Old 12-06-2013, 04:28 PM   #463
ML
ML's Avatar
Drives: 13 White MT FR-S
No it is not necessary.
There is a place in the main settings to enter custom PIDs
Old 12-06-2013, 04:40 PM   #464
Malt
Drives: 2015 WRX
Originally Posted by CBR600RR View Post
Torque app newb questions:
Is it necessary to remove the OBD II bluetooth adaptor every time I park my car?
How do I enter PIDs? ex/oil temp
Just a fyi, you need torque pro to enter in custom pids.
Sent from my SCH-R970C using Tapatalk
Malt is offline   Reply With Quote
Old 12-06-2013, 04:58 PM   #465
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
It's on the first page of this thread: http://www.ft86club.com/forums/showt...%2C+oil%2C+pid
And pulling it out depends on the model. Mine has an auto-sensing shutoff so it doesn't drain the battery.
mike_ekim1024 is offline   Reply With Quote
Old 12-06-2013, 05:07 PM   #466
mike_ekim1024
Max temps for oil and coolant?
I'm tweaking my Torque display and have come across a few discrepancies regarding fluid temps.
I did a short drive around and have these temps (it's 60F to 70F here):
Oil Temp: 208.4F
Coolant: 192.2F
Intake: 89.6F
I've searched the forum and read that operating temperature is 90C = 194F, and have also read that common spirited driving oil temps are 215F - 230F.
The Perrin oil cooler states the engine is happiest at 85-90C (185F-194F), but then I've also read it's good for the oil to get hotter to boil any water out. So 100C is not bad?
Thoughts?
Old 12-06-2013, 06:16 PM   #467
CBR600RR
Drives: Raven Black
I have Torque Pro
What is the custom PID for the oil temp?
Old 12-06-2013, 06:42 PM   #468
calispec
calispec's Avatar
Drives: Subaru BRZ with Delicious Innovate
Oil Temp: 208.4F
Coolant: 192.2F
Intake: 89.6F
Thoughts?
Perrin probably says that because that is what they have seen with their oil cooler under normal driving haha...
Also... it is important to note that all oil temps you are reading are POST cooler. It is anyone's guess what they are before the cooler or in the pan. And an even bigger question. What are the oil temps in the head or cylinder walls? Probably MUCH higher. I am not saying that that is a bad thing. I am not sure what exactly is happening in that engine while it is running but I think it is safe to assume any oil in the pan is being splashed up by the crank where the water (if there is any) would be sitting on top. the crank, rods, pistons, and cylinder walls are much hotter than the oil. Once it touches anything it will most likely vaporize. If the water makes it through the pump and into the heads it doesn't stand a chance.. Oil too cold isn't a good thing but I don't think pan temps need to be 100C to eliminate water.. and once again.. you have no clue how hot your pan temps are..
It's a little cold where I am so I gave my baby a coat!! Oil temps were 165 now are 205F
[IMG][/IMG]
2013 BR-Zed, Innovate Powered, Delicious Tuned, Zeltus Cooled. Build Thread
www.GT86Mounts.com
calispec is offline   Reply With Quote
The Following User Says Thank You to calispec For This Useful Post:
mike_ekim1024 (12-08-2013)
Old 12-07-2013, 01:35 AM   #469
regal
Drives: Scion FR-S/Toyota Yaris
Originally Posted by zooki View Post
Well, that's just it. I have an Android tablet that only has WiFi. No Bluetooth. So I still don't know if it will work. Has Anybody run Torque over a WiFi scan tool?
Does it have USB?, a miniUSB to USB EML327 may work, no guarantees.
2013 FRS Argento Silver 6MT
Mods:
Clear fender side lights
Tactrix ZA1JB01C 2014 Calib
regal is offline   Reply With Quote
Old 12-07-2013, 05:01 AM   #470
Malt
Drives: 2015 WRX
I have Torque Pro
It's on the second post of this thread
Old 12-07-2013, 10:55 AM   #471
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
Those temps look fine.
Coolant should be around 195 and not move around that much once warmed up.
Oil will always be higher than coolant, 208f is fine. I see that all the time. Track day temp will be 250 up to 270 and thats why some have gone to oil coolers.
Intake temp I've noticed will be 5-10 higher than ambient when car is moving.
Oil Temp: 208.4F
Coolant: 192.2F
Intake: 89.6F
Thoughts?
garfull is offline   Reply With Quote
The Following User Says Thank You to garfull For This Useful Post:
Old 12-18-2013, 04:16 AM   #472
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Hey iOS peeps,
I found this app called 'Engine Link' that does OBD2 stuff for iOS devices AND claims to be able to use custom PIDs as well, in addition to using custom Torque PIDs.
https://itunes.apple.com/us/app/engi...le/id591557194
Anyone tried it out? Would be awesome to be able to log oil temps via OBD2 on iOS (for us Apple peeps).
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 12-18-2013, 09:47 PM   #473
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
Subd.....
gdrider77 is offline   Reply With Quote
Old 12-18-2013, 11:07 PM   #474
ML
ML's Avatar
Is there a oil pressure PID?
Old 12-19-2013, 08:18 PM   #475
Yruyur
Yruyur's Avatar
No. The sensor is only on or off.
Sent from my SCH-I545 using Tapatalk 2
The Following User Says Thank You to Yruyur For This Useful Post:
ML (12-19-2013)
Old 12-19-2013, 09:55 PM   #476
mike_ekim1024
I'm interested in seeing other people's Torque setups and layouts.. could we start another thread or is here OK?
Mike
android, app, boost, gauges, torque
Torque app for android question Brody602 Electronics | Audio | NAV | Infotainment 8 01-08-2015 04:53 PM
Torque for Android Freeman Scion FR-S / Toyota 86 GT86 General Forum 7 11-22-2012 11:05 PM
Android Torque app questions Craig Engine, Exhaust, Transmission 1 11-12-2012 04:14 PM
Bluetooth OBD scanner and Android Torque - less than 25 shipped whataboutbob Engine, Exhaust, Transmission 7 10-20-2012 01:15 PM
Android Tablet + torque CharlieChaos Electronics | Audio | NAV | Infotainment 3 10-04-2012 08:23 PM
