not going to believe, after 2 weeks of a fixed no leak SC, CEL came on PO351 Ignition Coil Primary/secondary circuit.
Coil pack issues. Well this is the second one if have seen on the FRS/BRZ, luckily the front coli packs are easier to get too. Though why they are failing is a good question, but then again I have seen them fail on the STI and WRX also, so hard to say.
As for what to notice when it happens. Usually at very high RPM, 5500+ under full load you will feel a blip in power consistently at the same RPM. At first there may be no CEL, but as you continue to drive it will get worse and worse and finally start throwing the check engine lights for one of the following codes.
P0351, P0352, P0353, P0354, which are all faulty coil packs, each one referring to each specific cylinder. Usually the spark plug is fine when replacing the coil, but you can check while you are there.
Cheers,
William Knose
The Following User Says Thank You to DeliciousTuning For This Useful Post:
Ryan86 (12-17-2013)
Old 12-17-2013, 11:14 PM   #44
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Hey Bill
Car going into Toyota tomorrow, change pack 1 and I will just replace plugs same time while at it.
I opted to try out the HKS intake duct to replace the cone. Is this where you picking up issues with intake?
Ryan86 is offline   Reply With Quote
Old 12-17-2013, 11:22 PM   #45
sw20kosh
Drives: 2013 Black FR-S
Cheers,
William Knose
Are you able to see anything in the logs to indicate this is happening? The only hiccup I have experienced is at 6800 rpms every single time but in the logs I saw 2-3 deg of timing being pulled right there.
Old 12-17-2013, 11:30 PM   #46
whataboutbob
AutoX-10/10ths every run
Finally got a chance to look at the logs again. Basically the timing is going flat at this point. I also believe there maybe an airflow limitation on the intake, though I can not verify that, but the airflow values are also pretty flat at this point.
I have another intake from a reputable vendor coming in that I will be testing on my vehicle soon. Along with the a supercharger or two or three.
Also working on some turbo kit tunes next. AVO is one we have been developing with multiple boost map options. But we have a coupe other kits we are looking into also.
Lot of new developments for next year so keep an eye out.
Cheers,
William Knose
Is that two or three list full yet?
Build thread:Here
Old 12-17-2013, 11:47 PM   #47
DriftEm
DriftEm's Avatar
Cheers,
William Knose
Mmmmm new intake, me want
DriftEm is offline   Reply With Quote
Old 12-20-2013, 12:40 PM   #48
lex tech
Drives: 2005 kia spectra 5, 2004ford tauras
Wrxgoose made 265whp on a dyno dynamics with a header back perrin exhaust, the 75mm pulley,ecu trek(not race rom), the injectors supplied with the innovate kit and a good tune. That's on pump gas. With e85 I would expect a little more. With e85 do you plan on upgrading the injectors. The stock injectors will hold back power. How is the afr.
lex tech is offline   Reply With Quote
Old 12-20-2013, 03:35 PM   #49
xjohnx
Grip>Slip
xjohnx's Avatar
The innovate kit doesn't come with injectors.
Stock injectors are good to 300+ whp, as demonstrated by @DeliciousTuning
http://delicioustuning.com/node/247
Old 12-20-2013, 03:50 PM   #50
OrbitalEllipses
Drives: Attitude
His dynos were exceptional for his modification level.
Old 12-20-2013, 06:12 PM   #51
wrxgoose
WUB WUB
Drives: 2013 Firestorm
it was the FA20 Club kit that came with injectors and a pump.
wrxgoose is offline   Reply With Quote
Old 12-20-2013, 06:21 PM   #52
Astroboy
Astroboy's Avatar
Drives: None
I'm still debating on weather getting this or the fa20club turbo, I prefer feeling power instantly with a sc. 300 on this charger is impressive.
Sent from my LG-D800 using Tapatalk
Astroboy is offline   Reply With Quote
Old 12-20-2013, 08:46 PM   #53
xjohnx
Grip>Slip
xjohnx's Avatar
I'll be going back to stock injectors tomorrow (assuming the tune shows up)
Old 12-23-2013, 04:37 PM   #54
mad_sb
Drives: 2013 Asphalt FR-S
Cheers,
William Knose
Are you bumping into the 200g/s maf limit by chance? You should be getting close if not over.. but I would imagine you have already raised that limit though.
Old 12-23-2013, 08:31 PM   #55
evo4g63
evo4g63's Avatar
Drives: 2016 Subaru WRX
@DeliciousTuning what is the max you have seen on this kit with e85 and no IC?
-2016 Subaru WRX
-2013 Scion FR-S: Wastegated Vortech V3'd, E85 SOLD
evo4g63 is offline   Reply With Quote
Old 12-23-2013, 09:56 PM   #56
DriftEm
DriftEm's Avatar
http://www.delicioustuning.com/node/152
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
>>>VORTECH SUPERCHARGER KIT w/ PERRIN ECUTEK TUNE ~ ONE Kit IN STOCK - Ready to ship! Circuit Motorsports Forced Induction 91 10-24-2013 12:07 PM
Delicious Tuning: Offering Innovate Supercharger Stage 1 "Tuner" EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 24 09-20-2013 03:04 PM
Delicious Tuning: FlexFuel Innovate Supercharger EcuTeK Maps DeliciousTuning Engine, Exhaust, Bolt-Ons 1 09-13-2013 01:34 AM
p000d CEL+Innovate supercharger MattF Forced Induction 13 08-16-2013 12:22 AM
