Old 08-12-2013, 09:30 AM   #43
Ny Brz
Hella Flush
Ny Brz's Avatar
Drives: 2013 SWP BRZ
Originally Posted by styl3z View Post
Is that the lowest you can go? Looks good! Thinking about getting the same coilovers.
I have about 3 threads left, so it can be lower. The cols have settled more and I will take more pics when are my turbo goes in hopefully this weekend.
Originally Posted by console_cowboy View Post
You can't use camber bolts in the rear, although some people have tried. I would not recommend the camber bolt in the rear method. The two best ways to adjust rear camber are the whiteline camber adjustment bushings or any of the various control arms. Personally, I like the SPC control arms due to their cost, factory look, and ease of adjustment. They won't adjust as far, only +-2 deg, but I like how the adjustment point is towards the outside edge of the arm.
Absolutely correct, I am running the Oem crash camber bolts on the front and am looking into the rear LCAs but car is handling awesome and have no rubbing issues with the back. Maybe considering Stance or Spc I'll compare some others as well.
Ny Brz is offline   Reply With Quote
Old 10-28-2013, 11:16 PM   #44
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
Originally Posted by Ny Brz View Post
review is added to front page..sorry it took so long
I'm looking at getting a set of coilovers soon, deciding between this and the Bilstein B14. Anyway....would you mind giving us another short review on how you're getting on with this (especially the ride quality) now that you've had it on for awhile..?
Fizz is offline   Reply With Quote
Old 10-28-2013, 11:36 PM   #45
mokytron
i shoot cars
mokytron's Avatar
Drives: asphalt grey
this review is exactly what i was looking for. thanks! +1 for another review now that you've had these for a few months
my automotive portfolios:
kevinkinguy.com
flickr
mokytron is offline   Reply With Quote
Old 10-29-2013, 12:01 AM   #46
kchiang4200
Drives: Raven FR-S
I'm not the OP, but I've had these for ~900 miles. The ride feels almost like stock, just a little stiffer, so it gets a little bouncy if you drive through a series of bumps - but the ride pretty much feels stock.
Other than that, no clunking or other weird noises. The car definitely feels more planted with less body roll during hard cornering. If you need help with install, ask OP bc he helped me a lot lol. I used the links below for the install - might help if you choose to DIY.
http://www.ft86club.com/forums/showthread.php?t=32414
http://www.ft86club.com/forums/showthread.php?t=12864
kchiang4200 is offline   Reply With Quote
The Following 3 Users Say Thank You to kchiang4200 For This Useful Post:
akahenry (06-11-2014), Fizz (10-29-2013), Ny Brz (12-20-2013)
Old 12-19-2013, 09:50 AM   #47
TchDwnUGA
TchDwnUGA's Avatar
Drives: 2014 Subaru BRZ Limited 6spd
Bumping an old thread here, but I have a question that pertains to this thread:
If I were to install these without changing anything else camber related, would I have issues? I'm only looking to lower the car 1.5in, so not slammed by any means. I'd rather go ahead and order anything else before I get these.
Thanks!
2014 BRZ Limited 6speed
-Stock
-WRB
TchDwnUGA is offline   Reply With Quote
Old 12-19-2013, 11:00 AM   #48
Anomie
Anomie's Avatar
Drives: 2014 BRZ Limited
Some info that may be helpful to you when deciding between them, or may not be. But apparently the B14's have a wider spring than most coilovers (closer to OEM width) so if you're going with coilovers for added inner clearance for wide rims, you could possible have some rubbing issues that you wouldn't with the ST's (depending on widths, offsets, camber, etc).
You can find more info about it here:
http://www.ft86club.com/forums/showt...t=48846&page=5
Thanks!
A lot of people will ask you what you are planning on using your car for in order to answer this question (DD/track/both/etc). Personally, I would just spend the little bit of extra money and correct the camber so I don't have to worry about it and so I can get the car aligned perfectly.
