Old 12-19-2013, 04:07 PM   #533
gmsii
gmsii's Avatar
I may have missed this, but can anyone post the diameter of the pulley on the Rotrex? @gmsii @KraftWerks
you are asking the wrong question.
gmsii is offline   Reply With Quote
Old 12-19-2013, 05:15 PM   #534
CSG Mike
CSG Mike's Avatar
I'm not understanding... I just want to know the diameter of the default cogged pulley on the supercharger is.
Will you be offering alternate pulleys for the current C30-94 setup?
Old 12-19-2013, 05:21 PM   #535
Calum
That Guy
Drives: 2013 asphalt FRS MT
Let me see if I can translate douche to english for you. What I think he's getting at is that you would have to know the number of teeth on both pulleys to know what the actual speed ratio is.
I've been thinking about asking the same question though, so, @gmsii how many teeth are on both gears. Or if you feel like saving us the time of doing the math, what did you end up with for a supercharger impeller rpm at 7450 engine crankshaft rpm?
And Mike, do you know the supercharger impeller rpm for the JR kit.
Old 12-19-2013, 06:01 PM   #536
Ralph Spoilsport
Ralph Spoilsport's Avatar
Drives: 2013 BRZ, WRB
Looking at DA's pics, I think I see 30T(-75mm?) on the small cog and 40T on the big one.
Ralph Spoilsport is offline   Reply With Quote
Old 12-19-2013, 06:10 PM   #537
CSG Mike
CSG Mike's Avatar
Oh, I forgot the belt system is independent. I suppose I'll be counting the teeth. Be back in a minute.
*edit*
Okay, I can't see all the teeth, and I don't have a kit on hand to do any math.
@gmsii: What RPM is the supercharger spinning at redline with the included pulley?
Old 12-19-2013, 06:17 PM   #538
CSG Mike
CSG Mike's Avatar
About 87k. The blower is rated for 100k. Impeller RPM is about 9100 at 7400 engine RPM on the Jackson Racing kit. I'm trying to figure out what it is on the Kraftwerks kit.
Old 12-19-2013, 06:20 PM   #539
cobrabyte
cobrabyte's Avatar
Drives: 2013 BRZ, 2002 WRX
Being as though they recommend a redline of 7800 RPM, that may tell you what the rotational speed is at that point. Dunno if they've put some wiggle room in there. I have no clue.
cobrabyte is offline   Reply With Quote
Old 12-19-2013, 06:23 PM   #540
cobrabyte
cobrabyte's Avatar
Perhaps the parts sheet has what you need:
Old 12-19-2013, 06:33 PM   #541
CSG Mike
CSG Mike's Avatar
Crank pulley 100mm, Rotrex pulley 75mm. Got it. Not sure why it was so difficult for them to just tell me that... brb after I do some quick math.
3 rotations on crank = 4 rotations on Rotrex. Essentially, 1.33 multiplication. Teeth counts confirm, 30 vs 40.
7800 RPM redline * 40 teeth / 30 teeth = 10400 impeller RPM.
The Rotrex C30-94 is spec'ed out for 10500 impeller RPM.
the blower is set up to hit 10.2psi with a max engine RPM of 7800.
we have a smaller pulley set-up where the engine redline is set for 7300rpm engine that makes about 13psi boost and about 15whp more in the midrange and 30whp more peak
Essentially, the blower is maxed out with the Kraftwerks kit, at the 7800 RPM that Kraftwerks recommends (per the post above). I'm guessing the 7300RPM redline pulley is a 38 tooth pulley/71mm pulley??
Old 12-19-2013, 06:45 PM   #542
gmsii
gmsii's Avatar
wouldn't have been hard to tell you bro....just wanted peeps to slow down and think about things a bit...no ****ishness intended. sorry
yes, blower is close to being maxed out at 7800rpm, but kit performance is not maxed out by any means....we will be offering a pulley upgrade shortly that will change the power delivery quite dramatically
Old 12-19-2013, 06:46 PM   #543
OjiGeorge
OjiGeorge's Avatar
Drives: White 2013 FRS
Would it make sense to wait for C38 kit for those of us that want higher power numbers on stock internals? Planning on WMI w 93 octane and upgraded fuel system.
OjiGeorge is offline   Reply With Quote
Old 12-19-2013, 06:49 PM   #544
gmsii
gmsii's Avatar
we'll be releasing preliminary test data soon enough for you to make that determination...keep an eye out
The Following User Says Thank You to gmsii For This Useful Post:
OjiGeorge (12-19-2013)
Old 12-19-2013, 06:50 PM   #545
CSG Mike
CSG Mike's Avatar
Only if you have the supporting mods for that kind of output (Transmission, axles, etc). The base kit is plenty of power...
Old 12-19-2013, 07:28 PM   #546
OjiGeorge
OjiGeorge's Avatar
Can't seem to stop spending money on the car, so the supporting mods are sure to follow. ATM trying to reduce the risk of buying a system that will not be able to keep up with future mods. It will likely come down to the the KW or the AVO kit. Both because Drift Office is relatively close, and has experience with tuning both of these kits.
The Following User Says Thank You to OjiGeorge For This Useful Post:
sw20kosh (12-19-2013)
[TX] DFW General Discussion feedbag Southwest 1488 06-18-2022 07:25 PM
HKS GT Supercharger (Rotrex) in development! madfast Engine, Exhaust, Transmission 206 12-14-2012 03:28 PM
ROTREX SC Brainstorming MANDALAY Forced Induction 61 12-11-2012 05:57 PM
Rotrex kit - why no build? MindtheGap Engine, Exhaust, Transmission 5 10-26-2012 07:01 PM