SPC LCA's for the rear are not that expensive at all, and camber bolts for the front are really not that expensive at all either. My recommendation would just be to get them and if you don't end up needing them for some reason, just sell them, lots of people would buy them off these forums.
Cheers!
Anomie is offline   Reply With Quote
The Following User Says Thank You to Anomie For This Useful Post:
Ny Brz (12-20-2013)
Old 12-20-2013, 05:29 AM   #49
enjoi23
12% Done with the car.
enjoi23's Avatar
Drives: FRS
I am running 18x8.75+35 on 235/40. I have about 3 threads to the bottom so there is room to drop more on the front just a bit, the rears have 15 more on the thread count. the rears in the pictures i have posted are with 11 thread cound i raised it a bit more.
If you need something for DD i would recommend these thus far.
So would you recommend this for spirited driving? I plan to eventually get into autox with this car. I'm running 18x9.5 all the way around and want to just get rid of the wheel gap really, not trying to go too low.
HOUSTON TEXAS FR-S/BRZ OWNERS - https://www.facebook.com/groups/houston86/
enjoi23 is offline   Reply With Quote
Old 12-20-2013, 10:35 AM   #50
DrDuquette
DrDuquette's Avatar
Drives: 2013 Premium White, 2006 TL
So a question here. Do you have to use part of the old spring/strut system to install the ST coilovers? Do I need a spring compressor?
DrDuquette is offline   Reply With Quote
Old 12-20-2013, 10:42 AM   #51
Ny Brz
Hella Flush
Ny Brz's Avatar
Cheers!
Exactly depending on you setup and how aggressive you want to go you should consider a camber kit for correction, I am actually going with a wider setup this season since my turbo kit is going in so I'll need a set of LCAs
Spirted driving would be ok, but if you have any serious plans in the future for really tracking and are serious about it save your money for some KW3s
Thanks!
The only thing I would highly recommend is the front crash bolts- if I remember they are 20 something dollars and makes sense to get them when you install the coils
Old 12-20-2013, 05:58 PM   #52
Chee-Hu
Chee-Hu's Avatar
Negative on spring compressor, I would assume since it'll replace the whole shock/springs.
Chee-Hu is offline   Reply With Quote
Old 12-20-2013, 07:27 PM   #53
merino_frs
merino_frs's Avatar
You will need to use your stock top mount. So yes, you will need a spring compressor.
merino_frs is offline   Reply With Quote
Old 12-20-2013, 11:19 PM   #54
DrDuquette
DrDuquette's Avatar
Are there aftermarket top mounts?
Old 12-20-2013, 11:26 PM   #55
mike the snake
I might be wrong, as I had my shop install my ST's, but I don't think you need a spring compressor. The fronts at least use a helper spring that you should be able to compress by hand if needed.
The Following User Says Thank You to mike the snake For This Useful Post:
skye67 (12-28-2013)
Old 12-21-2013, 12:57 PM   #56
DrDuquette
DrDuquette's Avatar
I have done many spring removals in my younger days. I would unscrew the last few theards with an open ended wrench and let it go sailing across the garage floor. Of course only on light cars. Thanks for the input. Is it worth getting the KW V1 so I don't have to deal with stock caps? Would you guys say the the V1 have the same feel and ride qualities as the ST?
RS*R Sports-i coilovers - install & review ultra Suspension | Chassis | Brakes -- Sponsored by 949 Racing 50 07-27-2022 06:29 PM
Suspension Review: KW v3 Coilovers DarrenDriven Suspension | Chassis | Brakes -- Sponsored by 949 Racing 53 07-10-2015 12:42 AM
Mann Engineering Coilovers review l8apexr CANADA 10 03-11-2014 01:11 PM
FR-S Coilovers Review sraggs42 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 05-14-2013 01:16 PM
Who likes blue? FT-86 SpeedFactory Review - Standard R3 Coilovers FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 04-27-2013 04:50 PM
